Halogens exist in different physical state
In summary, the halogens exist in different physical states at room temperature and atmospheric pressure. The boiling points and melting points for these elements are based on molecular size. The effect of molecular size on intermolecular forces is discussed. The boiling and melting points relate to each other in a way that is not clear to me.
physicsss
319
At room temperature and atmospheric pressure, the halogens exist in different physical states. Chlorine is a gas, bromine is a liquid, and iodine is a solid. What are the boiling points and melting points for these elements? Estimate the volume of the Cl2, Br2, and I2 molecules. Comment on the effect of molecular volume on intermolecular forces. Compare and contrast the intermolecular interactions of the molecules.
I think I can look for the boiling and melting points online.
For the second question, do I use PV=nRT, where P=1 atm, n=1/molar mass of the gases, and T=298K? (not sure about n)
For the 3rd and 4th question, can someone give me a hint? And does boiling and melting points relate to them in any way?
Thank you.
Chemistry news on Phys.org
I think increasing atomic size reduces the control of valence shell electrons by the core, thus iodine's valence electrons are more active than bromine, and so on. Solid formation involves intermolecular forces, so increased activity results in an increased rate of this kind of interaction.
Yeah, you can actually work out PV=nRT to find that at standard temperature and pressure 22.4L of gas corresponds to on mole of the ideal gas. You may note that some of the halogens do not exists as gases under these conditions.
With stronger intermolecular interactions will result in higher boiling points, since higher internal energy is required to achieve separation from intermolecular attractions which are due to the respective properties of each element.
Volume of the molecule has nothing to do with the volume of the ideal gas. No idea what kind of estimation you should made.
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
Related to Halogens exist in different physical state
1. What are the different physical states in which halogens exist?
Halogens exist in three physical states: solid, liquid, and gas. These states are dependent on factors such as temperature and pressure.
2. Which halogen is found in a gaseous state at room temperature?
Fluorine is the only halogen that exists in a gaseous state at room temperature. The other halogens - chlorine, bromine, and iodine - are found in either liquid or solid states.
3. Why do halogens have different physical states?
The different physical states of halogens are a result of their atomic structure and the strength of their intermolecular forces. As the atomic size increases down the halogen group, the intermolecular forces also increase, resulting in a change in physical state.
4. What is the melting and boiling point trend of halogens?
The melting and boiling points of halogens increase down the group. This is due to the increasing strength of intermolecular forces as the atomic size increases.
5. What is the significance of the different physical states of halogens?
The different physical states of halogens make them useful for various applications. For example, gaseous fluorine is used in the production of refrigerants, while liquid bromine is used in flame retardants. Solid iodine is used in medicine and photography.
