Hawking Radiation from All Gravitational Sources?
In summary: The former is the "black hole temperature" or, equivalently, the "Unruh temperature" associated with that proper acceleration.In summary, the formulas for hawking radiation and unruh radiation are related, but they are not physically equivalent. The "g" in the Hawking formula represents the surface gravity of the black hole's horizon, while the "g" in the Unruh formula represents the proper acceleration of the body. The two formulas do not apply to all gravitating bodies, as the Hawking formula is specifically for black holes with a horizon. The "surface gravity of the horizon" is the redshifted proper acceleration of an object at the horizon, and it does not diverge due to a "
bcrelling
69
I see that the formula for hawking radiation is related the the formula for unruh radiation. The accelleration experienced by a body yields an unruh temperature equivalent to a black holes hawking temperature with an equivalent value of g. The unruh effect happens at all accelerations, therefore is hawking radiation a property of all gravitation sources(not just black holes?)
Likes Matterwave and PAllen
This doesn't mean quite what you think it means. The "g" in the Unruh case is the actual proper acceleration of the body. The "g" in the Hawking case is not; it's the "surface gravity" of the black hole, which is the "redshifted proper acceleration" at the hole's horizon. This is not a direct observable the way the proper acceleration of the body in the Unruh case is. So, although the two formulas are related, they are not physically equivalent.
No. "All accelerations" in the Unruh case corresponds (with the caveats given above) to "all black hole masses" in the Hawking case. As noted above, the "g" in the Hawking formula is the surface gravity of the horizon, so the formula doesn't apply to gravitating bodies that don't have a horizon.
Likes bcrelling
What does the "surface gravity of the horizon" mean? If it means the proper acceleration of an object hovering at the horizon, then doesn't that diverge?
Okay, according to Wikipedia, there's sort of a "cancelling infinities" effect going on here. The temperature goes to infinity near the horizon, but also photons emerging from near the horizon and escaping to infinity undergo an infinite red shift. The two effects combine to give a finite photon energy, corresponding to a finite temperature, as measured by an observer far from the black hole.
http://en.wikipedia.org/wiki/Hawking_radiation
It means the "redshifted proper acceleration" of an object at the horizon. The easiest way I know of to physically interpret what that means is to imagine an object being held at a constant altitude above the horizon by a rope, with the other end of the rope being held by an observer at infinity. The observer has to exert a force on the rope to hold the object static, and this force increases as the altitude at which the object is held approaches the horizon; but it does not diverge because the force required at infinity is "redshifted", relative to the force required at the object itself. So the limit of this force as the altitude of the object approaches the horizon is finite, and therefore so is the limit of the force at infinity divided by the invariant mass of the object, which is the "redshifted proper acceleration" of the object. The latter limit is the surface gravity of the horizon.
I can confirm that the concept of Hawking radiation is not limited to black holes, as it is a consequence of the principles of quantum mechanics and general relativity. The formula for Hawking radiation is indeed related to the Unruh effect, which states that an accelerating observer will detect a thermal radiation that is equivalent to a black hole's Hawking temperature.
This means that any object or source of gravity, including planets, stars, and even ourselves, can potentially emit Hawking radiation. However, the effect is extremely small for sources with low gravitational fields, such as planets and stars, and is only significant for objects with extremely strong gravitational fields, such as black holes.
Furthermore, the Hawking radiation from these sources would also be extremely difficult to detect due to its low intensity. So while it is theoretically possible for all gravitational sources to emit Hawking radiation, it is only significant and detectable for objects with extremely high gravitational fields, such as black holes.
In conclusion, Hawking radiation is not limited to black holes and can potentially be emitted by all gravitational sources, but its significance and detectability are dependent on the strength of the gravitational field.
FAQ: Hawking Radiation from All Gravitational Sources?
What is Hawking Radiation from All Gravitational Sources?
Hawking Radiation from All Gravitational Sources is a theoretical phenomenon proposed by physicist Stephen Hawking. It suggests that black holes and other gravitational sources emit radiation due to quantum effects near their event horizon, causing them to slowly lose mass over time.
How does Hawking Radiation occur?
Hawking Radiation occurs due to virtual particle pairs being created near the event horizon of a black hole or other gravitational source. One particle falls into the black hole, while the other escapes, causing the black hole to lose mass and energy.
Can Hawking Radiation be observed?
Hawking Radiation is very difficult to observe, as it is extremely faint and difficult to distinguish from other sources of radiation. However, there have been some observations that suggest the existence of Hawking Radiation, such as the decrease in mass of certain black holes over time.
What is the significance of Hawking Radiation?
Hawking Radiation has significant implications for our understanding of black holes and the nature of gravity. It also provides a link between quantum mechanics and general relativity, two fundamental theories in physics that have been difficult to reconcile.
Can Hawking Radiation be used for energy production?
Currently, Hawking Radiation is too weak to be harnessed for energy production. However, some researchers are exploring the possibility of using advanced technology to amplify or manipulate Hawking Radiation for practical use in the future.
