what_are_electrons
Since the electron and the positron are indeed true "point charges" then why are the colliders able to make them collide head-on?
A head-on collision of true point charges refers to a scenario in which two point charges, which are particles with a finite amount of electric charge, come into direct contact with one another, resulting in a collision. This type of collision is often studied in the field of electrostatics, which is the study of electric charges at rest.
During a head-on collision, true point charges will experience a repulsive force due to their like charges. This force will cause the charges to slow down and eventually come to a stop before reversing direction and moving away from each other. The charges will continue to oscillate back and forth until they eventually come to a rest at a distance from each other.
The outcome of a head-on collision between true point charges is influenced by several factors, including the magnitude and sign of the charges, the distance between the charges, and the mass of the particles. These factors determine the strength of the repulsive force and the resulting motion of the charges during the collision.
No, a head-on collision of true point charges cannot result in a merger. This is because point charges are considered to be particles with no physical size, and therefore cannot combine or merge with one another. Instead, the charges will simply interact and then move away from each other.
While head-on collisions of true point charges may seem like abstract concepts, they have real-life applications in fields such as electronics and particle physics. Understanding the behavior of these collisions can help scientists and engineers design and optimize devices such as capacitors, transistors, and particle accelerators.
