Has a Double Slit Experiment Been Conducted in a Vacuum Tube?
In summary, the double slit experiment has indeed been conducted in vacuum tube environments, demonstrating that light and matter exhibit wave-particle duality even in the absence of air or other particles. These experiments confirm that quantum effects are consistent regardless of external conditions, reinforcing the fundamental principles of quantum mechanics.
dave1223
i.e a vacuum tube. using the gate in a triode to adjust the amplification of the electrons. i guess you would have to have a photographic plate attached to the anode but this shouldnt effect the operation of the valve. just a thought... not sure where you would put the detector, maybe it would work outside the glass... you would put the slit between the gate and the anode or the gate and the cathode...
Even if you could, why would you? You wouldn't get any difference in results than a normal experiment.
Likes Vanadium 50
well, considering the amount of variations on the double slit experiments that have been tried and the number of times it has been repeated, i would say its probably worth a try
dave1223 said:
i.e a vacuum tube.
The double slit experiment has been made with other objects than photons (i.e light), e.g. electrons and C60 molecules.
At the moment I don't remember if the electron version of the experiment is done in vacuum, but I wouldn't be surprised... I think it is... I'll look around for it.
But it is my understanding that the C60 version of the experiment has been done in vacuum, quote:
Article said:
A significant advantage of the thermionic mechanism is that it does not detect any of the residual gases
present in the vacuum chamber. We could thus achieve dark count rates of less than one per second even under moderately high vacuum conditions (5 x 10-7 mbar).
The vacuum chamber is rigidly mounted on an optical table together with the ionizing laser, in order to minimize spatial drifts.
Source: Wave–particle duality of C60 molecules (by Arndt et al, Letters to Nature)
Edit, note: Above I assumed that you were interested in whether the experiment has the same result in vacuum as in air at normal pressure.
Likes PeroK and vanhees71
the electronic valve (vacuum tube) acts as an amplifier/suppressor, so it is not just about having a vacuum.
Likes vanhees71
There's nothing fundamentally different about doing the double slit experiment inside a vacuum tube than anywhere else. This is analogous to rolling a ball down the aisle of a bus vs a train vs a plane. Sure the carpet might be different, but you're still just rolling a ball on a surface. The electrons don't care where they are at. They'll still react to fields, barriers, and detectors just the same no matter where you put them.
If this thread turns into us giving you examples you adding new criteria as we do so to explain why the examples don't "count", this will get very old very fast.
Why don't you tell us where you are going with this (assuming it is in line with the PF rules, of course)?
Likes phinds
Hm, I don't know, whether the double-slit experiment with electrons is feasible just at normal air pressure. I don't know, what's the mean free path of electrons in air under normal conditions. For sure it's also dependent on the electrons' energy.
From a quick Google, it's reasonable to suppose a mfp of several microns. So the apparatus would have to be much smaller than this. You might be able to fabricate something on a silicon chip. :)
FAQ: Has a Double Slit Experiment Been Conducted in a Vacuum Tube?
What is the Double Slit Experiment?
The Double Slit Experiment is a famous physics experiment that demonstrates the wave-particle duality of light and matter. When particles such as electrons or photons pass through two closely spaced slits, they create an interference pattern on a screen behind the slits, indicating that they exhibit both particle-like and wave-like properties.
Why would conducting the Double Slit Experiment in a vacuum tube be significant?
Conducting the Double Slit Experiment in a vacuum tube eliminates the influence of air molecules and other environmental factors, providing a more controlled environment. This can help in achieving more accurate results and in studying the fundamental properties of particles without external interference.
Has the Double Slit Experiment been conducted in a vacuum tube?
Yes, the Double Slit Experiment has been conducted in a vacuum tube. Performing the experiment in a vacuum allows scientists to observe the behavior of particles more clearly and without the disturbances caused by air particles, leading to more precise measurements and observations.
What were the results of the Double Slit Experiment conducted in a vacuum tube?
The results of the Double Slit Experiment conducted in a vacuum tube confirmed the wave-particle duality of particles such as electrons and photons. The interference pattern observed was consistent with the patterns seen in experiments conducted in non-vacuum environments, reinforcing the idea that particles exhibit both wave-like and particle-like properties.
How does conducting the Double Slit Experiment in a vacuum tube impact our understanding of quantum mechanics?
Conducting the Double Slit Experiment in a vacuum tube provides a clearer and more precise demonstration of quantum phenomena, such as wave-particle duality and quantum interference. This helps to validate and refine theoretical models in quantum mechanics, contributing to a deeper understanding of the fundamental nature of reality and the behavior of particles at the quantum level.
