Harmonics on a Stretched Spring
  • Thread starter Thread starter BuBbLeS01
    Harmonics Spring
The discussion focuses on solving a physics problem involving a string fixed at both ends, with given mass density and tension. The fundamental frequency is calculated using the formula FF = 1/2L * sqrt(T/μ), leading to an answer of 371 Hz for part A, while part B identifies the resonance frequency of 742 Hz as the second harmonic. The user struggles to determine the length of the string due to a lack of velocity information. They consider using L = V/2f but need assistance in finding the wave velocity. The thread highlights the challenges in applying wave equations to find string properties.
BuBbLeS01
A. A string with a mass density μ = 4.10×10-3 kg/m is under a tension of F = 327 N and is fixed at both ends. One of its resonance frequencies is 742.0 Hz. The next higher resonance frequency is 1113.0 Hz. What is the fundamental frequency of this string?
B. Which harmonic does the resonance frequency at 742.0 Hz correspond to? (i.e. what is n at this frequency?)C. What is the length of the string?
So for A. I wanted to use the equation...
FF - fundamental frequency
Where...
μ = 4.10×10-3 kg/m
T = 327N
but I don't know what L is?
The standing waves in a string forms with integral multiples of half of the wavelength of the generated wave in the string
L = n\frac{\lambda}{2}
and for the speed in the wave we can substitute
\lambda f = \alpha
where
\alpha = \sqrt{\frac{T}{\mu}}
giving
\lambda = \frac{1}{f} \alpha
lets say that the one standing wave forms such that
L = \frac{n\lambda _1}{2}
and the next harmonic such that
L = \frac{(n + 1) \lambda _2}{2}
equating gives
\frac{n\lambda _1}{2} = \frac{(n + 1) \lambda _2}{2}
therefore
n\lambda _1 = (n + 1) \lambda _2
substituting now for \lambda gives
\frac{n \alpha}{f_1} = \frac{(n+1) \alpha}{f_2}
Wow...okay so is that all just for the first part of the question??
Ok I got the answer for A and B (A was 371Hz and B was 2)...but I can not figure out how to determine the length of the string. I thought the equation to use was...
L = V/2f
but I don't have the velocity...
Can someone please help me with this.
Thank you
