Having trouble with algorithm to build a function tree
In summary, the algorithm to build a function tree from math functions is complicated and I am not able to come up with a general algorithm to do it.
Jamin2112
986
So I've been writing an algorithm to build a function tree and I believe I'm aaaaallllllmost there. The intent is to take a math function like
Code:
x^2+x+1*5
and build it into
Code:
      / ^ \     x           1 *  5
    x       2
My idea to parse the function is to think of it being like
Code:
[Exp_0][Op_1][Exp_1][Op_2][Exp_2]...[Op_n][Exp_n]
where [Exp_i] represents an expression (x, a number, or a function in parentheses) and [Op_i] represents an operator. In the above function
Code:
Exp_0 = 'x'
Op_1 = '^'
Exp_1 = 2
Op_2 = '+'
Exp_2 = 'x'
Op_3 = '+'
Exp_3 = 1
Op_4 = '*'
Exp_4 = 5
I know how to write the algorithm if the operators are in order of ascending or descending precedence. For instance, something like
x^2*2+1
is easy to build into a tree because as you grab the expressions from left to right you simply take the previous tree and make it be the left-hand side of a new tree and make the right-hand side of the tree be the current expression. The building of that tree (skipping a few steps) would look like
Code:
x     2
Code:
 / ^ \          2
x     2
Code:
                 /             1
       / ^ \          2
      x     2
The algorithm is:
Code:
Get Exp_0
If there's no Op_1, return Exp_0;
Else,
Make a tree T like
     /                  [Op_1]             \
[Exp_0]                                  [Exp_1]
for (i = 2; i <= n; ++i)
      temp = T;
      T = new Tree;
      T.leftHandSide = temp;
      T.oper = [Op_i];
      T.rightHandSide = [Exp_i];
Hopefully that pseudo-code is legible to you.
The algorithm for making a tree when the precedence of the operators is reversed, e.g.
1+2*x^2
is slightly more complicated, but I know how to write. I can also write an algorithm that combines the 2 algorithms I mentioned.
The problem is that I can't think of a general algorithm that looks at the precedence of each operator found and then rebuilds the tree accordingly. It seems like it would be extremely complex, and I've gotten close to making it, but maybe I'm going about things completely wrong.
Can someone give me a hint to push me along?
Technology news on Phys.org
Compiler developers face exactly the same problem - decomposing strings into atomic operations. Have a Google for "smallc.c" the name may vary slightly. It is a C interpreter written in C, functions the way the BASIC language originally did. It uses a descent parser - which is what you need. Somewhere on my shelves is a book on C that has the code. If I bump into it I will post the reference.
At any rate check out a descent parser.
Found what you want: 'C: The complete reference Fourth Edition' Herbert Schildt, 2000, Obourne
You want Chapter 29.
I DO NOT fully recommend the book as a C reference - the edition I have has more than several errors.
Awesome. I'll take a look at it.
Pseudocode for this would look like this.
Tokenise the input. I would use regex.
Code:
20 * (32 + 4) + 1 --> integer mulop bra integer addop integer ket addop integer
Now the grammar:
Code:
<expression> =
        <term> <addop> <term>
    or  <term>
<term> =
        <factor> <mulop> <factor>
    or  <factor>
<factor> =
        <integer>
    or  <bra> <expression> <ket>
Now recursive descent parsing
Code:
def parse (tokens)
    value = expression ()
    return value
def expression ()
    value = term ()
    while 1
        if tokens[index].type == ADDOP
            index += 1
            value += term ()
        else if tokens[index].type == SUBOP
            index += 1
            value -= term ()
        else break
    return value
def term ()
    value = factor ()
    while 1
        if tokens[index].type == MULOP
            index += 1
            value *= factor ()
        else if tokens[index].type == DIVOP
            index += 1
            value /= factor ()
        else break
    return value
def factor ()
    if tokens[index].type == INTEGER
        return tokens[index++].value
    else if tokens[index].type == BRA
        index += 1  # eat bracket
        result = expression()
        if tokens[index].type != KET
            throw SyntaxError
    return result
def main ()
    tokens = lex ("  2 + 3 * (2+2)  ")
    answer = parse (tokens)
    print (answer)
Read Compilers by Aho (the Dragon Book) or just google how to write a parser. I did this quick and there might be an error or two.
Edited. Fixed expression, term.
FAQ: Having trouble with algorithm to build a function tree
1. What is an algorithm?
An algorithm is a set of step-by-step instructions or rules that are followed to solve a problem or complete a task.
2. Why am I having trouble building a function tree?
Building a function tree can be challenging because it requires understanding of the problem and the logic behind the solution. It also involves breaking down the problem into smaller subproblems and determining the appropriate functions to use.
3. How can I improve my algorithm for building a function tree?
One way to improve your algorithm is to carefully analyze the problem and break it down into smaller, more manageable steps. You can also try to identify any patterns or similarities between the problem and other problems you have previously solved.
4. Are there any resources that can help me with building a function tree?
Yes, there are many online resources and tutorials available that can provide guidance and tips for building a function tree. You can also consult with other programmers or seek assistance from a mentor.
5. Can I use any programming language to build a function tree?
Yes, you can use any programming language to build a function tree as long as it has the necessary features and functions to solve the problem at hand. However, some languages may be better suited for certain types of problems than others.
