Have I proved some part of Fermat's last theorem?
  • B
  • Thread starter fenstip
  • Tags
    Proof
In summary, the article explores the author's potential contributions to proving aspects of Fermat's Last Theorem, discussing various mathematical approaches and insights that may align with or support existing proofs. The author reflects on the significance of their findings and the historical context of the theorem, ultimately questioning the validity and completeness of their work in relation to the established proof by Andrew Wiles.
fenstip
Have I proved Fermat last theorem?
X^4 + Y^4 != Z^4 has been proved by Fermat that if X,Y,Z = integer numbers, the formular is fine. Set x=X^2, y=Y^2, z=Z^2, so x, y, z are (some) integer numbers based on X,Y,Z.
x^4 + y^4 != z^4 //x, y, z are still integer, would be obey to Fermat's Fermat theorem, in which n=4.
X^8 + Y^8 != Z^8 // replacing x,y,z with X,Y,Z.
In the same way, you can have n=16, 32, 64...
Mathematics news on Phys.org
No, you've just made a well known observation.
What about others? Say n=5.
Thread closed temporarily for Moderation...
It is sufficient to prove Fermat's last theorem for odd prime numbers, and as far as I know, it is believed that Fermat had a proof for three in mind. He only wrote down a sketch of a proof for four so we cannot know for sure what he knew and what he did not know. The Pythagorean triples which solve the quadratic case have been known since ancient times. Euler has definitely proven the cases three and four.
Likes dextercioby
N=3,4,5 has been proved hundreds of years ago, if let them mix and mix in my proof can get N more dense, but far away from complete dense. Only Andrew Wiles has the full proof.
He said he has proof all, but no one knows.
As i said, it is not your proof, it is just an observation that everyone can see.
And if you know you dont get all exponents, why did you ask if you had proven the theorem!
There is no link out there saying human beings except AndrewWiles, improve the number of n to 1000, unless visiting this page, then "everyone" can see it is not my proof including you.
I am not sure what you mean here. Every elementary book on number theory that talks about Fermat says the obvious that of ##n=mk##, then the equations becomes ##(x^m)^k+(y^m)^k=(z^m)^k##. So it is enough to prove it for ##n=4## and ##n## a prime number.
Also you should look into the history of the problem. There are many people you improved on between Fermat and Wiles.
He didn't just say that, he published the proof. Others have checked it and verified that it is correct after fixing a smaller issue in an earlier version.
Edit: I thought this was about Wiles, my comment is about Wiles.
If there is no solution for n then there is no solution for 2n, 3n, 4n, ... - that is very easy to demonstrate, and that's the observation you made here. That alone doesn't prove the theorem, however. You also need to show that there is no solution for all odd primes and you need to show that there is no solution for 4. People had found proofs for 4 and for many primes before, but Wiles was the first one to find a proof for all primes.
mfb said:
He [Fermat] didn't just say that, he published the proof.
Fermat didn't publish anything. All we have are letters he sent to colleagues, which at the time were basically challenges, and what has been published after his death, was found in his left properties. E.g.
Wikipedia said:
Bernard Frénicle de Bessy published the first proof for the case n=4 as early as 1676. His solution came from Fermat himself, whose proof sketch in this case is known in a marginal note in his Diophant edition on a closely related problem (see Infinite Descent).
Leonhard Euler published a proof for the case n=4 in 1738. Later, with the help of complex numbers, he was also able to confirm the claim for the case n=3, which he published in 1770 (he announced in a letter in 1753 that he had the proof). However, Euler was unable to extend his method of proof to other cases.
At least 20 different pieces of evidence have now been found for the case n=4. For n=3 there are at least 14 different pieces of evidence.
Even if they/you own the enough knowledge to prove it, it doesn't mean you notice how to prove it. All of our words learning from parents/books/films etc which are full in the proof, so there wouldn't "proof" existed?
I think I know what the difference between us. You are focusing on the proof, I know I referred Fermat's in my observation. I focus on the result (after proving) which I think others ignored 300 years.
  • Skeptical
Likes weirdoguy
This does not make any sense. Who ignored what? Read my post #13.
Only Fermat's name was given to the problem because of his famous note on the margin of his book. His contributions to any part of the solution were marginal, too.
There is nothing more to discuss on that specific conclusion that was best summarized in @martinbn's post #11. This thread is closed.
Likes e_jane, berkeman and topsquark
FAQ: Have I proved some part of Fermat's last theorem?
What is Fermat's Last Theorem?
Fermat's Last Theorem states that there are no three positive integers \(a\), \(b\), and \(c\) that satisfy the equation \(a^n + b^n = c^n\) for any integer value of \(n\) greater than 2. This theorem was famously conjectured by Pierre de Fermat in 1637 and was proven by Andrew Wiles in 1994.
How do I know if I have proved a part of Fermat's Last Theorem?
To determine if you have proved a part of Fermat's Last Theorem, you need to compare your findings with existing literature. If your proof addresses the case for specific values of \(n\) greater than 2 or provides new insights or conditions under which the theorem holds, you may have contributed to its understanding.
What are some common approaches to proving parts of Fermat's Last Theorem?
Common approaches include exploring the cases for specific primes, using modular forms, elliptic curves, or employing techniques from algebraic geometry. Many researchers have focused on proving the theorem for particular values of \(n\) or for certain types of numbers.
Can I submit my proof to a journal?
Yes, if you believe you have a valid proof or a significant contribution related to Fermat's Last Theorem, you can submit your work to a mathematical journal. Ensure that your proof is rigorous, well-documented, and clearly addresses the relevant aspects of the theorem.
What should I do if I think I have found a mistake in a known proof of Fermat's Last Theorem?
If you believe you have found a mistake in a known proof, it is crucial to carefully verify your findings and understand the original proof thoroughly. You may want to discuss your concerns with experts in the field before publishing your observations. Engaging with the mathematical community can provide valuable feedback and help validate your claims.
