Heat capacities of a gas mixture.
In summary, the conversation discusses the pressure and molar heat capacities of a gas mixture composed of 1 gram of hydrogen and 1 gram of helium in a 10 L container at 27°C. The pressure is calculated using the ideal gas law and the number of moles for each gas is determined by dividing their mass by their respective molar masses. The molar heat capacities for the mixture are found by adding the individual heat capacities of each gas, and the value of γ is calculated by dividing the sum of the individual Cp values by the sum of the individual Cv values.
Je m'appelle
120
1 gram of Hydrogen [tex]H_2[/tex] and 1 gram of Helium [tex]He[/tex] are put together into a container of 10 L in volume and at a temperature of 27°C.
(a) Find the pressure
(b) Find the molar specific heat capacities [tex]C_v[/tex] and [tex]C_p[/tex], as well as [tex]\gamma = \frac{C_p}{C_v} [/tex] of this gas mixture.
[tex]n = \frac{m}{M_{molar}}[/tex]
[tex]PV = nRT [/tex]
For a monoatomic gas
[tex]C_v = \frac{3}{2}R [/tex]
For a diatomic gas
[tex]C_v = \frac{5}{2}R [/tex]
For both monoatomic and diatomic gas
[tex]C_p = C_v + R[/tex]
[tex]R = 8,31 \frac{J}{K.mol}[/tex]
[tex]T_{kelvin} = T_{celsius} + 273 [/tex]
(a)
[tex]P = \frac{nRT}{V} [/tex]
Now, the problem here is to find 'n' for the mixture, can I simply find the number of mols of each gas separately and then sum them up?
[tex]n_{He} = \frac{1}{4} = 0.25 [/tex]
[tex]n_{H_2} = \frac{1}{1} = 1 [/tex]
[tex]n_{mixture} = n_{He} + n_{H_2} [/tex]
So,
[tex]P = \frac{1,25 \times 8,31 \times 300}{10} = 311,625[/tex]
Is this correct?
(b)
In order to find out the molar heat capacity for the mixture, can I proceed just as before and work out them separately and them add them up?
[tex]C_v (He) + C_v (H_2) = C_v (Mixture) [/tex]
[tex]C_p (He) + C_p (H_2) = C_p (Mixture) [/tex]
[tex]\gamma_{mixture} = \frac{C_p (He) + C_p (H_2)}{C_v (He) + C_v (H_2)} [/tex]
Is this correct?
Thanks in advance.
No the value of γ is not correct.
The best way to find it is to calculate heat capacity (as opposed to specific heat capacity) - the heat required to raise temperature of whole mixture by 1° C - for the mixture. Then divide it by the no. of moles present in the mixture.
This way you find Cp and Cv for the mixture and then γ.
Related to Heat capacities of a gas mixture.
1. What is the definition of heat capacity?
The heat capacity of a substance is the amount of heat required to raise the temperature of a given quantity of the substance by one degree.
2. How is heat capacity different for gas mixtures compared to pure gases?
Heat capacity for gas mixtures is dependent on the individual heat capacities of the gases present as well as their relative proportions. In contrast, the heat capacity of a pure gas is solely dependent on the amount of substance present.
3. What factors affect the heat capacity of a gas mixture?
The heat capacity of a gas mixture is affected by the molecular weight and specific heat capacities of the individual gases present, as well as the temperature and pressure of the mixture.
4. How is heat capacity calculated for a gas mixture?
The heat capacity of a gas mixture can be calculated by determining the individual heat capacities of the gases present and their relative proportions, and then using a weighted average formula to calculate the overall heat capacity of the mixture.
5. Why is it important to know the heat capacity of a gas mixture?
The heat capacity of a gas mixture is important in understanding how the mixture will respond to changes in temperature and pressure. It is also necessary for accurately predicting the behavior of the mixture in various processes, such as combustion or heat transfer.
  • Classical Physics
