Hartree Fock v.s. Configuration Interaction
In summary, the conversation discusses the use of approximation methods, specifically the Hartree Fock (HF) method and Configuration Interaction (CI) method, in Quantum Mechanics for describing multi fermionic systems. The HF method uses a Slater determinant of spin-orbitals to approximate the system wave function and can only find the ground state wave function. On the other hand, the CI method constructs the electronic wave function from a linear combination of several Slater determinants, allowing for the inclusion of excited states. However, finding excited states is an extension of the basic method and the ground state is usually the most important for chemistry. In some cases, it is necessary to use multiple Slater determinants to represent a state, known as multiconfiguration SCF
Jan Hidding
Hey everyone,
For my studies I have to read a part about approximation methods in Quantum Mechanics. Unfortunately I'm having difficulties understanding some concepts.
If I'm correct, for describing a multi fermionic system of n electrons, the Hartree Fock (HF) method uses a Slater determinant consisting of spin-orbitals to approximate the system wave function.
$$ \psi=(n!)^{-1/2} det|\phi_a(1) \phi_b(2) ...\phi_z(n)| $$
The Slater determinant is used to obey anti symmetry and thus the Pauli Exclusion Principle. Then the Hartree Fock equation is used to obtain the spin-orbitals. By means of a Self Consisting Field approach the spin-orbitals are then optimized until the wave functions do not change anymore. The HF ground state is then found by constructing a Slater Determinant of the n energetically lowest orbitals.
For the Configuration Interaction (CI) method the electronic wave function is constructed of a linear combination of several Slater determinants. These determinants correspond to different singly, doubly, triply, etc. excited states.
Does this mean that you do not take into account any excited states for constructing your electronic wave function using the Hartree Fock method and that you are only able to find the ground state wave function?
I really have a hard time understanding any of this so if you would be able to explain it simply it is much appreciated :)
Thanks in advance!
Usually yes; the electronic ground state is the state most important for chemistry. Finding excited states is already an extension of the basic method.
There are some excited states which can be described by a single Slater determinant. These are often states of lowest energy of a different symmetry than that of the ground state. But sometimes it is also symmetry which demands looking for a solution consisting of more than one Slater determinant. It is then often possible to represent the state by only a hand full of Slater determinants and optimize the orbitals. This is called multiconfiguration SCF.
Related to Hartree Fock v.s. Configuration Interaction
1. What is the difference between Hartree Fock and Configuration Interaction?
Hartree Fock is a method used in quantum chemistry to approximate the electronic structure of a multi-electron atom or molecule. It assumes that the electrons move independently of each other and do not interact. Configuration Interaction, on the other hand, takes into account the interactions between electrons and allows for a more accurate calculation of the electronic structure.
2. Which method is more accurate: Hartree Fock or Configuration Interaction?
Configuration Interaction is generally considered to be more accurate than Hartree Fock, as it takes into account electron-electron interactions that are not considered in Hartree Fock. However, the accuracy of both methods depends on the system being studied and the basis set used.
3. Is it necessary to use both Hartree Fock and Configuration Interaction in calculations?
No, it is not necessary to use both methods. In fact, many quantum chemistry calculations only use one of these methods. The choice of which method to use depends on the level of accuracy needed for the specific system being studied.
4. Can Hartree Fock and Configuration Interaction be combined?
Yes, it is possible to combine Hartree Fock and Configuration Interaction to improve the accuracy of electronic structure calculations. This is known as the Hartree Fock-Configuration Interaction (HF-CI) method.
5. Which method is more computationally efficient: Hartree Fock or Configuration Interaction?
Hartree Fock is generally more computationally efficient than Configuration Interaction, as it does not take into account electron-electron interactions. However, as computer technology advances, Configuration Interaction calculations are becoming more feasible for larger systems.
  • Quantum Physics
  • Quantum Physics
  • Atomic and Condensed Matter
  • Quantum Physics
