Harmonic waves - Fundamental voltages
In summary: That's why the error in the formula you quoted is always negative, even when the "actual" value is positive.In summary, an ac voltage, comprises of a fundamental voltage of 100 Vrms at a frequency of 120 Hz, a 3rd harmonic which is 20% of the fundamental, a 5th harmonic which is 10% of the fundamental and at a phase angle of 1.2 radians lagging.
Jason-Li
119
An ac voltage, comprises of a fundamental voltage of 100 Vrms at a frequency of 120 Hz, a 3rd harmonic which is 20% of the fundamental, a
(i) Write down an expression for the voltage waveform.
(ii) Sketch the waveforms of the harmonic components.
(iii) Determine the voltage at 20 ms.
(iv) Given an ideal V = 100 V rms, what is the percentage error at 20 ms?
(i)
A 1Hz = 2π rads^-1 so:
Fundamental = 120Hz = 240π, 3rd = 360Hz = 720ω & 5th = 600Hz = 1200π lagging by 1.2 radians
Vrms = 100V so Vmax or A = 100 * √2 = 141.421V
3rd = 0.2 * 141.421 = 28.2842V
5th = 0.1 * 141.421 = 14.1421V
so written as one expression:
141.421sin(240πt)+28.284*sin(720πt)+14.1421*sin(1200πt-1.2)
(ii) Attached at bottom
(iii) where t = 20ms or 0.02s
141.421sin(240π*0.02)+28.284*sin(720π*0.02)+14.1421*sin(1200*π*0.02-1.2)
=96.844V
(iv) Ideal Vrms = 100V, V at 20ms = 96.844V
As 96.844V was found from 'max' value,
Percentage error = (1-(V@20ms/V)*100
= (1-(96.844/141.421)*100
=(1-0.6848)*100
= 31.5%
Can anyone confirm if I am along the right lines? just seems like an excessive percentage error and unsure if I should use max values or RMS values for (iv)
You can use either peak or rms values when discussing percentage error (as long as you're consistent) as rms is essentially a scaling factor.
For part (iv) you need to find the voltages at 20 ms for the ideal waveform and the the actual waveform. The ideal waveform will not be 100 Vrms at t = 20 ms. 100 Vrms is its maximum value which occurs at other times along its waveform. So compute the values for the ideal and actual waveforms for t = 20 ms, then do your %error calculation.
Ahh I see, so does the following look more suitable:
For instantaneous ideal V at 0.02s:
V=141.421sin(240π*0.02) = 83.125V
Percentage error = (1- 83.125/ 96.844 ) * 100 = 14.166%
Also do the other parts look okay? More specifically the sin wave drawing? Thanks as always!
I think you may have swapped the "actual" and "expected" values there. Percent error (pe) is given by
##pe = \frac{expected - actual}{expected} \times 100##
##pe = \left(1 - \frac{actual}{expected}\right) \times 100##
With a cursory look your plots look okay.
Likes scottdave, jim hardy and Jason-Li
Ah yeah, I wrote them the other way round so that the percentage error would be positive If I write it properly as you state:
Percentage error = ((96.844-83.125)/ 96.844 )) * 100 = 14.166%
or
My main quandary is that I've seen other workings through this such as this:
Ideal = 100Vrms
Error at 20ms = 100V - 96.844 = 3.156, hence 3.155%
I assume this is incorrect as they have used an instantaneous and an RMS value together?
Likes scottdave
Hmm. I think that the expected value would be the 83.125 V (from the fundamental voltage waveform), and the actual value 96.844 V. The fundamental represents the expected value, while the 96.844 V is the actual value with the harmonics taken into account.
Likes Jason-Li
Ideal = 100Vrms
The instantaneous versus peak argument doesn't matter here. It is clearly incorrect as they have not taken into account the time. A 100 V (peak or rms) sinewave at some frequency will not be 100 V at 20 ms from t = 0.
Makes sense,
Percentage error = ((83.125-96.844)/83.125 )) = -0.165 so expressed as a percentage = -16.5%.
You're post seems to make sense but when I read other physics papers I found this (below) - being experimental as actual and theoretical as expected? I have found quite a few different sources that have actual and expected different ways around, just unsure which way I should use them as it returns different values.
The difference between the formula that you quoted above and the one I presented in post #4 is that the positions of the "experimental" and "theoretical" values are swapped in the numerator. That will change only the sign of the result, not its magnitude. The interpretation of what a % error is meant to express (in terms of its sign) sometimes requires a bit of thought involving the context of the measurement. The formula that you quoted is fine.
However, the important thing to note is that the denominator should always be the "theoretical" (or "expected") value.
FAQ: Harmonic waves - Fundamental voltages
1. What are harmonic waves?
Harmonic waves are periodic waves that are characterized by their fundamental frequency and its multiples (harmonics). These waves have a sinusoidal shape and can be found in various natural phenomena such as sound waves, light waves, and electromagnetic waves.
2. How are harmonic waves produced?
Harmonic waves are produced when a source vibrates at a specific frequency, creating a disturbance in the surrounding medium. The resulting wave consists of the fundamental frequency and its harmonics, which are determined by the properties of the source and the medium.
3. What is the fundamental voltage of a harmonic wave?
The fundamental voltage of a harmonic wave refers to the lowest frequency component of the wave. It is the voltage that has the same frequency as the source that produced the wave. All other voltages in the wave are multiples of the fundamental voltage.
4. How do harmonic waves affect electrical systems?
Harmonic waves can cause disturbances in electrical systems, especially in power systems. These waves can result in voltage and current distortions, which can lead to equipment malfunction and power quality issues. Proper management and mitigation of harmonic waves are essential in maintaining a stable and efficient electrical system.
5. Can harmonic waves be eliminated?
While it is not possible to completely eliminate harmonic waves, their effects can be mitigated through various techniques such as using harmonic filters, proper system design, and regular maintenance. It is crucial to identify and address the sources of harmonic waves in an electrical system to minimize their impact on equipment and power quality.
10K
