Half-Life & Constant Emission: Understand Why
In summary: Since the decay constant is very small, ##A_o-A \approx A_o## where ##A_o## is initial activity and ##A## is a decrease in activity over a significant period of time.Since Activity remains constant, the rate of emission remains constant.
Faiq
348
A radioactive source emits alpha particles at a constant rate 3.5x10^6 s^-1. The particles are collected for a period of 40 days.
BY reference to the half life of the source, suggest why it may be assumed that rate of emission of alpha particles remain constant?
I cannot, however, find a way to incorporate the half-life into the answer which the question specifically mentions. I am aware of the relation between decay constant and half-life, but for this situation, I cannot develop a clear logic which involves the half-life of the source. More specifically how does rate of emission remains constant if a half-life is high?
Secondly, how do I know half life is high in this question?
Thirdly, what is the significance of the provided period of 40 days?
Secondly, how do I know half life is high in this question? Thirdly, what is the significance of the provided period of 40 days?
Reference https://www.physicsforums.com/threads/half-life-question.908387/
Good questions. To which I would add: What is the mass of the source and its atomic weight, or equivalently the number of gram-moles it contains? A flux of 3.5x10^6 particles per second is one thing if it's coming from a 5 kg source, and something else if it's produced by 1 mg.
Is this problem related to an earlier one where more information is provided?
I'd take the decay equation, expand the exponential and consider what might be a good approximation.
Edit: Is it possible you're being asked to say something in terms of a general (long) half-life?
Nothing else is provided. This is the whole question
Well the answer of this question given was
either the half life of the source very long
or decay constant is very small
or half life >> 40 days
or decay constant << 0.02 day ^-1
Btw I get what you are saying,
For the equation, ##A = λN## to work, I should know the value of N. Earlier, I drew my conclusions by prematurely assuming that N = 6.02*10^23.
I think I'd approach it this way. Assume the source is reasonably pure and macroscopic--say a few grams. Pick a credible mass number, and estimate the number of alpha emitters in the source. Compare that number to the number of decays, at the specified rate, in one second, an hour, a day, 40 days . . . (Note that whatever the half life, the rate can only go down; so assuming a constant rate gives an upper bound on the actual number of decays in each period.)
Edit With luck you'll find that the details of your assumptions (mass, mass number, purity) don't matter much.
Edit:
Each of these pairs says the same thing twice. The half life is inversely proportional to the decay constant, so if one is large, the other must be small.
The wording of this question is atrocious. Are you sure you have quoted it exactly? Is it a translation?
The time for which the particles are collected provides no information in itself. I can only suppose it intends to convey that the collection rate appeared constant for 40 days.
Okay but let's assume the half life is of the order of 10000 years.
Now how does this half life constitutes a constant rate of emission?
Would you agree that it would result in an approximately constant rate of emission over a span of 40 days? Can you calculate how much the rate would have reduced between start and end of that span?
Let me see,
##A = A_oe^{-\frac{ln2}{t_{1/2}}t}##
##A = A_o*e^{-\frac{ln2}{10000*365}40}##
##A=0.99999A_o##
Got your point.
Likes jbriggs444
FAQ: Half-Life & Constant Emission: Understand Why
1. What is the concept of Half-Life?
The concept of Half-Life refers to the amount of time it takes for a substance to decay or deteriorate by half of its original amount. This concept is commonly used in nuclear physics and chemistry to study the rate of radioactive decay.
2. How is Half-Life related to Constant Emission?
Half-Life and Constant Emission are closely related as they both involve the decay of a substance over time. Constant Emission refers to the continuous emission of particles or energy from a radioactive substance, while Half-Life is the time it takes for the amount of a substance to decrease by half through radioactive decay.
3. What factors affect the Half-Life of a substance?
The Half-Life of a substance can be affected by a variety of factors, including the type of substance, its chemical properties, and the amount of energy or radiation it emits. The presence of other substances or external factors can also influence the rate of decay.
4. Why is understanding Half-Life and Constant Emission important?
Understanding Half-Life and Constant Emission is crucial in fields such as nuclear physics, chemistry, and environmental science. It allows scientists to accurately predict the rate of decay of radioactive substances, which can have significant implications for health, safety, and the environment.
5. Can Half-Life and Constant Emission be artificially manipulated?
Yes, Half-Life and Constant Emission can be manipulated through various methods such as nuclear reactions, chemical processes, and external influences. However, the natural rate of decay for a substance is constant and cannot be altered.
