spaghetti3451
- 1,344
- 34
The Klein-Gordon field ##\phi(\vec{x})## and its conjugate momentum ##\pi(\vec{x})## is given, in the Schrodinger picture, by
##\phi(\vec{x})=\int \frac{d^{3}p}{(2\pi)^{3}} \frac{1}{\sqrt{2\omega_{\vec{p}}}}[a_{\vec{p}}e^{i\vec{p}\cdot{\vec{x}}}+a_{\vec{p}}^{\dagger}e^{-i\vec{p}\cdot{\vec{x}}}]##
##\pi(\vec{x})=\int \frac{d^{3}p}{(2\pi)^{3}} (-i)\sqrt{\frac{\omega_{\vec{p}}}{2}}[a_{\vec{p}}e^{i\vec{p}\cdot{\vec{x}}}-a_{\vec{p}}^{\dagger}e^{-i\vec{p}\cdot{\vec{x}}}]##
I would like to show that the Hamiltonian ##H## of the Klein-Gordon theory is given by
##H = \int \frac{d^{3}p}{(2\pi)^{3}}\omega_{\vec{p}}[a_{\vec{p}}^{\dagger}a_{\vec{p}}+\frac{1}{2}(2\pi)^{3}\delta^{(3)}(0)]##.
Here's my attempt:
##H=\frac{1}{2}\int d^{3}x [\pi^{2}+(\nabla\phi)^{2}+m^{2}\phi^{2}]##
##=\frac{1}{2}\int \frac{d^{3}x\ d^{3}p\ d^{3}q}{(2\pi)^{6}}\Big[ -\frac{\sqrt{\omega_{\vec{p}}\omega_{\vec{q}}}}{2} \Big( a_{\vec{p}}e^{i\vec{p}\cdot{\vec{x}}}-a_{\vec{p}}^{\dagger}e^{-i\vec{p}\cdot{\vec{x}}} \Big) \Big( a_{\vec{q}}e^{i\vec{q}\cdot{\vec{x}}}-a_{\vec{q}}^{\dagger}e^{-i\vec{q}\cdot{\vec{x}}} \Big)##
##+ \frac{1}{2\sqrt{\omega_{\vec{p}}\omega_{\vec{q}}}} \Big( i\vec{p}a_{\vec{p}}e^{i\vec{p}\cdot{\vec{x}}}-i\vec{p}a_{\vec{p}}^{\dagger}e^{-i\vec{p}\cdot{\vec{x}}} \Big)\cdot{\Big( i\vec{q}a_{\vec{q}}e^{i\vec{q}\cdot{\vec{x}}}-i\vec{q}a_{\vec{q}}^{\dagger}e^{-i\vec{q}\cdot{\vec{x}}} \Big)}+ \frac{m^{2}}{2\sqrt{\omega_{\vec{p}}\omega_{\vec{q}}}} \Big( a_{\vec{p}}e^{i\vec{p}\cdot{\vec{x}}}+a_{\vec{p}}^{\dagger}e^{-i\vec{p}\cdot{\vec{x}}} \Big)\Big(a_{\vec{q}}e^{i\vec{q}\cdot{\vec{x}}}+a_{\vec{q}}^{\dagger}e^{-i\vec{q}\cdot{\vec{x}}} \Big)\Big]##
##=\frac{1}{4}\int \frac{d^{3}p\ d^{3}q}{(2\pi)^{3}}\Big[-\sqrt{\omega_{\vec{p}}\omega_{\vec{q}}}\Big(a_{\vec{p}}a_{\vec{q}}\delta(\vec{p}+\vec{q})-a_{\vec{p}}^{\dagger}a_{\vec{q}}\delta(-\vec{p}+\vec{q})-a_{\vec{p}}a_{\vec{q}}^{\dagger}\delta(\vec{p}-\vec{q})+a_{\vec{p}}^{\dagger}a_{\vec{q}}^{\dagger}\delta(-\vec{p}-\vec{q})\Big)+\frac{1}{\sqrt{\omega_{\vec{p}}\omega_{\vec{q}}}}\Big(-\vec{p}\cdot{\vec{q}}a_{\vec{p}}a_{\vec{q}}\delta(\vec{p}+\vec{q})+\vec{p}\cdot{\vec{q}}a_{\vec{p}}^{\dagger}a_{\vec{q}}\delta(-\vec{p}+\vec{q})+\vec{p}\cdot{\vec{q}}a_{\vec{p}}a_{\vec{q}}^{\dagger}\delta(\vec{p}-\vec{q})-\vec{p}\cdot{\vec{q}}a_{\vec{p}}^{\dagger}a_{\vec{q}}^{\dagger}\delta(-\vec{p}-\vec{q})\Big)+\frac{m^{2}}{\sqrt{\omega_{\vec{p}}\omega_{\vec{q}}}}\Big(a_{\vec{p}}a_{\vec{q}}\delta(\vec{p}+\vec{q})+a_{\vec{p}}^{\dagger}a_{\vec{q}}\delta(-\vec{p}+\vec{q})+a_{\vec{p}}a_{\vec{q}}^{\dagger}\delta(\vec{p}-\vec{q})+a_{\vec{p}}^{\dagger}a_{\vec{q}}^{\dagger}\delta(-\vec{p}-\vec{q})\Big)\Big]##
##=\frac{1}{4}\int \frac{d^{3}p}{(2\pi)^{3}}\Big[- \omega_{\vec{p}} a_{\vec{p}} a_{-\vec{p}} +
\omega_{\vec{p}} a_{\vec{p}}^{\dagger} a_{\vec{p}} +
\omega_{\vec{p}} a_{\vec{p}} a_{\vec{p}}^{\dagger} - \omega_{\vec{p}} a_{\vec{p}}^{\dagger}
a_{-\vec{p}}^{\dagger} + \frac{1}{\omega_{\vec{p}}} \vec{p}^{2} a_{\vec{p}} a_{-\vec{p}} + \frac{1}{\omega_{\vec{p}}} \vec{p}^{2} a_{\vec{p}}^{\dagger} a_{\vec{p}} + \frac{1}{\omega_{\vec{p}}}
\vec{p}^{2} a_{\vec{p}} a_{\vec{p}}^{\dagger} + \frac{1}{\omega_{\vec{p}}} \vec{p}^{2}
a_{\vec{p}}^{\dagger} a_{-\vec{p}}^{\dagger} + \frac{m^{2}}{\omega_{\vec{p}}} a_{\vec{p}} a_{-\vec{p}} +
\frac{m^{2}}{\omega_{\vec{p}}} a_{\vec{p}}^{\dagger} a_{\vec{p}} + \frac{m^{2}}{\omega_{\vec{p}}} a_{\vec{p}} a_{\vec{p}}^{\dagger} + \frac{m^{2}}{\omega_{\vec{p}}} a_{\vec{p}}^{\dagger} a_{-\vec{p}}^{\dagger}\Big]##
##=\frac{1}{4}\int \frac{d^{3}p}{(2\pi)^{3}}\frac{1}{\omega_{\vec{p}}}\Big[(-\omega_{\vec{p}}^{2}+\vec{p}^{2}+m^{2})a_{\vec{p}}a_{-\vec{p}}+(-\omega_{\vec{p}}^{2}+\vec{p}^{2}+m^{2})a_{\vec{p}}^{\dagger}a_{-\vec{p}}^{\dagger}+(\omega_{\vec{p}}^{2}+\vec{p}^{2}+m^{2})a_{\vec{p}}a_{\vec{p}}^{\dagger}+(\omega_{\vec{p}}^{2}+\vec{p}^{2}+m^{2})a_{\vec{p}}^{\dagger}a_{\vec{p}}\Big]##
##=\frac{1}{4}\int \frac{d^{3}p}{(2\pi)^{3}}\frac{1}{\omega_{\vec{p}}}\Big[(-\omega_{\vec{p}}^{2}+\vec{p}^{2}+m^{2})(a_{\vec{p}}a_{-\vec{p}}+a_{\vec{p}}^{\dagger}a_{-\vec{p}}^{\dagger})+(\omega_{\vec{p}}^{2}+\vec{p}^{2}+m^{2})(a_{\vec{p}}a_{\vec{p}}^{\dagger}+a_{\vec{p}}^{\dagger}a_{\vec{p}})\Big]##
##=\frac{1}{2} \int \frac{d^{3}p}{(2\pi)^{3}}\omega_{\vec{p}}[a_{\vec{p}}a_{\vec{p}}^{\dagger}+a_{\vec{p}}^{\dagger}a_{\vec{p}}]##, where we used ##\omega_{\vec{p}}^{2}=\vec{p}^{2}+m^{2}## to eliminate the first term and simplify the second term
##=\frac{1}{2} \int \frac{d^{3}p}{(2\pi)^{3}}\omega_{\vec{p}}[[a_{\vec{p}},a_{\vec{p}}^{\dagger}]+a_{\vec{p}}^{\dagger}a_{\vec{p}}+a_{\vec{p}}^{\dagger}a_{\vec{p}}]##
##=\int \frac{d^{3}p}{(2\pi)^{3}}\omega_{\vec{p}}[a_{\vec{p}}^{\dagger}a_{\vec{p}}+\frac{1}{2}[a_{\vec{p}},a_{\vec{p}}^{\dagger}]]##
##=\int \frac{d^{3}p}{(2\pi)^{3}}\omega_{\vec{p}}[a_{\vec{p}}^{\dagger}a_{\vec{p}}+\frac{1}{2}(2\pi)^{3}\delta^{(3)}(0)]##
Is my working correct?
Here's my attempt:
