Have they determined where the sunken cores are at Fukushima?
  • Fukushima
  • Thread starter ElliotSmith
In summary, the exact location of the corium at Fukushima reactors #1-3 has not been determined, but it is likely under the pressure vessel and some may be in the water at the bottom of containment and torus. It is unknown if the corium has breached the concrete base of the reactor buildings and reached the ground soil. There has been progress made on unloading the spent fuel pools, but the plan for removing the corium is still unclear. TEPCO suspects the corium may be in the bottom of the pressure vessel, but confirmation is needed. The water in this area is highly contaminated, making it difficult to use cameras to investigate.
ElliotSmith
168
104
After almost 4 years sine the triple meltdowns, have they determined the exact location of the corium at Fukushima reactors #1-3?
How far down has it burned through and has it breached the concrete base/foundations of the reactor buildings? Has it reached ground soil?
Also, how much progress has been made on the unloading of the spent fuel pools?
Do they know if the melted core material has burned through the concrete base of the reactor buildings and into the ground soil beneath?
How do they plan on (eventually) removing the big blob of corium sitting somewhere beneath the pressure vessel?
I know that in the three mile island defueling/decommissioning process, the melted core material was broken up and vacuumed out. But that was different because TMI reactor #2 only suffered a partial core meltdown and 100% of the core was still contained inside the reactor vessel.
As far as I know, TEPCO as not confirmed where the 'corium' is located, but I imagine they suspect in the bottom of the pressure vessel. Some of the core (fission products) obviously dissolved in the water that did find its way into the RPV. The fuel, cladding and core structural materials probably reacted (oxidized) in the coolant, and the reaction products would have flowed out with the water into the containment. TEPCO has to get a camera underneath the RPV to see if it was breached. The water there is highly contaminated with radionuclides, so the radiation affects the CCDs.
Related to Have they determined where the sunken cores are at Fukushima?
1. What are sunken cores?
Sunken cores refer to the fuel assemblies that were inside the reactors at the Fukushima nuclear power plant. These assemblies were damaged during the 2011 earthquake and tsunami, causing them to sink to the bottom of the reactors.
2. Why is it important to determine the location of the sunken cores?
Determining the location of the sunken cores is important for the clean-up and decommissioning process of the Fukushima nuclear power plant. It is crucial to know the exact location of the cores in order to safely remove and dispose of them.
3. How have they determined the location of the sunken cores?
Scientists have used remote-controlled robots equipped with cameras and radiation detection equipment to enter the reactors and search for the sunken cores. They have also used sonar technology to map the bottom of the reactors.
4. Have they been able to determine the location of all the sunken cores?
No, as of now, the location of all the sunken cores has not been determined. Due to the high levels of radiation and other challenges, it has been a difficult and ongoing process. However, scientists continue to work towards finding and mapping the location of the sunken cores.
5. What are the risks associated with the sunken cores at Fukushima?
The sunken cores at Fukushima pose a risk of continued radiation leakage into the surrounding environment. If not properly contained and removed, the cores could also potentially cause further damage to the reactors or lead to a criticality incident. It is important to safely and effectively manage the sunken cores in order to mitigate these risks.
  • Nuclear Engineering
16K
11K
22K
14K
  • STEM Career Guidance
