Harmonic sum and a stack of blocks (check my work)
In summary, the conversation discusses the value of n required for the sum of a harmonic series to be greater than 100, the possibility of forming a "wing" of a specific length using identical blocks, and the use of the floor and ceiling functions in solving the problem. The solution involves considering the center of mass and the maximum length that can be achieved by n blocks.
analyzer
Let S_n = 1 + (1/2) + (1/3) + (1/4) + ... + (1/n)
a) What value of n is required such that S_n > 100?
b) Show how one can form a stack of identical blocks (one per row), each 1 ft long, so as to form a "wing" (I don't know what the correct word in English is, but I believe you understand) that is 50 ft long. Is it possible to form a "wing" 50 million ft long?
Taken from Algebra and Trigonometry with Analytic Geometry, by Varberg and Fleming (Spanish version.)
In calculus, it is proved that
ln n < 1 + (1/2) + (1/3) + (1/4) + ... + (1/n) < 1+ ln n
a) The first thing that I have done is plug ln n = 100. Solving for n one gets it equals e^100. But n must be an integer, so I have two options.
Let f(x) denote the greatest integer less than or equal to x, and g(x) denote the smallest integer greater than or equal to x.
If I plug n = f(e^100), I wouldn't know for sure whether S_n > 100. On the other hand, it is certain that n = g(e^100) satisfies the condition.
b) If there is an integer n such that S_n - 1 = 50, we're done: we can put the second block in the stack so that it sticks out 1/n ft in relation to the first, the third block sticking out 1/(n-1) ft in relation to the second, and so on until we put the top block, which will stick out 1/2 ft in relation to the one that's below.
If such an integer n doesn't exist, we plug n = g(e^51) (remember the function I defined in part (a):)
(ln g(e^51)) - 1 < S_n - 1 < ln g(e^51)
so we can multiply the expression at the center by a number that is less than one in order to get that expression to be equal to 50; that is, we multiply 1/2 , 1/3 , 1/4 , ... , 1/n by that number so as to keep the stack of blocks "harmonic".
The answer to the second question in part (b) is yes, we can. The procedure is similar to the one described for the 50 ft "wing." The number n in this case will be much bigger.
Hi. Gauss invented function expressing maximum integer that does not exceed x. It may help you.
Hi, sweet springs. Thank you for replying. Isn't f(x), which I have defined above (of course, I'm not the first person to have used such function), the function you are talking about?
If I plug n = f(e^100), S_n is not going to be necessarily greater than 100. We don't know what value it is (unless we compute it), but it may be below 100 given that ln x is an increasing function (e^100 is greater than or equal to f(e^100))
Honestly, I didn't know their names. On the other hand, I have searched for a solution to the problem on other resources. I see that I have to take into account the center of mass, a concept I am not familiar with (I'm ignorant of physics).
One of the resources (Wolfram MathWorld) states that the maximum length that can be achieved by n blocks is (1/2)*S_n.
FAQ: Harmonic sum and a stack of blocks (check my work)
1. What is the Harmonic sum?
The Harmonic sum is the sum of a series of numbers in which each term is the reciprocal of a positive integer. It is also known as the harmonic series.
2. How is the Harmonic sum calculated?
The Harmonic sum can be calculated using the formula: Hn = 1 + 1/2 + 1/3 + ... + 1/n, where n is the number of terms in the series.
3. What is the significance of Harmonic sum in mathematics?
The Harmonic sum has many applications in mathematics, such as in number theory, calculus, and probability. It is also commonly used in problems involving infinite series and convergence.
4. How does a stack of blocks relate to the Harmonic sum?
A stack of blocks can be used as a visual representation of the Harmonic sum, where each block represents a term in the series. The height of the stack increases as more blocks are added, similar to how the Harmonic sum increases as more terms are added.
5. How can the Harmonic sum be used in real-world scenarios?
The Harmonic sum can be used to solve various real-world problems, such as calculating the average speed of a moving object, determining the likelihood of certain outcomes in a game of chance, and analyzing the efficiency of algorithms. It is also commonly used in physics and engineering to model natural phenomena.
