Harmonic Oscillator with Friction
In summary, the conversation discusses how to solve a harmonic oscillator problem with friction. The equation F = -kx - b is suggested as a starting point, with the force of friction being a constant. However, it is later clarified that friction is a function of velocity and is not constant. The equation mx''= -kx - b is proposed as the correct form for the harmonic oscillator with friction. The conversation then delves into solving the differential equation by using Newton's second law and guessing a solution. The process for finding x(t) is also explained, involving substituting functions and finding the general form of the solution. The conversation also mentions J.P. den Hartog's work on this problem and brings up the possibility
Fascheue
I don’t have a specific problem to solve, and I’m not sure I would be able to correctly find one, but I need to know how to solve a harmonic Oscilator problem with Friction. I believe I should be starting with F = -kx -Ff, and that I will be given some information about the frictional force. I’m guessing the frictional force will just be constant. If that’s the case I believe the force could just be written as F = -kx - b, where b is some constant? Can anybody confirm that this is correct and help me solve the differential equation
F = -kx - b
[/B]
mx’’= -kx - b
This is where I have to solve the differential equation that I’m unsure how to solve. I’m not quite sure where to start, but I believe it might have something to do with guessing a solution.
Why do you think the force of friction is a constant? When it's sitting at the equilibrium position, what should the net force be? What does your equation say it is?
Likes Fascheue
The friction force can't be a constant, it's some function of velocity ##x'##, and in the simplest case it's a linear function of velocity as in
##mx''(t) = -kx(t) - bx'(t)##
Likes Fascheue
I’m imagining a mass attached to a spring on a surface with friction. I thought friction would be constant because Ff = uFn where u is constant and Fn wouldn’t change. I guess that only gives the value for maximum possible friction though, I see that it’s wrong.
If friction is -bx’(t) (in a simple case) as hilbert2 said, then I’m a bit confused. In the case of the mass on a spring, I don’t believe friction can exceed uFn. If that is the case, shouldn’t the force of friction no longer be dependent on x’(t) at some point when the mass is moving quickly enough?
What does uFn mean? Linear models usually work only under some limiting conditions, the air resistance on a cannonball or a jet plane is likely to be a more complicated function of velocity than a linear one.
Likes Fascheue
The coefficient of friction multiplied by the normal force. Wouldn’t that equation describe the maximum frictional force possible on a mass attached to a spring on a frictional surface?
Yes, that's usually true. I was interpreting friction as air resistance here, hence the confusion.
If you assume that the spring is exerting enough force on the mass to make it move in the first place, and that the motion is not too fast, you can probably find a constant ##b## that is relatively well consistent with the friction force being of the form ##bx'(t)##.
Likes Fascheue
Alright that makes sense. If F = -kx -bx’(t) is the equation for the simplest harmonic oscillator with friction, that’s probably what I’ll need to be able to work with. What exactly is the process for find x(t) from that equation?
I think I should probably use Newton’s second law.
x’’(t) = (-kx -bx’(t))/m
My knowledge of differential equations is very limited, but it looks like a second order homogenous differential equation, and I think that means that I’m supposed to guess the answer somehow.
You can try to read this:
https://ocw.mit.edu/courses/mathematics/18-03sc-differential-equations-fall-2011/unit-ii-second-order-constant-coefficient-linear-equations/modes-and-the-characteristic-equation/MIT18_03SCF11_s12_2btext.pdf
Basically, the idea is to substitute functions of the type ##x(t)=Ae^{Bt}## or ##x(t)=Ate^{Bt}##, where ##B## can be a complex number, in the differential equation, and find the general form of the solution (in the end, complex-valued solutions are ignored by taking the real part of ##x(t)##).
As long as the mass is moving in one direction, a Coulomb friction force is constant. It is when it reverse direction that the difficulties begin, but this particular problem was solved and published many years ago by J.P. den Hartog.
F = -kx - bx’mx’’ = -kx - bx’x’’ +kx/m + bx’/m = 0r^2 + b/mr + k/m = 0r = (-b/m +/- sqrt(b^2/m^2 -4k/m)/2x(t) = Ae^((-b/m + sqrt(b^2/m^2 -4k/m)t/2) + Be^((-b/m - sqrt(b^2/m^2 -4k/m)t/2)Does it seem like I did this correctly? Also, I just found some information about oscillators with friction in my lecture notes. I have the same equation that I used above except instead of b I have mΓ. Would mΓ just be a specific case of b?
Who knows what m*capGamma means? This is not a common notation, so it is hard to interpret.
I believe it represents the mass multiplied by some coefficient of friction. I guess I’m just a bit curious why mass is involved in that equation but not the one mentioned in this thread.
Related to Harmonic Oscillator with Friction
1. What is a harmonic oscillator with friction?
A harmonic oscillator with friction is a physical system in which a particle or object oscillates back and forth around an equilibrium position, while experiencing a damping force due to friction. This type of oscillator is commonly used to model systems such as pendulums, springs, and electrical circuits.
2. How does friction affect the motion of a harmonic oscillator?
Friction acts as a damping force on the oscillator, causing it to lose energy and decrease in amplitude over time. This means that the oscillations become smaller and eventually come to a stop, reaching the equilibrium position.
3. What is the equation for a harmonic oscillator with friction?
The equation of motion for a harmonic oscillator with friction is given by:
m(d^2x/dt^2) + c(dx/dt) + kx = 0
where m is the mass of the object, c is the damping coefficient, k is the spring constant, and x is the displacement from equilibrium.
4. How does the damping coefficient affect the motion of a harmonic oscillator?
The damping coefficient determines the rate at which the oscillator loses energy due to friction. A higher damping coefficient will result in faster energy dissipation and a quicker decrease in amplitude, while a lower damping coefficient will result in slower energy dissipation and a longer period of oscillation.
5. Can a harmonic oscillator with friction exhibit simple harmonic motion?
No, a harmonic oscillator with friction cannot exhibit simple harmonic motion because the damping force causes the amplitude to decrease over time. Simple harmonic motion requires the amplitude to remain constant throughout the motion.
