Harnessing energy from piezioelectric roadways
  • Thread starter fireseed
  • Tags
    Energy
In summary: But the energy used to deform the piezos has to come from somewhere. It's not going to just magically appear. So you might save some wear on the roadway, but you are going to make the cars work harder to push the same distance.In summary, the conversation discusses the potential for harvesting energy from piezoelectric crystals that are buried in roadways. It is mentioned that a 1 cm cube of quartz can produce a voltage of 12,500 V with 2 kN of force applied. The participants also discuss the average pressure and contact area of a car's wheel on the road, as well as the concept of time and current in relation to harvesting energy from piezoelectricity. However, it is noted that the
fireseed
I am trying to determine how much energy can be, in ideal circumstances, harvested from piezoelectric crystals that draw pressure from being buried in roadways.
To start, we found a basic fact on Wikipedia;
http://en.wikipedia.org/wiki/Piezoelectric
"...a 1 cm cube of quartz with 2 kN (500 lbf) of correctly applied force can produce a voltage of 12,500 V."
Using what means and understanding we possess, we determined so far that;
-that the average wheel on a car would be roughly 5 kN
-that .20m of a wheel touches the ground on average with an area of 0.034m^2
Now based on my understanding of piezoelectricity, I am not sure as to whether time would have to be factored in as well or not. So basically if we could come up with some kind of a unit measurement/equation to determine how much voltage a 1 cm cube of quartz would put off with the force of the average vehicle going at an average speed, we could then extrapolate that to conclude exactly how much power could be generated from a roadway of any given length and thus the overall energy potential of piezoelectricity as a whole.
Overall, we'll have one more sound fact to give hope to the world that could be.
But I seem to have taken this equation as far as I can on my own at the time, so I need someone's help.
Anything at all would be greatly appreciated.
Voltage alone doesn't really tell you anything useful about the energy available - you'd need a current. And note, conservation of energy applies: any energy generated by the crystals has to come from the car engine and not much of a car's energy is lost as rolling resistance on a road.
So then is there any direction you could suggest that I look into further my progress with this question?
From talking to people who use the piezeo sensors for speed/traffic measurements - very little signal is generated because of the road surface material over the top of the sensors.
They have to do some pretty complex signal processing to even detect a car.
Well, I guess you could pick an arbitrary deflection (it's up to you to design it, right?) and calculate based on that. Ie, try these numbers:
A car weighs 5000N
You design your device to deflect 1m, like a spring
The contact patch is 20 cm long and the car is moving at 10 m/sec (so the contact area is changed 50 times a second)
You don't get something for nothing. I am guessing that the energy you get would be offset by losses elsewhere like loss of gas mileage in all the vehicles that travel the road. So if you expect to harvest free energy I doubt it will work.
The cars are already deforming the road surface without any reclamation of that energy. It would be no different than trying to generate energy from the sound the tires produce: they're going to be making noise whether you do something with that noise or not. The real problem is whether the cost of engineering and installing any such system is paid for by the energy produced.
What about something even simpler like specially designed 1/2 inch air hoses, that when ran over, take the mechanical pressure applied, and force air out, and transfer that into electric energy? Wouldn't that be simple enough to work?
The roads have to handle relatively heavy loads like tractor trailers, they aren't deforming much with a car or it would really sag under a truck. And if they are already sagging then they would have to sag an additional amount for the piezo wouldn't they?
That would definitely kill gas mileage, no net gain.
Well, this is not quite right as you would just exchange some part of the road for piezos, so you just switch from deforming concrete, where most energy used for the deformation will finally end up as a slight increase in temperature towards deforming piezos, where you can harvest a little bit of the energy. Nevertheless I think the amount of energy you can get is far too small to make the use of expensive piezos sensible. Also the change of temperature between summer and winter should be a great problem at most locations.
However piezos have been used to harvest energy in other locations. Although I think this is more or less a marketing gag, there is a club in the netherlands, which uses a dancefloor with piezos: http://www.nytimes.com/2008/10/24/w...html?_r=3&pagewanted=2&partner=rssnyt&emc=rss
Yes. The amount of deformation, the actual deflection from the previous dimension required to produce voltage, is very slight but requires a lot of pressure, proportionately, to accomplish. Crystals are very hard. You can scratch glass with a quartz crystal.
A car weighs 5000N
Do I understand this correctly -- a 1 m deflection? Wouldn't a cm be more reasonable? The car has to push the device down by this distance, and then "climb" up out of the depression in the road that has been created. As a driver, I doubt I'm willing to tolerate more than a cm or 2.
Of course, the car must consume more gas to climb out of the dip in the road, which I guess is the whole point. If you really want to burn gasoline/petrol to generate electricity, you might as well buy a generator.
I'd be amazed if the deflection required anything on the order of a milimeter much less a centimeter.
Related to Harnessing energy from piezioelectric roadways
1. How does harnessing energy from piezoelectric roadways work?
Piezoelectric roadways use special materials that can generate electricity when pressure is applied. As vehicles drive over the road, the pressure from their weight causes the piezoelectric material to deform, producing an electric charge. This charge is then captured and stored for later use.
2. What are the benefits of using piezoelectric roadways for energy generation?
Piezoelectric roadways have several advantages. They can generate electricity without any additional infrastructure or equipment, as they are integrated into existing roads. They also have a low environmental impact, as they do not produce any emissions or require any fuel. Additionally, they can potentially reduce the strain on the power grid by providing local, renewable energy.
3. How much energy can be harnessed from piezoelectric roadways?
The amount of energy generated from piezoelectric roadways can vary depending on factors such as traffic volume, vehicle weight, and road conditions. However, studies have shown that a single lane of piezoelectric road can generate enough energy to power street lights or traffic signals.
4. Can piezoelectric roadways be used in all types of weather?
Yes, piezoelectric roadways can function in all types of weather. They are designed to withstand heavy loads and extreme temperatures, making them suitable for use in various climates.
5. Are there any downsides to using piezoelectric roadways for energy generation?
One potential downside is the cost of installing and maintaining piezoelectric roadways. While they may generate renewable energy, the initial investment may be high. Additionally, the technology is still being developed and may not be as efficient as other renewable energy sources. There may also be concerns about the impact on road durability and the potential for noise pollution from the vibrations caused by passing vehicles.
14K
  • Mechanical Engineering
  • Electromagnetism
