Has anyone done a PPN formalism on Dark Matter? Or other non-GR?
In summary, although there is still some disagreement about the exact nature of dark matter, it is most likely a result of symmetry breaking in the universe. This symmetry breaking may be due to differences in the way gravity works between baryonic matter and dark matter, or it could be due to some other unknown factor.
mollwollfumble
34
TL;DR Summary
Any signs of a factor of two difference between Dark Matter mass calculated using gravitational lensing vs calculated from the virial theorem?
This thought surprisingly came from thinking about the definition of temperature and the symmetry breaking that separated time from temperature. Which led to thoughts about symmetry breaking that separated QM from GR. Which led to to the symmetry breaking that separated dark energy from baryonic matter from dark matter. ie. the fine tuning there may be a result of symmetry breaking rather than just a statistical freak.
Although gravity between baryonic matter and baryonic matter has been confirmed using Parameterized post-Newtonian formalism to agree to high accuracy with General Relativity, I haven't seen evidence confirming that gravity between Dark Matter and baryonic matter acts using General Relativity.
Gravity between DM and baryonic matter could, for instance, act through gravitons in QM rather than through GR. If so, then the DM mass calculated from the virial theorem would differ by a factor of two from that calculated by gravitational lensing. Has this been tested? Any signs of a factor of two difference between Dark Matter mass calculated using different methods?
Likes ohwilleke
Dark Matter is GR. So its PPN parameters are the same as GR's.
Likes Demystifier
Dark matter theories, at the galaxy and galaxy cluster scale where a lot of the study of DM is being done, aren't really GR. They are really just straight up Newtonian gravity justified by the assumption that GR effects are negligible, which literature being discussing in a different PF thread right now, disputes.
I think what the OP is really asking is whether the improvements on unmodified Newtonian gravity used to approximate GR in most astronomy applications from the Post-Newtonian expansion (or equivalently, the PPN with GR parameters) could reproduce dark matter effects without resort to dark matter.
In other words, if considering some of the GR effects neglected in a purely Newtonian approximation, without using the mathematically intractable fully GR without any simplifying assumptions, as the post-Newtonian expansion and PPN with standard GR parameters do, could explain or partially explain phenomena usually attributed to dark matter.
The main non-Newtonian effects in GR which have been proposed to possibly account for phenomena in galaxies and galaxy clusters that are attributed dark matter have been gravitational field self-interactions and the GEM (gravitomagentic) effects that are both well recognized but have historically been discounted in weak field galaxy and galaxy cluster systems.
I'm not certain whether the PN expansion or PPN approach captures these GR specific effects in a way that would work for galaxy and galaxy cluster scale systems. But I think that this is what the OP wants to know.
Likes Maarten Havinga
Then let him ask it. Answering questions he didn't ask rather than the one he did ask is unlikely to be helpful.
FAQ: Has anyone done a PPN formalism on Dark Matter? Or other non-GR?
Has anyone applied PPN formalism to Dark Matter?
Yes, researchers have explored the Parameterized Post-Newtonian (PPN) formalism in the context of Dark Matter. The PPN formalism is a framework used to test and compare different theories of gravity, including modifications to General Relativity (GR). Some studies have extended PPN parameters to include contributions from hypothetical Dark Matter models to see if they can account for observed gravitational effects.
What modifications to PPN parameters are suggested for Dark Matter?
Modifications to PPN parameters for Dark Matter typically involve introducing new terms or altering existing parameters to account for the presence of Dark Matter. These modifications can include changes in the gravitational potential, adjustments in the metric coefficients, or the addition of new fields that interact with both Dark Matter and ordinary matter. These changes aim to better match astronomical observations and experimental data.
How does the PPN formalism compare to other non-GR theories in explaining Dark Matter?
The PPN formalism provides a systematic way to compare various gravitational theories, including those that propose alternatives to General Relativity or modifications to account for Dark Matter. While the PPN formalism is powerful in testing deviations from GR, it is often used alongside other methods, such as cosmological simulations and astrophysical observations, to provide a more comprehensive understanding of Dark Matter and its effects on the universe.
Have any non-GR theories been successful in explaining Dark Matter without invoking it directly?
Several non-GR theories, such as Modified Newtonian Dynamics (MOND) and TeVeS (Tensor-Vector-Scalar gravity), have been proposed to explain the phenomena attributed to Dark Matter without invoking it directly. These theories modify the laws of gravity at large scales or low accelerations to account for the observed discrepancies in galaxy rotation curves and other cosmic phenomena. While some of these theories can explain certain observations, they often face challenges in providing a consistent explanation across all scales and types of observations.
What are the challenges in applying PPN formalism to Dark Matter and other non-GR theories?
Applying PPN formalism to Dark Matter and other non-GR theories presents several challenges. One major challenge is the complexity of incorporating additional fields or modifications into the PPN framework. Another issue is the need for high-precision measurements to detect subtle deviations from GR predictions. Additionally, different Dark Matter models and non-GR theories can lead to similar observational signatures, making it difficult to distinguish between them solely based on PPN parameters. Finally, the interplay between Dark Matter, Dark Energy, and other cosmological factors adds another layer of complexity to these analyses.
