Have a few questions, can you look them over?
  • Thread starter Satyr
In summary: So the graph decreases when -1<x<1 and increases when x<-1 or x>1. Also, since f'(x) is negative when -1<x<1, the graph is concave down on that interval. And since f'(x) is positive when x<-1 or x>1, the graph is concave up on those intervals. The given conditions of f(-1)=4 and f(1)=0 indicate that (-1,4) is a local max and (1,0) is a local min. As for the graph itself, it would look like a concave down parabola between x=-1 and x=
Satyr
1) integral from -4 to 2 of 2/sqrt(x) dx
I ended up with 4(sqrt2) - 4(sqrt-4); so I concluded it doesn't exist, correct?
2) integral (1+3x)x^2
This just seemed too simple to me, I ended up with f(x)=1/3x^3+3/4x^4+c, how's that look?
3) fifth derivative=0, find f(x); I ended up with C1x^4+C2X^3+C3X^2+C4X+C5
Does that seem okay?
4)I didn't finish this because I'm stuck, and not sure what the graph will look like, but the question is: Sketch the graph of a function that satisfies all of the given conditions.
f'(-1)=f'(1)=0
this means that there are tangent lines at x=1 and x= -1?
f'(x) <0 if |x|<1
this means graph decreases on all intervals when x<1?
f'(x)>0 if |x|>1
this means the graph increases on all intervals when x>1?
f(-1)=4, f(1)=0
these are critical points, local max's or min's?
f''(x) < 0 if x < 0
meaning concavity is down on all intervals where x is less than 1?
f''(x) > 0 if x>0
meaning concavity is up on all intervals where x is greater than 1?
If these are right, I'm not sure what the graph will look like, can someone give me a hand?
5) This last one seems simple, but I can't seem to figure out where to begin.
Question: Find the point of the graph of the function that is closest to the given point (2, 1/2) and the function: f(x)=x^2
EDIT: Think I got it, used the distance formula and solved through by optimization. Ended up with the points being (1,1)
Does that seem correct? Is there any way to check it?
Sorry for so many questions, but this is around 2 chapters worth of work that I'm trying to get caught up on and these are the ones that I got stumped or am unsure of.
Thanks a lot.
anybody have some time to give me a hand? lol
I think I solved question 5.
can someone at least take a look at number 4 for me?
I think the others are okay, but I need to get 4 done tonight.
thanks..
At a stationary point f'(x)=0 so then f'(-1)=f'(1)= 0 means that at x=-1 and x=1 there is a stationary point...now they gave you f(1) and f(-1). Thus (-1,4) and (1,0) are stationary points...they told you what f''(x) would be if x>0 and x<0...check the signs of the x-coordinates of the stationary points and see if they are max or min points
and |x|<1 => -1<x<1
FAQ: Have a few questions, can you look them over?
What is the purpose of asking someone to look over my questions?
The purpose of asking someone to look over your questions is to get feedback and ensure that your questions are clear, organized, and relevant to your research or topic.
Who should I ask to look over my questions?
You can ask a fellow scientist, colleague, or mentor who is knowledgeable about your research or topic to look over your questions. You can also seek out a subject matter expert or a peer review group for feedback.
How should I phrase my questions when asking someone to look them over?
When asking someone to look over your questions, it is important to be clear, concise, and specific. Use proper scientific terminology and avoid vague or ambiguous language. It may also be helpful to provide context or background information for each question.
How can I ensure that my questions are relevant and useful?
To ensure that your questions are relevant and useful, it is important to have a clear research question or objective in mind. Your questions should be directly related to your research or topic and should help you gather the information or data you need to answer your research question or achieve your objective.
Is it necessary to have someone look over my questions?
While it is not necessary to have someone look over your questions, it is highly recommended as it can improve the quality and effectiveness of your research. Getting feedback from others can also help you identify any potential flaws or gaps in your questions and allow you to make necessary adjustments before beginning your research.
