A Hamilton's Method with Lagrange Equation and Constraint
The discussion focuses on applying Hamilton's Principle using Lagrangian mechanics, specifically in the context of a closed loop robot linkage system. The user is comfortable with formulating Hamilton's Principle and deriving Euler Lagrange Equations but seeks a simple example of incorporating constraints using Lagrange multipliers. They request guidance on applying an equality constraint to Hamilton's Principle, particularly for a particle moving in a vertical plane under gravity with a specific constraint equation. The user expresses their background as a retiring mechanical engineer with limited mathematical skills, highlighting their desire to understand these concepts better. A straightforward example would enhance their understanding of combining these advanced mathematical theories.
Trying2Learn
TL;DR Summary
How do you apply constraint to calculus of variations
Good Morning
I am "comfortable" with formulating Hamilton's Principle with a Lagrangian (KE - PE), conducting the calculus of variations and obtaining the Euler Lagrange Equations. Advanced mathematical theory, is beyond me.
I also have a minimal understanding of using Lagrange multipliers.
I would like to combine both, say, for a closed loop on a robot linkage system
My issue is that I would like to see a SIMPLE example of how to apply a constraint (any constraint but formulated as an equality) to Hamilton's Principle
Could someone point me to a simple example?
I am a retiring mechanical engineer with a minimal mathematical skill set. My recent equations are now curiosity -- things I never learned.
Perhaps the simplest example is to write formulas for the case when a particle moves in the vertical plane (x,y) in the standard gravity g and the constraint is ax+by=0
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
