A Hard-Core Boson Model in K space
partyday
TL;DR Summary
I am asking about how to convert the Hard-Core boson Model into K-space.
Hello,
I am interested in the following model:
H = \sum_{<i,j>} -t (c_i c_j^{\dagger} + \text{H.C.}) + U (n_i n_j) + \sum_{<<i,j>>} -t' (c_i c_j^{\dagger} + \text{H.C.}) + U' (n_i n_j)
where \( <i,j> \) indicates nearest neighbors, and \( <<i,j>> \) indicates next-nearest neighbors interactions. \( c_i \) and its conjugate are the annihilation and creation operators, respectively.
The hardcore boson model also establishes that
c_i^{\dagger} c_i^{\dagger} = c_i c_i = 0
when acting on a state, so a particle may only inhabit one site at a time.
If we establish that there are \( L \) sites on a periodic lattice (so \( i+L = i \)), then this Hamiltonian can be rewritten:
H = \sum_{i} -t (c_i c_{i+1}^{\dagger} + \text{H.C.}) + U (n_i n_{i+1}) - t' (c_i c_{i+2}^{\dagger} + \text{H.C.}) + U' (n_i n_{i+2})
This Hamiltonian can be block diagonalized into different sectors of momenta, \( K \). For this reason, I'd like to express this Hamiltonian in terms of momentum states.
Using
\omega = \frac{2 \pi}{L}
and
c_j = \sum_{k} c_k e^{-i \omega k j}
we can derive the following two expressions:
\sum_{j} n_j n_{j+x} = \sum_{j} \sum_{k, k', q, q'} c^{\dagger}_{k'} c^{\dagger}_{q'} c_k c_q e^{i (k'+q'-k-q) j \omega} e^{i (q'-q) x \omega}
which simplifies to
\sum_{j} n_j n_{j+x} = \sum_{k, k', q, q'} \delta(k'+q'-k-q) e^{i (q'-q) x \omega} c^{\dagger}_{k'} c^{\dagger}_{q'} c_k c_q
The diagonal elements are more simple:
\sum_j c^{\dagger}_{j+x} c_j + \text{H.C.} = \sum_k 2 \cos(k \omega x) n_k
Now these terms can be substituted into the Hamiltonian for \( x = 1 \), \( x = 2 \).
My questions are as follows:
1. Was this derivation correct?
2. In momentum space, does
c_k^{\dagger} c_k^{\dagger} = c_k c_k = 0
hold?
3. Should values of $$ K $$ vary from $$( (-L/2, -L/2+1, \ldots, L/2-1, L/2) $$ or from $$ (0, 1, \ldots, L-1) $$? Is there a difference?
4. I'm interested in this model when there is an appreciable amount of filling. Say $$N = L/3 $$. I have been attempting to program a script that computes the matrix elements of this Hamiltonian for an arbitrary $$L $$ and $$ N $$. I first find all available basis states in momentum space, then I separate them into total momentum sectors. Say three particles with momenta $$ (1, 2, 5) $$ are in the same sector as $$ (1, 3, 4) $$ as they sum to the same number $$ K = 8$$. The action of the $$ n_j n_{j+x}$$ term in momentum space is to couple these states together (as well as any other states that are reachable via a momentum-conserving interaction). But let's say $$ L = 6 $$, then these two states are of $$K \% L $$, correct? It would be correct to say that these are of momentum $$ K = 2 $$, because it must lie in the first Brillouin zone?
5. Are these $$ K $$ sectors block diagonalizable themselves? Some papers I've seen make reference to parity blocks, but none define what this would look like. I can see, for instance, very clearly that $$ (1, 3, 4)$$ and $$(1, 2, 5)$$ are in the same block of total momentum $ K $, but how can I see if they are in the same parity block?
Any help or guidance would be greatly appreciated. I have tried a lot of academic papers and Google-searching but I have not been able to feel assured in my understanding yet.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
