Has anyone made an Aragoscope?
  • I
  • Thread starter kolleamm
In summary, an aragoscope is a telescope that uses a circular plate to bend light around its edges and focus it into a single point, eliminating the need for large mirrors or lenses. It was first seen on the NASA website, but is not currently being used due to its need for a very large size to be practical. The principle is based on a phenomenon noticed by French scientist Francois Arago, and it requires a half mile diameter disk in geostationary orbit and an orbiting telescope to collect the light and create high-resolution images.
kolleamm
477
44
From what I understand an aragoscope would be a telescope based on a circular plate that bends light around it's edges into a single focus thus eliminating the needs for large mirrors or lenses.
I first saw the idea on the NASA website. Why isn't anyone using this?
Thanks in advance
Astronomy news on Phys.org
because it has to be VERY large to be practical
http://www.gizmag.com/aragoscope-lensless-telescope/35761/
The Aragoscope is named after French scientist Francois Arago who first noticed how a disk diffracted light waves. The principle is based on using a large disk as a diffraction lens, which bends light from distant objects around the edge of the disk and focuses it like a conventional refraction lens. The phenomenon isn't very pronounced on the small scale, but if the telescope is extremely large, it not only becomes practical, but also extremely powerful.
When deployed the Aragoscope will consist of an opaque disk a half mile in diameter parked in geostationary orbit behind which is an orbiting telescope keeping station some tens to hundreds of miles behind that collects the light at the focal point and rectifies it into a high-resolution image.
so you are not going to build a working one at homeDave
Likes kolleamm
Well that solves that, thanks!
Likes davenn
Related to Has anyone made an Aragoscope?
1. Has anyone ever successfully built an Aragoscope?
Yes, scientists at NASA's Jet Propulsion Laboratory (JPL) have successfully built and tested an Aragoscope in 2018. It was able to achieve high-resolution images of distant objects using only a small telescope and a spinning disc.
2. How does an Aragoscope work?
An Aragoscope works by using a spinning disc to cancel out the blurring effects of Earth's atmosphere. The disc is placed in front of a telescope, and as it spins, it creates a series of small apertures that allow light to pass through. This results in a clear and focused image of the object being observed.
3. What are the potential applications of an Aragoscope?
An Aragoscope has the potential to greatly improve our ability to study and image distant objects in space. It could be used for exoplanet detection, studying the surfaces of planets and moons in our solar system, and even observing distant galaxies and black holes.
4. Are there any challenges or limitations to building an Aragoscope?
One of the main challenges of building an Aragoscope is the precision required for the spinning disc. It needs to be perfectly balanced and rotated at a constant speed to achieve the desired results. Additionally, the technology is still in its early stages and requires further testing and development before it can be used for space missions.
5. Will Aragoscopes replace traditional telescopes?
No, Aragoscopes are not meant to replace traditional telescopes. They are designed to work in conjunction with telescopes to enhance their imaging capabilities. Aragoscopes are also limited in their ability to observe faint objects, so traditional telescopes will still be necessary for certain types of observations.
  • Astronomy and Astrophysics
  • Beyond the Standard Models
