Hall Effect Measurements and Analysis
In summary, the Hall effect is used to measure the dopant concentration and to determine other information about the sample. The Hall coefficient is used to measure the majority/minority mobilities.
OnesieWithaZ
Hi all,
I am reading about hall effect measurements and analysis from an old physics book, A. C. Melissinos, Experiments in Modern Physics, for a lab class I'm taking.
An experiment involving hall and resistivity measurements of a p-type germanium sample is performed and discussed. He notes that the temperature dependence from the Hall mobility is ~ T^-1.5 - but the actual hole mobility (derived from the resistivity measurements in the extrinsic region) is ~ T^-2. He says this is why they distinguish between Hall and lattice mobilities.
My question: is it possible to use the Hall coefficient to obtain useful knowledge about the majority/minority mobilities? If not... do you just use the Hall coefficient as a means of measuring the dopant concentration and then use resistivity measurements to obtain everything else?
Also what is the difference between Hall mobility and lattice mobility? Theoretically it seems as if they would be the same... the only failing point I see is there are some assumptions about the mean free path in the calculation.
take help from below;
http://journals.aps.org/prb/abstract/10.1103/PhysRevB.8.5632
The carrier concentration and mobility, as determined from the Hall effect, have been analyzed using a computer for a series of n-type silicon samples doped with Sb, P, and As.
Mobility calculations, performed numerically, were based on the general treatment given by Herring and Vogt. Ionized-impurity scattering was calculated from two theories and compared with experiment.
Lattice-scattering parameters for intervalley and accoustic modes were determined from a comparison of the results between theory and experiment, using as many as four intervalley phonons.
The conclusions support the earlier work of Long, and a partial explanation of the disagreement with parameters determined from other measurements is suggested. Scattering by neutral impurities is found to be temperature dependent, unlike the theoretical model of Erginsoy.
Impurity and Lattice Scattering Parameters as Determined from Hall and Mobility Analysis in n-Type Silicon
P. Norton, T. Braggins, and H. Levinstein
Phys. Rev. B 8, 5632 – Published 15 December 1973
I'll look into this paper - thanks for your response
FAQ: Hall Effect Measurements and Analysis
What is the Hall Effect?
The Hall Effect is a phenomenon in which an electric current flowing through a conductor in the presence of a magnetic field will experience a force perpendicular to both the current and magnetic field. This effect is named after physicist Edwin Hall, who discovered it in 1879.
How are Hall Effect measurements performed?
Hall Effect measurements involve passing a current through a sample material while subjecting it to a perpendicular magnetic field. The resulting voltage across the sample is measured and used to calculate the Hall coefficient, which is a measure of the material's electrical conductivity and magnetic properties.
What can Hall Effect measurements tell us about a material?
Hall Effect measurements can provide information about a material's electrical conductivity, carrier concentration, and mobility. This can help researchers understand the material's electronic and magnetic properties, as well as its potential applications in electronic devices.
What are some common applications of Hall Effect measurements?
Hall Effect measurements are commonly used in the semiconductor industry to characterize materials and devices, such as transistors and integrated circuits. They are also used in the development of sensors, such as Hall effect sensors for measuring magnetic fields and current sensors for measuring electric current.
How is Hall Effect analysis used in materials research?
Hall Effect analysis is used in materials research to study the electronic and magnetic properties of various materials, including semiconductors, metals, and insulators. It can help researchers understand the behavior of charge carriers and identify any defects or impurities present in the material.
