Hamiltonian matrix off diagonal elements?
In summary: By the way, if you haven't seen this sort of thing before, you should take a minute to verify this for yourself).Anyway, this particular matrix element evaluates to -1/2, and so we have the contribution to the 2nd row, 3rd column of the matrix. In summary, the Hamiltonian matrix is built by finding the matrix elements of the various operators in the new basis, and filling them in according to the Clebsch-Gordan coefficients.
TheDestroyer
402
I'm trying to understand how Hamiltonian matrices are built for optical applications. In the excerpts below, from the book "Optically polarized atoms: understanding light-atom interaction", what I don't understand is: Why are the [itex] \mu B[/itex] parts not diagonal? If the Hamiltonian is [itex]\vec{\mu} \cdot \vec{B}[/itex] , why aren't all the components just diagonal? How is this matrix built systematically? Can someone please explain?
The following part is from the book:
We now consider the effect of a uniform magnetic field [itex]\mathbf{B} = B\hat{z}[/itex] on the hyperfine levels of the [itex] {}^2 S_{1/2}[/itex] ground state of hydrogen. Initially, we will neglect the effect of the nuclear (proton) magnetic moment. The energy eigenstates for the Hamiltonian describing the hyperfine interaction are also eigenstates of the operators [itex] \{F^2, F_z, I^2, S^2\}[/itex] . Therefor if we write out a matrix for the hyperfine Hamiltonian [itex] H_\text{hf}[/itex] in the coupled basis [itex] \lvert Fm_F\rangle[/itex] , it is diagonal. However, the Hamiltonian [itex] H_B[/itex] for the interaction of the magnetic moment of the electron with the external magnetic field,
$$H_B = -\mathbf{\mu}_e\cdot\mathbf{B} = 2\mu_B B S_z/\hbar,\tag{4.20}$$
is diagonal in the uncoupled basis [itex] \lvert(SI)m_S, m_I\rangle[/itex] , made up of eigenstates of the operators [itex] \{I^2, I_z, S^2, S_z\}[/itex] . We can write the matrix elements of the Hamiltonian in the coupled basis by relating the uncoupled to the coupled basis. (We could also carry out the analysis in the uncoupled basis, if we so chose.)
The relationship between the coupled [itex] \lvert Fm_F\rangle[/itex] and uncoupled [itex] \lvert(SI)m_Sm_I\rangle[/itex] bases (see the discussion of the Clebsch-Gordan expansions in Chapter 3) is
$$\begin{align}
\lvert 1,1\rangle &= \lvert \bigl(\tfrac{1}{2}\tfrac{1}{2}\bigr)\tfrac{1}{2}\tfrac{1}{2} \rangle ,\tag{4.21a} \\
\lvert 1,0\rangle &= \frac{1}{\sqrt{2}}\biggl(\lvert \bigl(\tfrac{1}{2} \tfrac{1}{2}\bigr) \tfrac{1}{2},-\tfrac{1}{2}\rangle + \lvert\bigl(\tfrac{1}{2}\tfrac{1}{2}\bigr),-\tfrac{1}{2}\tfrac{1}{2}\rangle\biggr),\tag{4.21b} \\
\lvert 1,-1 \rangle &= \lvert \bigl(\tfrac{1}{2}\tfrac{1}{2}\bigr),-\tfrac{1}{2},-\tfrac{1}{2} \rangle,\tag{4.21c} \\
\lvert 0,0\rangle &= \frac{1}{\sqrt{2}}\biggl( \lvert \bigl( \tfrac{1}{2} \tfrac{1}{2}\bigr)\tfrac{1}{2},-\tfrac{1}{2}\rangle - \lvert\bigl(\tfrac{1}{2}\tfrac{1}{2}\bigr),-\tfrac{1}{2}\tfrac{1}{2}\rangle\biggr),\tag{4.21d}
\end{align}$$
Employing the hyperfine energy shift formula (2.28) and Eq. (4.20), one finds for the matrix of the overall Hamiltonian [itex] H_\text{hf} + H_B[/itex] in the coupled basis
$$H = \begin{pmatrix}
\frac{A}{4} + \mu_B B & 0 & 0 & 0 \\
0 & \frac{A}{4} - \mu_B B & 0 & 0 \\
0 & 0 & \frac{A}{4} & \mu_B B \\
0 & 0 & \mu_B B & -\frac{3A}{4}
\end{pmatrix},\tag{4.22}$$
where we order the states [itex] (\lvert 1,1\rangle, \lvert 1,-1\rangle, \lvert 1,0\rangle, \lvert 0,0\rangle)[/itex] .
And for Eq. (2.28) the other part is
$$\Delta E_F = \frac{1}{2}AK + B\frac{\frac{3}{2}K(K + 1) - 2I(I + 1)J(J + 1)}{2I(2I - 1)2J(2J - 1)},\tag{2.28}$$
where [itex] K = F(F + 1) - I(I + 1) - J(J + 1)[/itex] . Here the constants [itex] A[/itex] and [itex] B[/itex] characterize the strengths of the magnetic-dipole and the electric-quadrupole interaction, respectively. [itex] B[/itex] is zero unless [itex] I[/itex] and [itex] J[/itex] are both greater than [itex] 1/2[/itex] .
I'm not completely familiar with your notation (what F, I and S are in terms of the physics). However, it appears that the author is assuming that the initial Hamiltonian is the hyperfine hydrogen Hamiltonian. Such a hamiltonian is diagonal in the same basis that the following operators, [itex]\{F^2, F_z, I^2, S^2\}[/itex] are diagonal, where [itex]\vec{F} = \vec{I} + \vec{S}[/itex]. This usually occurs when the Hamiltonian contains a term [itex]\vec{I} \cdot \vec{S} = (F^2 - I^2 - S^2)/2[/itex].
However, when one adds a magnetic field, it introduces a term coupling to the magnetic moment of the system. In principle, this should be two terms, [itex](\vec{\mu}_e + \vec{\mu}_p) \cdot \vec{B}[/itex], where the constants are the magnetic moments of the electron and proton respectively. Explicitly, [itex]\vec{\mu}_{e,p} = g_{e,p} \mu_{e,p} \vec{S}_{e,p}/\hbar[/itex], where S is the angular momentum operator for the particles, g is a fundamental proportionality constant of order 1 (g is approximately 2 for electrons, 5.6 for protons), and [itex]\mu = e \hbar/2m[/itex] and m is particle mass. Thus, since the proton mass is about 2000 times larger, we ignore this and only consider the electron term.
So our new Hamiltonian contains a term [itex]S_z[/itex], which cannot be made diagonal in our basis. Specifically, the mathematical identity [itex][F^2,S_z] \neq 0[/itex] guarantees that these operators can never both be diagonal. However, we know that we can choose a basis [itex]\{I^2, I_z, S^2, S_z\}[/itex] where [itex]S_z[/itex] is diagonal. Therefore, one can make a transformation from one basis to the other. The matrix elements of the transformation are the Clebsch-Gordan coefficients. What your book has done is transform the magnetic hamiltonian into the basis of your original problem, where it is nondiagonal.
Thank you for your reply.
The problem is exactly the way you understood it. Actually my problem is how to create the Hamiltonian matrix in the [itex] \left| {{I^2}{I_z}{S^2}{S_z}} \right\rangle [/itex] basis. Can you please explain how to create that hamiltonian?
Ok, I'm still vague about the situation, but I'll take a guess as to what you want. Your question, if I'm understanding it correctly, is how to take an operator which is diagonal in the [itex]\left| {{I^2}{I_z}{S^2}{S_z}} \right\rangle[/itex] basis and write it in the [itex]\left| {{F^2}{F_z}{I^2}{S^2}} \right\rangle[/itex] basis?
This is the well-known problem of addition of angular momentum, and finding the Clebsch-Gordan coefficients. Your book claims to cover this in Chapter 3, and every quantum mechanics text should cover it in detail. The idea is that there exists a linear transformation between the two bases:
$$ \left| {{F}{m_F}{I}{S}} \right\rangle = \sum_{m_I,m_S} C_{m_I,m_S}(I,S;m_I,m_S) \left| {{I}{S}{m_I}{m_S}} \right\rangle $$
(Note that I am now labeling the kets by their eigenvalues, rather than the operators). There is a standard procedure for obtaining the constants C, but you should really read up on it. This is how you obtain the relations 4.21 in your OP.
One can then build up the matrix in the new basis. As an example, let me write a matrix element here, where I'll use 4.21 from your OP:
$$ \left\langle 1 0 \frac{1}{2} \frac{1}{2} \right| S_z \left| 0 0 \frac{1}{2} \frac{1}{2} \right\rangle = \frac{1}{2} \left( \left\langle (\frac{1}{2} \frac{1}{2}) \frac{1}{2} -\frac{1}{2} \right| + \left\langle (\frac{1}{2} \frac{1}{2}) -\frac{1}{2} \frac{1}{2} \right| \right) S_z \left( \left| (\frac{1}{2} \frac{1}{2}) \frac{1}{2} -\frac{1}{2} \right\rangle - \left| (\frac{1}{2} \frac{1}{2}) -\frac{1}{2} \frac{1}{2} \right\rangle \right)$$
Notice that the off-diagonal matrix elements on the right are zero, since Sz is diagonal on the basis on the right:
$$ \left\langle 1 0 \frac{1}{2} \frac{1}{2} \right| S_z \left| 0 0 \frac{1}{2} \frac{1}{2} \right\rangle = \frac{1}{2} \left( \frac{\hbar}{2} \left\langle ( \frac{1}{2} \frac{1}{2}) \frac{1}{2} -\frac{1}{2} | (\frac{1}{2} \frac{1}{2}) \frac{1}{2} -\frac{1}{2} \right\rangle - (- \frac{\hbar}{2}) \left\langle ( \frac{1}{2} \frac{1}{2}) -\frac{1}{2} \frac{1}{2} | (\frac{1}{2} \frac{1}{2}) -\frac{1}{2} \frac{1}{2} \right\rangle \right) = \frac{\hbar}{2} $$
Therefore, the matrix [itex]S_z[/itex] has an off-diagonal element in the [itex]\left| {{F^2}{F_z}{I^2}{S^2}} \right\rangle[/itex] basis. The calculation above allows you to compute the rest of the matrix 4.22 in your OP.
Thank you so much for your answer. There's something weird happening when I do this calculation that I don't understand.
Now we are adding I and S, and this addition is supposed to be commutative, right? Look at the expectation value that you wrote there:
[itex]\left\langle 1 0 \frac{1}{2} \frac{1}{2} \right| S_z \left| 0 0 \frac{1}{2} \frac{1}{2} \right\rangle = \frac{1}{2} \left( \left\langle (\frac{1}{2} \frac{1}{2}) \frac{1}{2} -\frac{1}{2} \right| + \left\langle (\frac{1}{2} \frac{1}{2}) -\frac{1}{2} \frac{1}{2} \right| \right) S_z \left( \left| (\frac{1}{2} \frac{1}{2}) \frac{1}{2} -\frac{1}{2} \right\rangle - \left| (\frac{1}{2} \frac{1}{2}) -\frac{1}{2} \frac{1}{2} \right\rangle \right)[/itex]
What I don't understand is I=1/2 and S=1/2, and this makes it possible to exchange between the values you have inside your kets, which means that Sz can be either +1/2 or -1/2 depending on the mixing you do.
To clarify more, look at this:
[itex] \left( \left| (\frac{1}{2} \frac{1}{2}) \frac{1}{2} -\frac{1}{2} \right\rangle - \left| (\frac{1}{2} \frac{1}{2}) -\frac{1}{2} \frac{1}{2} \right\rangle \right) [/itex]
In each ket you (conceptually) can choose [itex]S_z[/itex] to be either +1/2 or -1/2, but it just has to be done consistently, so if you choose the first ket 1/2 as the eigen value for Sz, then you have to choose -1/2 in the second one, and vice versa, which is another way to say that angular momentum addition is commutative since I=S=1/2. Is my reasoning correct?
Now the surprise for me, that the result changes and depends on your choice. So it's once [itex]\hbar /2[/itex] and once [itex]-\hbar /2[/itex] depending on which one you choose.
How do you explain that? Please elaborate.
Why is this important? Because I'm writing a computer program to do this stuff as an initiation for a very complicated simulation with 32 levels, and I got my matrix with two different signs for those mixed states, because I chose a different ordering for the sum, which confused me.
Related to Hamiltonian matrix off diagonal elements?
1. What are the off-diagonal elements of a Hamiltonian matrix?
The off-diagonal elements of a Hamiltonian matrix represent the coupling between different states in a quantum system. They describe the probability of a particle transitioning from one state to another.
2. How are the off-diagonal elements of a Hamiltonian matrix calculated?
The off-diagonal elements are typically calculated using the Schrödinger equation and the wavefunction of the system. They can also be determined experimentally through measurements of the energy levels of the system.
3. What is the significance of the off-diagonal elements in a Hamiltonian matrix?
The off-diagonal elements play a crucial role in understanding the behavior of a quantum system. They determine the probability of transitions between different states, which can affect the overall dynamics and evolution of the system.
4. Can the off-diagonal elements of a Hamiltonian matrix be zero?
Yes, it is possible for some off-diagonal elements to be zero. This indicates that there is no coupling between the corresponding states in the system, and they will not affect each other's behavior.
5. How do the off-diagonal elements affect the energy levels of a Hamiltonian matrix?
The off-diagonal elements can cause energy level splitting, where the initially degenerate energy levels are separated due to the coupling between states. This can lead to new energy eigenstates and affect the overall structure of the energy spectrum.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
