Heat capacity for a real gas using the ideal gas (zero pressure) equation
In summary, the author suggests that heat capacity can be determined using the principle of corresponding states. They first use the equation C_p(T,P)=\frac{\partial H(T,P)}{\partial T} which is valid for real gas with ideal gas (zero pressure) equation. Next, they use PV=zRT to get the enthalpy difference H(T,P). Finally, they take the partial derivative of the enthalpy difference with respect to temperature at constant pressure to get the heat capacity.
gmaverick2k
42
Summary:: Heat capacity for real gas with ideal gas (zero pressure) equation
I'm looking at this problem and I'm stuck.
I usually question everything but this problem is confusing me.
I don't know how they've made the jump from reduced properties (from generalized Cp charts(?)) to Cp-Cp°=1.70 cal/molK
Usually Cp-Cv=R
I've searched online and it seems Cp-Cv=ZR
This is not the same as Cp-Cp°=ZR, which would mean they've made Cp°=Cv (zero pressure so this is true?)
Has the author got the compressibility factor from the generalised compressibility chart for the Pr and Tr (Z=0.92)
I'm confused how they've made something straight forward
Below is the problem plus the authors solution:
Science news on Phys.org
At constant temperature, the effect of pressure on molar enthalpy is $$\frac{\partial H}{\partial P}=V-T\frac{\partial V}{\partial T}$$This is used in conjunction with $$PV=zRT$$This leads to $$H(T,P)=H(T,0)-RT^2\int_0^P{\frac{1}{P}\frac{\partial z}{\partial T}dP}$$The heat capacity can be determined by taking the partial derivative of the enthalpy with respect to temperature at constant pressure. The resulting integrals are evaluated using the principle of corresponding states.
that's for calculating the departure enthalpy from ideal, i.e. enthalpy difference for real gas. the question is asking for heat capacity only
What did I say in my last sentence? Do you not know how to take the partial derivative of my enthalpy equation with respect to temperature?
I've used these in a previous example from the same book about real gas departure function. This problem in the OP stumped me.
$$C_p=C_p^0-2RT\int_0^P{\frac{1}{P}\frac{\partial z}{\partial T}dP}-RT^2\int_0^P{\frac{1}{P}\frac{\partial^2 z}{\partial T^2}dP}$$
how was this derived? Cp° introduced above?
Are you saying that you agree with the equation I wrote in post #2, but you don't know how I arrived at the equation in post #6?
Starting with the equation in post #2, $$C_p(T,P)=\frac{\partial H(T,P)}{\partial T}$$ and $$C_p^0(T)=\frac{\partial H(T,0)}{\partial T}$$
i figured that out as the functions are H(T,0) for Cp°. how did you get the last term in post#6?
Chestermiller said:
This equation assumes that the partial derivative of z with respect to T at constant P is independent of P (which is incorrect).
i think for that example the pressure remained the same at 25atm and Z was interpolated. the gas (nitrogen) changed from 1atm and 298K to 25atm and 973K, i.e. simultaneous change in T & P. looking to see if departure from ideal was significant at end conditions, not so in this case.
It's just math. Taking the partial derivative of the overall term with respect to temperature.
thanks my calculus is very rusty, hence brushing up on my thermo. i think its the chain rule for partial derivatives. as long as I'm satisifed and made everything water tight, I'm happy. thanks again
i'm stuck on finalising the equation
how the author arrived at 1.7cal/molK is tricky. do i have to integrate out the partial derivatives? I'm confused, the ln0 term is also spitting out errors
Your math is incorrect in several respects. What is the exact word-for-word statement of the problem you are trying to solve?
hi the top part which isn't hand written
OK. There must be a chart in the book of ##\frac{C_p-C_p^0}{R}## as a function of reduced temperature and reduced pressure. This is what they must have used.
its from the american professional engineers exam set by Randall robinson. the accompanying reference manual doesn't include this chart. the only chart included in the thermo section is the nelson-obert generalized compressibility chart
Well, you are going to need that chart I mentioned to solve it, or you are going to have to numerically (manually) differentiate the enthalpy departure function at the desired reduced pressure with respect to reduced temperature.
is there a way to translate this from the chart in post #16?
Something like that, but your charts don't have enough resolution to get what you want. See Fig. 6.6 of Introduction to Chemical Engineering Thermodynamics by Smith and Van Ness.
i assume its this from the 8th ed. So Tr = 0.8 and Pr = 0.1.. more confused the deeper i go
actually from older 4th ed.
say the left hand term is -0.18?
The partial derivative of the ordinate with respect to the reduced temperature (evaluated at reduced temperature of 0.8) at constant reduced pressure (abscissa = 0.1) is the residual heat capacity divided by R at the desired conditions. The partial derivative evaluated this way should come out to about +0.85 (dimensionless) if their answer is correct.
so,
Ru = 1.987 cal/molK
=> agrees with solution
ok fine, still need to clarify the jump between the generalized correlation chart to how +0.85 was obtained
If ##y(p_r,T_r)## is the ordinate on the plot, then a 2nd order accurate numerical approximation to the residual heat capacity is $$\frac{C_p^R}{R}=\frac{y(0.1,0.9)-y(0.1,0.7)}{0.9-0.7}$$
From the graph, it looks like the authors overestimated the heat capacity departure (aka residual heat capacity) by a factor of about 2.
it looks like there's another graph with the superscript 1 for the ordinate. i think this takes the acentric factor into account. for chlorine ω=0.073
Likes Chestermiller
You're right. It looks like that would substantially reduce the disagreement.
  • #31
i'm confused, the ordinate is
with enthalpy, H explicitly stated. how have you arrived at this
? where has the critical temp, Tc term disappeared to?
I've also found this equation in perry's but nothing to convert to cp:
  • #32
gmaverick2k said:
i'm confused, the ordinate is View attachment 285928with enthalpy, H explicitly stated. how have you arrived at this View attachment 285929? where has the critical temp, Tc term disappeared to?
$$\frac{\partial \left(\frac{H^R}{RT_c}\right)}{\partial T_r}=\frac{\partial \left(\frac{H^R}{RT_c}\right)}{\partial (T/T_c)}=\frac{1}{R}\frac{\partial H^R}{\partial T}=\frac{C_p}{R}$$
Regarding Eqn. 4-168, you differentiate each term separately
Likes gmaverick2k
  • #33
ok, using plot digitizer for points on both graphs..
Yes, it looks like the author has overestimated the heat capacity by a factor of two assuming this is the correct methodology. I wish authors didn't skip on the working outs. i guess the fun is in the connecting of dots..
Thanks
Likes Chestermiller
FAQ: Heat capacity for a real gas using the ideal gas (zero pressure) equation
What is heat capacity for a real gas?
Heat capacity for a real gas is the amount of heat energy required to raise the temperature of a gas by 1 degree Celsius. It is a measure of the gas's ability to store thermal energy.
How is heat capacity different for a real gas compared to an ideal gas?
In an ideal gas, heat capacity is constant and does not change with temperature. However, for a real gas, heat capacity is not constant and can vary with temperature, pressure, and volume.
What is the ideal gas (zero pressure) equation?
The ideal gas (zero pressure) equation is PV = nRT, where P is pressure, V is volume, n is the number of moles of gas, R is the ideal gas constant, and T is temperature.
How is the ideal gas (zero pressure) equation used to calculate heat capacity for a real gas?
The ideal gas (zero pressure) equation can be rearranged to solve for heat capacity (Cp) by using the equation Cp = (nR)/(γ-1), where γ is the adiabatic index of the gas. This equation can be used to calculate heat capacity for a real gas at zero pressure.
What factors can affect the heat capacity of a real gas?
The heat capacity of a real gas can be affected by various factors such as temperature, pressure, volume, and the nature of the gas molecules. It can also vary depending on the type of process (e.g. isobaric, isochoric, or adiabatic) that the gas undergoes.
