Harvard minimum accepted SAT/ACT scores
In summary: There is no one way to do things and the best way to prepare for the admissions process is to explore all your options and talk to as many people as you can.
Kutt
237
It is a well-known fact that Harvard university (arguably the most prestigious college in the United States) only accepts the very top highest-performing high school graduates in the country.
What is Harvard's minimum accepted high school GPA, number of AP credits, and SAT/ACT scores?
I believe that Harvard has the most stringent entry requirements out of any college in the US. Only about 6% of applicants are accepted every year.
Off-topic, but has anyone here gone to Harvard or at least knows someone who has?
Princeton is worse.
Are you from the US? If so, your guidance counselor(s) have obviously done a horrible job informing you of how the college admissions process works I'm afraid. If there was a strict minimum required SAT/ACT, GPA, and number of AP credits don't you think you would be able to find it on their website? You can't just poof up some magic set of numbers that will divide the line between getting in and not getting in unfortunately. Harvard is an all purpose university not Caltech or MIT. Rest assured you can easily find data online on the average SAT scores and gpa of people who are accepted. That is as good as it gets. A great GPA and a 2300+ SAT score won't guarantee you a spot; you need more than just that and the other things are not nearly as quantifiable (Extracurriculars etc).
I got into Harvard for college and I didn't have perfect SAT reasoning scores (though I did have two 800s for my subject tests, but that's not particularly difficult). Most people I know who have been admitted to Harvard have had SAT scores above 2250, but I'm sure there are successful applicants with lower grades. I had a perfect high school GPA and graduated as the valedictorian of a prestigious high school that had never sent students to an Ivy League.
I turned down Harvard for a peer school, so I can't comment on what attending Harvard is actually like.
Kutt said:
SAT scores below 2300 are not accepted?
No, what makes you think that?
I know several people who scored below 2300 on the SAT who were accepted.
The Ivy League and other top schools in the U.S. practice holistic admissions. This means they consider a wide number of factors beyond GPA and test scores like recommendations, extracurricular involvement, and your essays. For this reason, you are not guaranteed to get in with perfect tests scores and grades. Someone with a 2250 and a slightly lower GPA might fare a lot better than someone with a 4.0 and a 2400 if they have really outstanding essays. Also, schools take into account the context of your GPA within your school as well as course rigor. If you go to school where a 3.7 puts you in the top of the class, it might be seen in the same light as a 4.0 in a school with grade inflation.
Admissions in the U.S. are highly unpredictable. You might get into a school like Columbia but not Cornell or Yale but not Stanford.
Related to Harvard minimum accepted SAT/ACT scores
What is the minimum SAT score accepted by Harvard?
The minimum SAT score accepted by Harvard is 1470 out of 1600. However, this score alone does not guarantee admission as Harvard also takes into consideration other factors such as extracurricular activities, essays, and letters of recommendation.
What is the minimum ACT score accepted by Harvard?
The minimum ACT score accepted by Harvard is 33 out of 36. Similar to the SAT, this score is not the only factor considered in the admissions process.
Do I need to score higher than the minimum accepted scores to get into Harvard?
Yes, you should aim to score higher than the minimum accepted scores in order to increase your chances of being admitted to Harvard. The average SAT score for admitted students at Harvard is 1520 and the average ACT score is 34.
Are there any exceptions to the minimum accepted scores for Harvard?
While a high SAT or ACT score is typically expected for admission to Harvard, the admissions committee takes a holistic approach and considers each applicant individually. If you have a strong overall application, you may still be considered even if your test scores are slightly below the minimum accepted scores.
Can I submit both my SAT and ACT scores to Harvard?
Yes, Harvard allows applicants to submit both SAT and ACT scores. They will consider the highest scores from each section across multiple tests. However, it is not necessary to submit both sets of scores, and you can choose to submit only one if you feel it reflects your abilities better.
12K
11K
