Heat capacity (statistical physics)
In summary, the conversation is discussing the first assignment for a course on statistical physics. The system being studied has 3 energy levels with different degeneracies. The goal is to find the heat capacity of the system. The conversation also touches on the use of the partition function and how it can be used to determine other thermodynamic quantities. The conversation also includes a link to a website for further information.
broegger
257
Hi. I've just started a course on statistical physics and the first assignment is this:
A system possesses 3 energy levels, [tex]E_1 = \epsilon,[/tex] [tex]E_2 = 2\epsilon[/tex] and [tex]E_3 = 3\epsilon[/tex]. The degeneracy of the levels are g(E1) = g(E3) = 1, g(E2) = 2. Find the heat capacity of the system.
I've forgotten all this thermodynamics stuff, so I would appreciate some hints :-)
Anyone? Please :rolleyes:
If you are given a description of a system, what quantity do you first compute, from which you can determine other thermodynamic quantities ?
Yes, yes, the partition function, I know :-)
sum over states to get Q
Q= exp{-B.E) + 2exp{-B.2E} + exp{-B.3E}
B=kT Q=partition E=energy (two in front of second term beacuse of degenercy)
U= - Diff (lnQ) w.r.t (B)
U= internal energy prof can be found ( http://www.chem.arizona.edu/~salzmanr/480b/statt01/statt01.html)... if you are interested
gives U= E.exp(-B.E) + 4E.exp(-B.2E) + 3E.exp(-B.3E)
makes sense highest energy has least probabilty of being populated but contributes three times as much to internal enrgy when it is. same would apply to the middle state but there is two of them so it is four instead of two.
Related to Heat capacity (statistical physics)
1. What is heat capacity?
Heat capacity is the amount of heat required to raise the temperature of a substance by one degree Celsius or Kelvin. It is a measure of the ability of a substance to store heat energy.
2. How is heat capacity different from specific heat?
Heat capacity is an extensive property, meaning it depends on the amount of substance present. Specific heat, on the other hand, is an intensive property and is defined as the heat capacity per unit mass. This means that specific heat is a constant value for a given substance, while heat capacity can vary depending on the amount of the substance.
3. What factors affect the heat capacity of a substance?
The heat capacity of a substance is affected by its mass, composition, and phase, as well as temperature and pressure. For example, the heat capacity of a gas is significantly higher than that of a solid due to the increased freedom of movement of its particles.
4. What is the relationship between heat capacity and temperature?
The heat capacity of a substance generally increases as temperature increases. This is because at higher temperatures, the substance's particles have more energy and are able to store more heat energy. However, this relationship is not linear and can vary depending on the substance and its phase.
5. How is heat capacity measured in experiments?
Heat capacity can be measured experimentally by heating a known mass of a substance and measuring the change in temperature. The heat capacity can then be calculated using the formula C = Q/m∆T, where C is heat capacity, Q is the amount of heat added, m is the mass of the substance, and ∆T is the change in temperature.
