Having all subgroups normal is isomorphism invariant
In summary, being Hamiltonian is an isomorphism invariant, as proven by showing that if all subgroups of a group are normal and the group is isomorphic to another group, then all subgroups of the other group are also normal. This is established through two lemmas, one showing that the preimage of a subgroup is also a subgroup and the other showing that if the preimage of a subgroup is normal, then the subgroup itself is normal.
Mr Davis 97
1,462
44
A group is called Hamiltonian if every subgroup of the group is a normal subgroup. Prove that being Hamiltonian is an isomorphism invariant.
Let ##f## be an isomorphism from ##G## to ##H## and let ##N \le H##. First we prove two lemmas:
Lemma 1): If ##f^{-1}(N) \le G## then ##N \le H##.
Let ##a,b \in N##. Then since ##f## is surjective, ##a=f(x)## and ##b=f(y)## for some ##x,y \in f^{-1}(N)##. Then ##ab^{-1} = f(x)f(y)^{-1} = f(xy^{-1}) \implies xy^{-1} = f^{-1}(ab^{-1})##. In the previous step we used the fact that ##f## is a homomorphism and that ##f## is injective. Now, since ##x,y \in f^{-1}(N)## and ##f^{-1}(N)## is a subgroup, we have that ##xy^{-1} \in f^{-1}(N)##. So ##f^{-1}(ab^{-1} \in f^{-1}(N)##. By definition of the preimage, this means that ##f(f^{-1}(ab^{-1})) \in N \implies ab^{-1} \in N##. So ##N \le H##.
Lemma 2): If ##f^{-1}(N) \trianglelefteq G## then ##N \trianglelefteq H##.
Here we use lemma 2 and suppose that ##N \le H##. We want to show that ##\forall h \in H##, ##hNh^{-1} \subseteq N##. So, let ##h\in H## and ##n \in N##. Since ##f## is surjective, ##h = f(y)## for some ##y \in G## and ##n=f(x)## for some ##x \in f^{-1}(N)##. Then ##hnh^{-1} = f(y)f(x)f(y)^{-1} = f(xyx^{-1}) \implies yxy^{-1} = f^{-1}(hnh^{-1})##. But ##f^{-1}(N) \trianglelefteq G##, so ##yxy^{-1} \in f^{-1}(N)##. Hence ##f^{-1}(hnh^{-1}) \in f^{-1}(N)##. By definition of the preimage, this implies that ##hnh^{-1} \in N##. We conclude that ##N \trianglelefteq H##.
Finally, we prove the main result, that if all of the subgroups of ##G## are normal, and if ##G## is isomorphic to ##H##, then all of the subgroups of ##H## are normal.
Let ##N## be a subgroup of ##H##. We know that the preimage of a subgroup is also a subgroup, so ##f^{-1}(N) \le G##. But all of the subgroups of ##G## are normal, so ##f^{-1}(N) \trianglelefteq G##. By lemma 2, we then know that ##N \trianglelefteq H##, and we are done.
NOTE: Perhaps this argument would have been easier if I supposed that ##f : H \to G## were the isomorphism.
In this case you really do merely need two lines:
and
Let me write it a bit easier. Say ##f\, : \,G \longrightarrow H## is an isomorphism and ##N \trianglelefteq G## and ##n,m \in N, g \in G, h=f(g)\in H\,.##
Then ##f(n)f(m)^{-1}=f(nm^{-1}) \in f(N)## shows the subgroup property, and ##hf(N)h^{-1}=f(gNg^{-1}) \subseteq f(N)## shows normality. That's all.
Likes Mr Davis 97
Related to Having all subgroups normal is isomorphism invariant
What does it mean for all subgroups to be normal?
When all subgroups of a group are normal, it means that every subgroup of the group is invariant under conjugation. In other words, if you take an element from the group and conjugate it with an element from any subgroup, the result will still be in that subgroup.
What is an isomorphism?
An isomorphism is a bijective homomorphism between two groups. It preserves the algebraic structure of the groups, meaning that the operation in one group corresponds to the operation in the other group.
How does having all subgroups normal affect the isomorphism of a group?
If a group has all subgroups normal, it means that the group has a strong symmetry which is preserved under isomorphisms. This means that if two groups have all subgroups normal, they will be isomorphic to each other.
What are the benefits of having all subgroups normal?
Having all subgroups normal makes the group easier to study and understand. It also allows for more efficient computations and simplifies the process of finding isomorphisms between groups.
Are there any groups that have all subgroups normal?
Yes, there are several groups that have all subgroups normal, such as abelian groups, symmetric groups, and dihedral groups. However, not all groups have this property, and it is a significant characteristic that can help classify and distinguish different groups.
