Half life of multi chain decays
  • Thread starter Thread starter heroslayer99
    Graph Half life
The discussion focuses on understanding the half-life of multi-chain decays, particularly how it relates to the decay rates of intermediate steps. It suggests that if the decay rate of Y is significantly higher than that of X, the decay events occur closely together, leading to a total decay rate that approximates twice that of X. A differential equation can be established to analyze this relationship further. The conversation also raises questions about the measurement of activities and whether they are distinguishable. Overall, the relationship between half-lives in multi-chain decays is complex and requires careful mathematical modeling.
heroslayer99
If we had a multi decay mechanism where say, X decayed into Y then Y decayed into Z, and we plotted activity against time of a sample of X, what would the half life of the graph represent? (Assume the half life of X to Y step is much greater than the Y to Z half life)
x
I am not really too sure where to start with this one, I would guess that the half life of the graph is very similar to the half life of the X to Y step, but at the same time I am unsure of how I would prove it. Any tips or reading material? Thanks!
Well, you could set up a differential equation and solve it.
A more qualitative approach would be to say: if the decay rate constant (inversely proportional to half life) of Y is much greater than that of X, then effectively X decays relatively slowly, and (almost) every time an X decays to a Y, that Y (almost) immediately decays to a Z. In other words, every time an X decays there are two decay events within a very short time of each other. So the total decay rate is (to a good approximation) twice the decay rate of X; the two graphs are the same except that one has the y coordinate multiplied by 2, and the half lives are the same.
Now do the differential equation.
It depends what activity is measured. Are the two activities indistinguishable?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
