Have a problem with this Rotational Motion question
In summary, to find the speed of a wheel when it is 10m below the top of a hill, we can use the equation mgh + 1/2mv^2 + 1/2IW^2 = mgh + 1/2mv^2 + 1/2IW^2. By plugging in the values for mass, height, and initial velocity, we can solve for the final velocity. This is because the initial kinetic energy is not 0, so we cannot assume that the final potential energy is 0. By correctly setting up the equation, we can get the correct answer of 23m/s.
Shuo Xue
[/B]
A wheel, of radius 200mm, rolls over the top of a hill with a speed of 20m/s and negligible friction losses. (I = 1/2mr^2)
[/B]
Find the speed of the wheel when it is 10m below the top.
[/B]
mgh = 1/2mv^2 + 1/2IW^2
W= v/r
mgh = 1/2mv^2 + 1/2(1/2mr^2)(v/r)^2
mgh = 1/2mv^2 + 1/4mv^2
gh = 3/4mv^2
v^2 = 4gh/3
v^2 = 4(9.81)(10)/3
v = 11.4m/s
I got v = 11.4 m/s
but my answer is incorrect as it is different from the answer given which is 23m/s.
I want to know the correct solution.
I've also tried searching for the height first.
h = (3/4v^2)/g
h = 30.58m
and then 10m below from the top
h = 20.58m
v^2 = 4gh/3
v^2 = 4(9.81)(20.58)/3
v = 16.41m/s
Which is still far from the answer also.
h = 30.58m
I tried adding 10m to h instead of subtracting 10m
so, h = 40.58
v^2 = 4gh/3
v^2 = 4(9.81)(40.58)/3
v = 23m/s
Doing it this way, I got the correct answer.
Do you now understand why that is correct?
The wheel is already rolling on the top of a hill
my mistake is I assume the initial kinetic energy is 0 but it is actually not.
So initial energy is mgh + 1/2mv^2 + 1/2IW^2mgh + 1/2mv^2 + 1/4mv^2 = 1/2mv^2 + 1/4mv^2
gh + 1/2v^2 + 1/4v^2 = 1/2v^2 + 1/4v^2
gh + 3/4v^2 = 3/4v^2
(9.81)(10) + (3/4)(20)^2 = 3/4v^2
398.1 = 3/4v^2
v^2 = 4(398.1)/3
v^2 = 530.8
v = 23m/s
Here is another way to answer the question.
This solution is more understandable for me than the earlier solution.
Although I got the correct answer for that, I still don't understand why do I have to add 10m to the height that I got instead of subtracting 10m to it.
I also cannot assume that the final potential energy is 0 so
I think this is the most understandable solution.
mgh + 1/2mv^2 + 1/2mv^2 = mgh + 1/2mv^2 + 1/2mv^2
gh + 3/4v^2 = gh + 3/4v^2
(9.81)(30.58) + (3/4)(20^2) = (9.81)(20.58) + 3/4v^2
(9.81)(30.58) - (9.81)(20.58) + 300 = 3/4v^2
3/4v^2 = (9.81)(30.58-20.58) + 300
3/4v^2 = (9.81)(10) + 300
3/4v^2 = 398.1
v^2 = 530.8
v = 23m/s
Related to Have a problem with this Rotational Motion question
What is rotational motion?
Rotational motion is the movement of an object around an axis or center point. It can be described by the object's angular velocity, angular acceleration, and torque.
What is the difference between linear and rotational motion?
The main difference between linear and rotational motion is the direction of movement. Linear motion refers to movement in a straight line, while rotational motion refers to movement around an axis or center point.
What is angular velocity?
Angular velocity is the rate at which an object rotates around an axis. It is typically measured in radians per second.
What is torque?
Torque is a measure of the force that causes an object to rotate around an axis. It is calculated by multiplying the force applied to an object by the distance from the axis of rotation.
What are some real-life examples of rotational motion?
Many objects in our daily lives exhibit rotational motion, such as the spinning of a top, the rotation of a car tire, and the swinging of a pendulum. Other examples include the rotation of the Earth on its axis, the orbit of planets around the sun, and the rotation of a ceiling fan.
