MHB Hank's question at Yahoo Answers regarding a first order linear IVP
The discussion revolves around solving a first-order linear initial value problem (IVP) given by the equation 3xy' - 6y = x^{-4} with the initial condition y(1) = -8. The integrating factor is identified as alpha(x) = 1/x^2, which transforms the equation into a standard linear form. The general solution is derived as y(x) = -1/(18x^4) + Cx^2. By applying the initial condition, the constant C is determined to be -143/18, leading to the specific solution y(x) = -(143x^6 + 1)/(18x^4). This concise solution satisfies the original IVP.
MarkFL
MHB
Here is the question:
Could Someone please take a look at this Calc 2 problem?!? Thank you so much!?
Solve 3 x y' - 6 y = x^{-4}, y(1) = -8.
(a) Identify the integrating factor, alpha(x).
I know in a) alpha(x) = e^(-2ln(abs(x)))
But I am not sure how to do parts (b) and (c).
(b) Find the general solution.
y(x) = ?
(c) Solve the initial value problem y(1) = -8
y(x) = ?
Thank you so much for your help!
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Hank,
First, let's write the ODE in standard linear form:
$$\frac{dy}{dx}+\frac{-2}{x}y=\frac{1}{3x^5}$$
a) We find the integrating factor is:
$$\alpha(x)=e^{-2\int\frac{dx}{x}}=\frac{1}{x^2}$$
b) Multiplying the ODE in linear form by this integrating factor, we obtain:
$$\frac{1}{x^2}\frac{dy}{dx}+\frac{-2}{x^3}y=\frac{1}{3x^7}$$
Observing that the left side is now the differentiation of the product of the integrating factor and $y$, we may write:
$$\frac{d}{dx}\left(\frac{y}{x^2} \right)=\frac{1}{3x^7}$$
Integrating both sides with respect to $x$, we get:
$$\int\,d\left(\frac{y}{x^2} \right)=\frac{1}{3}\int x^{-7}\,dx$$
$$\frac{y}{x^2}=-\frac{1}{18x^6}+C$$
Solving for $y$, we obtain the general solution:
$$y(x)=-\frac{1}{18x^4}+Cx^2$$
c) Using the initial values, we may write:
$$y(1)=-\frac{1}{18}+C=-8\implies C=-\frac{143}{18}$$
And so the solution satisfying the given IVP is:
$$y(x)=-\frac{1}{18x^4}-\frac{143}{18}x^2=-\frac{143x^6+1}{18x^4}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
