Harmonic Oscillator in 3D, different values on x, y and z
In summary, the conversation discusses the energy levels and degeneracy of a harmonic oscillator in 3D, with a potential function V(x,y,z) = 1/2mw^2(x^2+4y^2+z^2). It is shown that in a more general case, the energy level can be calculated using the formula En = hw(n+3/2), and that the first excited state in this case is E100 = E001 = 3hw, with a degeneracy of 2. The conversation also clarifies that w2 = 2w, not 4w, due to the definition of the potential function.
Ofinns
Hi,
For a harmonic oscillator in 3D the energy level becomes En = hw(n+3/2) (Note: h = h_bar and n = nx+ny+nz) If I then want the 1st excited state it could be (1,0,0), (0,1,0) and (0,0,1) for x, y and z.
But what happens if for example y has a different value from the beginning? Like this: V(x,y,z) = 1/2mw2(x2+4y2+z2) and for this decide the energy level AND degeneracy for the 1st excited state. I can only find simple examples when x, y and z are equal and 1.
Best regards
In such a more general case you have
$$E_{n_1n_2n_3}=\hbar \omega_1 \left( n_1+\frac{1}{2} \right) + \hbar \omega_2 \left( n_2+\frac{1}{2} \right) + \hbar \omega_3 \left( n_3+\frac{1}{2} \right)$$
Can you elaborate on that? Is 4y2 just n2 here? And in that case you will get three different energy values:
E100 = 3hw1/2
E010 =6hw2
E001 =3hw3/2
Which one is the 1st excited state? Is it E010?
No, it enters in as the frequency.
In your case
$$\omega_1=w$$
$$\omega_2=2w$$
$$\omega_3=w$$
Therefore
$$E_{000}=2\hbar w$$
$$E_{100}=E_{001}=3\hbar w$$
$$E_{010}=4\hbar w$$
Hence the first excited states are ##E_{100}=E_{001}##.
Thank you, now I understand that part.
What will the degeneracy become for the 1st excited state then? Can I use the same formula gn = 1/2(n+1)(n+2) for this case?
It's 2.
No.
Demystifier said:
It's 2.
Why is it 2? What formula do you use to calculate that? (Sorry for all the questions..)
It follows from the last line of post #5. There you see that there are 2 "first excited states" with equal energies. Hence the degeneracy of first excited state is 2.
Oh! Thank you so much for the answers, this has been bugging me for a while now.
Best regards
Demystifier said:
In your case
$$\omega_1=w$$
$$\omega_2=2w$$
$$\omega_3=w$$
Late questions.. but why is w2=2w and not 4w?
Because, by definition,
$$V(x)=\frac{1}{2}m\omega^2 x^2$$
Right, of course. Thank you.
Related to Harmonic Oscillator in 3D, different values on x, y and z
1. What is a harmonic oscillator in 3D?
A harmonic oscillator in 3D is a physical system where the motion of a particle or object follows a specific pattern, known as a harmonic motion, in three dimensions. This means that the particle or object moves back and forth repeatedly along a specific path, with its displacement from the center being proportional to the force applied.
2. How is a harmonic oscillator in 3D different from a 1D or 2D harmonic oscillator?
A 1D harmonic oscillator only has one dimension of motion, while a 2D harmonic oscillator has two dimensions of motion. In a 3D harmonic oscillator, the particle or object can move in three different directions, making it more complex to analyze and understand. Additionally, the equations used to describe a 3D harmonic oscillator are more complex compared to those used for 1D or 2D oscillators.
3. What are the different values on x, y, and z in a 3D harmonic oscillator?
Each of the three dimensions in a 3D harmonic oscillator has a different value, denoted as x, y, and z. These values represent the displacement of the particle or object in each respective direction. In a 3D harmonic oscillator, the values of x, y, and z may have different magnitudes and directions, resulting in a more complex motion compared to a 1D or 2D oscillator.
4. How do the different values on x, y, and z affect the motion of a 3D harmonic oscillator?
The values on x, y, and z determine the direction and magnitude of the displacement of the particle or object at any given time. The motion of a 3D harmonic oscillator is a combination of these three displacements, resulting in a complex and unique motion. The values on x, y, and z also affect the period, amplitude, and frequency of the harmonic motion.
5. What are the real-life applications of a 3D harmonic oscillator?
3D harmonic oscillators can be found in various physical systems, such as molecules, atoms, and even galaxies. In molecular systems, 3D harmonic oscillators are used to model the vibrations of molecules, which play a crucial role in chemical reactions. In atomic systems, 3D harmonic oscillators can model the vibrations of electrons, which are essential for understanding atomic structure. In cosmology, 3D harmonic oscillators can describe the oscillations of galaxies and the expansion of the universe.
