Heat Capacity and Latent Heat question
In summary, the attempt at a solution involves calculating the heat required to melt ice and raise the temperature of melted ice, and equating it to the heat released from dropping the temperature of water. However, the final calculated temperature is lower than expected, and after rearranging the equation, it is determined that the signs in the ΔT term need to be changed to properly represent a heat loss.
stratz
23
A 75.0g ice cube at 0 C is placed in 825g of water at 25 C. Find final temp.
Well none really, this should be simple plugging into to heat equations.
Heat required to melt ice = (0.075kg)(3.33*10^5) = 24975 J
Heat required to melt ice + Heat required to raise temp of melted ice = heat released from dropping temp of water
24975 + (0.075kg)(4186J/kg C)(Tf) = (0.825)(4186J/kg C)(Tf - 25)
Rearrange the equation: Tf ends up being 35.4, which is impossible. What am I doing wrong?
You are expecting the final temperature to be lower than 25C, right? Take a look at your ΔT for the water.
The Tf-25 right? Shouldn't it be that way because the delta T would equal Tf-Ti? Or is the issue that I am supposed to put a negative 1 coefficient in front of the whole sign for Qg = -Ql ? If I do that I get Tf as a negative number though.
If you write ΔT = (25 - Tf) and Tf is less than 25 (as you expect it to be) then the heat quantity you calculate will be a positive value. On the other side of the equation you're raising the temperature of the ice water from zero to Tf, and you wrote its ΔT as (Tf - 0). You are equating two positive values, which is fine.
Suppose you were to move the liquid water expression to the left hand side of the equals so that you sum the two heats. You expect that sum to be zero since no heat is being magically created or destroyed, it's just being moved around. If you move the RHS to the left then, to change its sign you can change the signs in its ΔT term, making it now (Tf - 25), and its corresponding heat will be negative, representing a heat loss.
Related to Heat Capacity and Latent Heat question
1. What is the difference between heat capacity and latent heat?
Heat capacity refers to the amount of heat required to raise the temperature of a substance by a certain amount. It is a measure of how much energy a substance can absorb before its temperature increases. Latent heat, on the other hand, refers to the amount of heat required to change the state of a substance (such as from solid to liquid or liquid to gas) without a change in temperature. It is the energy absorbed or released during a phase change.
2. How is heat capacity and latent heat measured?
Heat capacity is typically measured in units of Joules per Kelvin (J/K) or in specific heat capacity, which is measured in Joules per gram per Kelvin (J/gK). Latent heat is measured in units of Joules per gram (J/g) or in specific latent heat, which is measured in Joules per gram (J/g).
3. What factors affect heat capacity and latent heat?
The heat capacity of a substance is affected by its mass, temperature, and chemical composition. The higher the mass and specific heat capacity of a substance, the higher its heat capacity. The latent heat of a substance is affected by its molecular structure, as well as the temperature and pressure at which the phase change occurs.
4. How does heat capacity and latent heat play a role in temperature changes?
Heat capacity plays a crucial role in determining how much the temperature of a substance will change when heat is added or removed. The higher the heat capacity, the slower the change in temperature will be. Latent heat plays a role in maintaining a constant temperature during a phase change, as the energy absorbed or released during the phase change does not contribute to a change in temperature.
5. How are heat capacity and latent heat important in everyday life?
Heat capacity and latent heat are important in various everyday applications. For example, in cooking, the heat capacity and latent heat of foods determine the cooking time and temperature needed to achieve desired results. In climate science, heat capacity and latent heat play a role in understanding and predicting weather patterns. In engineering, they are important in designing efficient heating and cooling systems. Understanding heat capacity and latent heat also helps us to better understand and mitigate the effects of climate change.
