Having trouble solving this problem due to its wording
  • Thread starter Dellb89
In summary, the conversation discusses a problem involving two 300kg telephone poles trying to connect without the use of a copper cable. The cable has a length of 20m and the question is what force would draw the poles together but may not be enough to fully connect them. The equation for tension is mentioned and there is some confusion about the relevance of the masses of the poles. It is eventually determined that the force of tension is the answer, but there is not enough information given to calculate it accurately. The force of gravity is also mentioned as a possible factor, but it is concluded that the poles are held in place by being planted in the ground and their mass is not a significant factor in the tension.
Dellb89
Two 300kg lonely obelisk (telephone poles) long to make a connection without the intermediary of copper cable of love (telephone wire). If the cable is stretched taut that connects them is 20m, then what is the force that will forever draw them together but may never be enough to enable them to become as one?
(I believe its tension)
T1=T2+F
T1-T2=F
SinΘ*300kg-SinΘ*300kg=F
Since the masses are the same the net force is 0. But I am still not confident that I am doing right.
I don't think there is enough info to calculate an answer. Unless the answer is something simple like... It takes an infinite force to pull the wire taut/horizontal.
I am having trouble even picturing this scenario, let alone solving it.
Are they vertical? Are they 20m apart? Is that why a cable between them is taut? What force is drawing them together? The tension on the cable?
I think this statement should tell you something's wrong with your logic. The ratio of the masses should be irrelevant.
This seems to be more of a puzzle problem than anything else. You aren't given any details about extant forces like the cable tension (and it would go slack anyways if the poles bent even a little bit towards each other). So tension can be crossed off the list.
So consider the specific details that you are given.
It is possible that you are only meant to identify the force involved and not necessarily calculate it...
Likes CWatters
Think I might have an idea...
Both the mass and strength of the wire are proportional to it's diameter. So with luck the maximum allowable tension is independent of diameter!
Edit: Humm I can't make that work.
Ignore my post above. Have figured it out. Quite a nice problem when you see the light.
gneill - I've sent you a PM.
Thank you guys! I think this is more of a conceptual problem, more than one that gives an actual answer. I'm just telling her the answer is tension. Its not actually for my it for my cousin. I have a degree in physics and have never come across a problem worded in this way. I'm blaming common core for this one.
You may want to rethink that. What happens to the cable tension if the poles bend towards each other? Can the cable tension last "forever"?
No, gneill the cable will eventually break. Or the poles will start to bend towards each other and the cable will start to sag, but that would require more information. I'm going to assume that it breaks because the cable cannot withstand the force of 2,940 N on each side of it.
How do you come up with 2,940 N for the tension? Are the posts hanging from the cable somehow? What then is the cable attached to? Are the posts not driven into the ground like telephone poles? How do you decide what the failure tension is for the cable if no details are given?
I got 2940 N by multiplying the 300, the mass of the obolus by g, acceleration due to gravity.
I was staring to thing that this was a young modulus problem but we don't know the cross section of the string. And we don't know the original length of the string for it to be stretched 20m
What direction does the force due to gravity act?
Downward, but isn't tension equal to force on the body, which is its weight.
Downward is correct. The tension acts horizontally though, so they are unrelated. Here the tension is provided by the poles' stiffness -- a sort of spring action. The poles are kept from tipping by being planted and held in the ground, but they will have some amount of flexibility along their length since no material is perfectly rigid.
So are we to say that the cable will bring the poles slightly together. What does that have to do with the 20m?
Yes. At least their top ends anyways; their bases are fixed.
Nothing. The mass, too, is essentially irrelevant to the tension (other than helping to keep the poles seated in the ground).
There is not enough information given to calculate the tension. All you can do is recognize that there is tension and identify its source.
There is another force acting to pull the poles together but it will be entirely negligible. That force you do have enough information to at least estimate.
And what force would that be? Gravity? Friction? Normal?
What force do you have enough information about that you might calculate (or estimate) a value for it?
Since we have the mass, I'm guessing gravity.
But that 20m is still being neglected.
Good guess :smile:
Is it? What's the equation for gravitational force?
F=G*m1*m2/r^2
Dellb89 said:
F=G*m1*m2/r^2
Right. So you should see where the distance fits, right?
Thank you so much!
Dellb89 said:
Thank you so much!
You're welcome.
So you should note that there are two forces acting to bring the poles together: tension and gravity. The gravitational force will be many, many orders of magnitude smaller than the tension, but it's still there even so.
Obviously the answer to the question - it is a force acting forever.
If that is the answer they want, the question is pretty stupid.
I agree 256bits, this question was terrible.
I think it's a great question. Sorry to say I only got it after gneill's post (#4).
FAQ: Having trouble solving this problem due to its wording
How do I know if the wording of a problem is causing me trouble in solving it?
If you find yourself repeatedly stuck on a problem or having difficulty understanding what is being asked, it is likely that the wording of the problem is causing you trouble.
What can I do when I'm having trouble solving a problem due to its wording?
There are a few strategies you can try when faced with a problem you are having trouble with due to its wording. First, try breaking down the problem into smaller, more manageable parts. You can also try rephrasing the problem in your own words to gain a better understanding. Additionally, seek help from a classmate, teacher, or tutor for a fresh perspective.
Are there any common mistakes that can arise from confusing problem wording?
Yes, there are a few common mistakes that can result from confusing problem wording. These include misinterpreting what the problem is asking for, using incorrect units or variables, and skipping important steps in the solution process.
How can I improve my problem-solving skills when it comes to tricky wording?
Practice makes perfect! The more problems you solve, the better you will become at recognizing and navigating tricky wording. It can also be helpful to read through the problem multiple times and make notes of any key information or keywords.
Is it okay to ask for clarification on a problem's wording?
Absolutely! Asking for clarification is an important part of problem-solving. It is always better to make sure you fully understand a problem before attempting to solve it. Don't be afraid to ask your teacher or professor for clarification if needed.
