Hamiltonian Commutation Question
In summary: And, furthermore, if there exist multiple non-commuting operators that all commute with the Hamiltonian, the Hamiltonian must be degenerate. So any Hamiltonian that commutes with all three of the angular momentum operators (or even any two of them) must be degenerate.
Diracobama2181
75
TL;DR Summary
Why certain operators commute when they commute with the Hamiltonian.
Why is it the case that when some operators commute with the Hamiltonian (let's say A and ), it implies A and B commute, but even when each angular momentum component commutes with the Hamiltonian, it does not imply each the angular momentum components commute with each other?
Why? Where are you getting this from?
If two separate operators commute with the hamiltonian, then it implies they share a common set of eigenvectors. Using this reasoning, it can be shown that A and B commute. However, this proof fails for L_i. I just want to know why it fails. I believe it has to do with degeneracy.
This does not hold in general if the Hamiltonian is degenerate.
For example, all operators commute with the identity operator and all Hermitian operators share an eigenbasis with the identity operator. But, this does not imply they share an eigenbasis with each other.
Note that in the theory of spin 1/2 particles, for example, ##L^2## is represented by a multiple of the identity operator.
Likes Diracobama2181
If the Hamiltonian of the system is something like
##H=\begin{bmatrix}1 & 0 \\ 0 & 1\end{bmatrix}##
and ##A## and ##B## are non-commuting 2x2 matrices, then ##A## and ##B## both commute with ##H## (as any matrix commutes with a matrix that is equivalent to scalar multiplication) but ##AB\neq BA## and there is no common eigenbasis of ##A## and ##B##.
Likes vanhees71
Take as an example the free particle with the Hamiltonian
$$\hat{H}=\frac{\hat{\vec{p}}^2}{2m}.$$
Obviously ##\hat{H}## commutes with all three momentum components ##\hat{\vec{p}}##. Since also the momentum components commute you have a complete set of energy eigenvectors given by the momentum-eigenvectors ##|\vec{p} \rangle##.
Since ##\hat{H}## is a scalar with respect to rotations, ##\hat{H}## also commutes with the three orbital-angular-momentum operators ##\hat{\vec{L}}=\hat{\vec{x}} \times \hat{\vec{p}}##, but the ##\hat{\vec{L}}## do not commute among themselves. That's a counterexample to your claim in #1. Of course there's a complete set of orthonormal eigenvectors of ##\hat{H}##, ##\hat{\vec{L}}^2##, and ##\hat{L}_3##. These are of course no eigenvectors of ##\hat{\vec{p}}## (but only eigenvectors of ##\hat{\vec{p}}^2=2m \hat{H}##).
Related to Hamiltonian Commutation Question
1. What is Hamiltonian Commutation Question?
Hamiltonian Commutation Question is a concept in quantum mechanics that deals with the commutation of two operators known as the Hamiltonian and the observable. It is used to determine whether these operators commute or not, which has implications for the measurement and prediction of physical quantities in a quantum system.
2. How is Hamiltonian Commutation Question related to the Heisenberg uncertainty principle?
The Heisenberg uncertainty principle states that it is impossible to know both the position and momentum of a particle with absolute certainty. Hamiltonian Commutation Question is related to this principle because it helps determine the commutator between the position and momentum operators, which is a key factor in calculating the uncertainty in these values.
3. What does it mean if two operators commute?
If two operators commute, it means that their order of operation does not affect the final result. In other words, the operators can be applied in any order without changing the outcome. This is an important concept in quantum mechanics as it allows for the prediction of physical quantities in a quantum system.
4. What are the implications of non-commuting operators in Hamiltonian Commutation Question?
If two operators do not commute, it means that their order of operation does affect the final result. This has implications for the measurement and prediction of physical quantities in a quantum system, as the uncertainty in these values will be affected. Non-commuting operators also indicate that the system is not in an eigenstate, which can have consequences for the overall behavior of the system.
5. How is Hamiltonian Commutation Question used in practical applications?
Hamiltonian Commutation Question is used in various practical applications, such as in quantum computing, quantum cryptography, and quantum information processing. It is also used in the study of quantum systems and in the development of new technologies that utilize the principles of quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
