Have I got this correct? (Quotient rule)
  • Thread starter DBeckett91
In summary: Thanks for pointing that out.In summary, the goal of this problem is to differentiate the function s = (Ax^2-kx+w)/(Ax+k) using the quotient rule. The variables A, k, and w are defined as A = 8, k = 7, and w = 125. The final solution for ds/dx is (64x^2+951)/(8x+7)^2.
DBeckett91
Thanks in advanced for help on this, if I have gone wrong anywhere along the way please don't hesitate to point out my mistake(s).
Differatiate each question with respect to the variable.
s =(Ax^2-kx+w)/Ax+k
Quotient rule: ds/dx=((v*du/dx)-(u*dv/dx))/v^2
s = u/v
u = 8x^2-7x+125
v = 8x+7
du/dx = 8x^2-7x+125
= 16x-7
dv/dx = 8x+7
= 8
ds/dx=((8x+7*16x-7)-(8x+7*8))/8x+7^2
ds/dx=((128x^2-56x+112x-49)-(64x^2-56x+1000))/8x+7^2
ds/dx=((128x^2-56x-49)-(64x^2-56x+1000)/8x+7^2
ds/dx=(64x^2+951)/8x+7^2
s =(Ax^2-kx+w)/Ax+k
Is this the function you need to differentiate? Your work below has has A = 8 and k = 7.
Also, you need parentheses around the entire denominator, like this:
s =(Ax^2-kx+w)/(Ax+k)
s = u/v
u = 8x^2-7x+125
v = 8x+7
du/dx = 8x^2-7x+125
= 16x-7
dv/dx = 8x+7
= 8
Except for missing parentheses around the denominator, the above is fine.
DBeckett91 said:
ds/dx=((128x^2-156x-19)-(64x^2-56x+1000)/8x+7^2
How did you get the above? Specifically, how did -56x + 112x turn into -156x, and how did -49 turn into -19?
Sorry that was a typo, the post is now edited to be the numbers I intended. As for the value of A, k and w:
A = 8
k = 7
w = 125
I must have missed that bit also
FAQ: Have I got this correct? (Quotient rule)
1. What is the quotient rule?
The quotient rule is a formula used in calculus to find the derivative of a quotient of two functions. It is used when the two functions being divided are not easily differentiated by the power rule.
2. When should I use the quotient rule?
The quotient rule should be used when finding the derivative of a quotient of two functions, where the functions are not easily differentiated by the power rule. It is also useful when the functions are in the form of a fraction.
3. How do I apply the quotient rule?
To apply the quotient rule, you must first identify the two functions being divided. Then, use the formula d/dx(f/g) = (g * d/dx(f)) - (f * d/dx(g)) / (g^2) to find the derivative. Remember to use the power rule and chain rule as needed.
4. Can the quotient rule be used for more than two functions?
No, the quotient rule can only be used for two functions. If you have more than two functions being divided, you will need to use the product rule or chain rule in combination with the quotient rule.
5. What are the common mistakes when using the quotient rule?
Common mistakes when using the quotient rule include forgetting to use the power rule, forgetting to apply the negative sign when using the chain rule, and not simplifying the final answer. It is important to carefully check each step and simplify as much as possible to avoid errors.
