Handles and non-orientible 3D manifolds
In summary, the conversation discusses the concept of using "handles" or "crosscaps" to create 2D and 3D manifolds. A handle is created by cutting out two disks and attaching the ends of a circle x interval product, while a crosscap is equivalent to a Mobius strip with a circular boundary. These handles can be combined and converted to create various 3D manifolds, such as a 3-donut or a solid Klein bottle. The conversation also mentions the possibility of using other types of handles and the generalization of this concept in surgery theory.
bsaucer
30
I've read that with 2D manifolds, you can create any closed 2D manifold by adding "handles" or "crosscaps" (or "crosshandles"). To add a handle, cut out two disks and add the ends of a circle x interval product (cylinder). If you glue one end "the wrong way" you get a "crosshandle", which is how you get a Klein bottle. A "crosscap" is equivalent to a Mobius strip, but it has a circular boundary (instead of a figure-8 boundary folded up double). Use a crosscap to create a projective plane.
There are some "rules" that apply for 2D surfaces: a handle in the presence of a crosscap can be converted to a crosshandle. Two crosscaps can be combined into a crosshandle.
I'm trying to come up with a set of rules for creating 3D manifolds using "handles". If I define a "3-handle" as a 3-sphere x interval product, I can cut out two balls from an S3 and add the two ends of the handle to produce a 3-donut. Or I can glue one end the "wrong way" (adding a 3-crosshandle) and get a "solid Klein bottle".
I can also cut out a ball and plug in a "crossball" to get a real projective space.
You can cut out a solid torus (disk x circle product) and glue it back in a twisted way. Or you can glue in crosscap x circle product (which has a torus boundary). I'm not sure what you'd get.
Are there any other types of "handles" you can attach? I want to cover both orientable and non-orientable cases. Are there any rules about combining these in 3D?
The generalization of attaching handles to higher dimensions is called "http://en.wikipedia.org/wiki/Surgery_theory" ". The operation you are describing is a special case.
I also suggest you look at the article on the http://en.wikipedia.org/wiki/Connected_sum" .
Related to Handles and non-orientible 3D manifolds
1. What is a handle in 3D manifolds?
A handle is a topological feature that allows for a smooth transition between two different parts of a 3D manifold. It is often described as a "tube" or "hole" that connects two surfaces together.
2. How are handles classified in 3D manifolds?
Handles are classified based on their dimensionality, with a handle of dimension n being able to connect two surfaces of dimension n-1. For example, a handle of dimension 1 can connect two surfaces that are lines, while a handle of dimension 2 can connect two surfaces that are circles.
3. What is a non-orientable 3D manifold?
A non-orientable 3D manifold is a space that cannot be consistently assigned a direction or orientation. This means that there is no way to distinguish between the "front" and "back" of the space. A classic example of a non-orientable 3D manifold is the Möbius strip.
4. How are non-orientable 3D manifolds different from orientable ones?
The main difference between non-orientable 3D manifolds and orientable ones is their ability to be consistently assigned an orientation. In orientable 3D manifolds, there is a clear distinction between the "inside" and "outside" of the space, while in non-orientable ones, this distinction is not possible.
5. What are some real-world applications of handles and non-orientable 3D manifolds?
Handles and non-orientable 3D manifolds have many applications in various fields such as physics, engineering, and computer graphics. In physics, they are used to model complex spaces and phenomena, while in engineering, they are used to design and analyze complex structures. In computer graphics, they are used to create realistic and detailed 3D models and animations.
  • Differential Geometry
