Have i done this parametric differentiation right?
So, using the chain rule: d/dt(dy/dx) = (d/dx(dy/dx))(dx/dt)= (1-tant)(1/1+cost)= 1-tantSo the second order derivative is 1-tant.
bill nye scienceguy!
127
y=t+cost x=t+sint
dy/dt=1-sint dx/dt=1+cost
dy/dx= (dy/dt).(dt/dx)
= (1-sint).1/(1+cost) = (1-sint)/(1+cost)
= 1-tant
and how do i get from there to the second order differential?
bill nye scienceguy! said:
y=t+cost x=t+sint
= 1-tant
How did you go from:
[tex]\frac{dy}{dx} = \frac{1 - \sin t}{1 + \cos t} \quad \mbox{to} \quad = 1 - \tan t[/tex]?
Just stop at [tex]\frac{dy}{dx} = \frac{1 - \sin t}{1 + \cos t}[/tex]. It's okay, you don't have to simplify it any further.
To find:
[tex]\frac{d ^ 2 y}{dx ^ 2}[/tex], we use the Chain rule, and the derivative of inverse function:
[tex]\frac{dk}{du} = \frac{1}{\frac{du}{dk}}[/tex]
[tex]\frac{d ^ 2 y}{dx ^ 2} = \frac{d \left( \frac{dy}{dx} \right)}{dx} = \frac{d \left( \frac{dy}{dx} \right)}{dt} \times \frac{dt}{dx} = \frac{d \left( \frac{dy}{dx} \right)}{dt} \times \frac{1}{\frac{dx}{dt}}[/tex]
Can you go from here? :)
the second order derivitve is just the derivitive of dy/dx all divided by dx/dt
FAQ: Have i done this parametric differentiation right?
How do I know if I have correctly performed parametric differentiation?
The best way to determine if you have correctly performed parametric differentiation is to double check your work. Make sure you have correctly taken the derivatives of each individual function and then applied the chain rule to combine them. You can also verify your answer by plugging in values for the variables and comparing the results to the original functions.
What is the purpose of using parametric differentiation?
Parametric differentiation is a technique used to find the derivative of a function that is defined by parametric equations. These types of equations are often used to describe the path of a moving object, and by finding the derivative, we can determine the object's velocity and acceleration at any given point.
Can I use the power rule for parametric differentiation?
No, the power rule is not applicable to parametric differentiation. This is because parametric derivatives involve multiple functions and the chain rule must be used to find the derivative of each individual function.
What is the difference between parametric differentiation and implicit differentiation?
Parametric differentiation involves finding the derivative of a function defined by parametric equations, while implicit differentiation involves finding the derivative of a function that is not defined explicitly in terms of a variable. In implicit differentiation, the derivative can still be found using the chain rule, but it may also involve using the product rule or quotient rule.
Are there any common mistakes to avoid when performing parametric differentiation?
One common mistake is forgetting to apply the chain rule when taking the derivative of each individual function in parametric equations. It's also important to keep track of which variable you are taking the derivative with respect to, and to make sure you are taking the derivative of the correct function. Another common mistake is incorrectly simplifying the derivative using algebraic rules, so be sure to carefully distribute and combine terms when necessary.
