He most general form of the metric for a homogeneous, isotropic and st
In summary, a homogeneous, isotropic, static metric can only exist as a solution of the Einstein Field Equation with a nonzero cosmological constant.
MarkovMarakov
33
What is the most general form of the metric for a homogeneous, isotropic and static space-time?
For the first 2 criteria, the Robertson-Walker metric springs to mind. (I shall adopt the (-+++) signature)
[tex]ds^2=dt^2+a^2(t)g_{ij}(\vec x)dx^idx^j[/tex]
Now the static condition. If I'm not mistaken, it means that the metric must be time-independent and invariant under time reversal [tex]t\to -t[/tex]. So does that mean that the most general metric that satisfies all these 3 criteria is [tex]ds^2=dt^2+g_{ij}(\vec x)dx^idx^j[/tex] for some spatial metric [tex]g_{ij}(\vec x)[/tex]?
Thank you.
Thank you.
Surely all the spatial metric coefficients must be equal ?
Perhaps I should impose the condition of constant curvature...? Is that enough?
Probably. If the definition of homogeneity requires the same curvature everywhere. I'm sure someone will give you a better answer soon. I don't have my books at hand so I can't look it up.
I believe this is correct. However, I also believe that a homogeneous, isotropic, static metric can only be a solution of the Einstein Field Equation with a nonzero cosmological constant (e.g., the Einstein static universe). With a zero cosmological constant, a homogeneous, isotropic metric can't be static; it must be either expanding or contracting.
(Einstein introduced the cosmological constant in order to allow a static solution for the universe, but later, when the expansion of the universe was discovered, he called this "the greatest blunder of my life" because he missed the opportunity to predict an expanding universe before it was discovered.)
As Peter notes, a homogenous isotropic universe coming from the standard FLRW models cannot be static because the evolution equation ##3\frac{\ddot{a}}{a}= -4\pi(\rho + 3P)## tells us that for positive average mass density ##\rho > 0## and non-negative pressure ##P\geq 0##, ##\ddot{a} < 0##.
If we add a cosmological constant ##\Lambda## then according to problem 5.3 of Wald, static solutions exist iff ##k = +1## and ##\Lambda > 0##. I haven't done the problem yet myself but you might find it instructive (there is also a second part investigating the instability of such universes which is where the real interest of the problem lies!).
EDIT: Just to add, for the ##P = 0## (dust) case, we can drop the isotropy and homogeneity and be more general with regards to the impossibility of a static solution. See here if you are interested: https://www.physicsforums.com/showthread.php?t=683601
Thank you, everybody!
FAQ: He most general form of the metric for a homogeneous, isotropic and st
What is the most general form of the metric for a homogeneous, isotropic and stationary universe?
The most general form of the metric for a homogeneous, isotropic and stationary universe is known as the Friedmann-Lemaître-Robertson-Walker (FLRW) metric. It is a mathematical representation of the spacetime in a universe that is homogeneous (uniform throughout) and isotropic (looks the same in all directions) on large scales.
How is the FLRW metric derived?
The FLRW metric is derived from Einstein's general theory of relativity, which describes the relationship between matter, energy, and spacetime. It is based on the assumption that the universe is homogeneous and isotropic, and uses the cosmological principle to apply this to the entire universe.
What are the main components of the FLRW metric?
The FLRW metric has three main components: the scale factor, which describes the expansion of the universe over time; the curvature term, which takes into account the overall curvature of space; and the energy density, which represents the matter and energy content of the universe.
How does the FLRW metric relate to the Hubble law?
The FLRW metric is closely related to the Hubble law, which states that the farther away a galaxy is from us, the faster it appears to be moving away. The scale factor in the FLRW metric is directly proportional to the Hubble constant, which measures the rate of expansion of the universe.
Are there any limitations to the FLRW metric?
While the FLRW metric is a useful tool for describing the large-scale structure of the universe, it does have limitations. It assumes a perfect homogeneity and isotropy, which may not be true on small scales. It also does not account for the effects of dark energy, which is thought to be responsible for the current acceleration of the universe's expansion.
