Heat Conduction Initial Problem Set Up
In summary, the conversation discusses four different heat conduction scenarios and their corresponding mathematical formulations. For each scenario, the initial temperature, heat generation rate, and boundary conditions are given. The solutions for each scenario involve partial differential equations and boundary conditions that must be satisfied. There is some uncertainty about the boundary condition for the infinite side in problem b and the simplicity of the solutions for problems c and d. Guidance and clarification on these issues are requested.
timman_24
52
I need to set up the mathematical formulation of the following heat conduction scenarios:
a) A slab in [itex]0\le x \le L[/itex] is initially at a temperature f(x). For times t>0 the boundary at x=o is kept insulated and the boundary at x=L dissipates heat by convection into the medium at zero temperature.
b)A semi-infinite region [itex]0\le x \le \infty[/itex] is initially at temperature f(x). For times t>0, heat is generated in the medium at a constant rate of g (constant), while the boundary at x=0 is kept at zero temperature.
c) A solid cylinder [itex]0\le r \le b[/itex] is initially at a temperature f(r). For times t>0 heat is generated in the medium at a rate of g(r), while the boundary at r=b dissipates heat by convection into a medium at zero temperature.
d) A solid sphere [itex]0\le r \le b[/itex] is initially at temperature f(r). For times t>0, heat is generated in the medium at a rate of g(r), while the boundary at r=b is kept at a uniform temperature T'.
2. The attempt at a solution
Problem a)
Solution:
[itex]\frac{1}{\alpha}\frac{\partial T}{\partial t}=\frac{\partial ^2 T}{\partial x^2 }[/itex]
IC: T(x,0)=f(x)
BC:
1.) Insulated Boundary:[itex]q\prime(0,t)=0[/itex]
2.) Convection Boundary:[itex]k\frac{\partial T}{\partial x}|_L =-hT(L,t)[/itex]
Problem b)
Solution: [itex]\frac{1}{\alpha}\frac{\partial T}{\partial t}=\frac{\partial ^2 T}{\partial x^2 }+\frac{1}{k}g[/itex]
IC: T(x,0)=f(x)
BC:
1.) T(0,t)=0
2.) Is there another boundry for the [itex]x=\infty[/itex]?
Problem c)
Solution: [itex]\frac{1}{\alpha}\frac{\partial T}{\partial t}=\frac{\partial ^2 T}{\partial r^2 }+\frac{1}{k}g(r)[/itex]
IC: T(r,0)=f(r)
BC:
[itex]k\frac{\partial T}{\partial r}=-hT[/itex]
Problem d)
IC: T(r,o)=f(r)
BC: T(b,t)=T'
3. Discussion
I do not know if I need another boundary condition on question b for the infinite side, I don't know what to do there. Also, c and d should be rather easy to express due to symmetry, but it almost seems too easy. Is there anything I am missing in my mathematical representations of the physical systems described? Any guidance would be very appreciated.
Any thoughts?
FAQ: Heat Conduction Initial Problem Set Up
What is heat conduction?
Heat conduction is the transfer of thermal energy through a material or between two materials that are in direct contact. This transfer occurs due to a temperature difference between the materials.
How is heat conduction measured?
Heat conduction is typically measured using a thermal conductivity meter, which measures the rate at which heat flows through a material. This is often represented by the symbol "k" and is measured in units of watts per meter per Kelvin (W/mK).
What factors affect heat conduction?
The rate of heat conduction is affected by several factors, including the thermal conductivity of the material, the temperature difference between the materials, the thickness of the material, and the surface area of contact between the materials. Other factors such as humidity, density, and porosity can also play a role.
What is an "initial problem set up" in heat conduction?
An initial problem set up in heat conduction refers to the initial conditions and parameters that are defined in a mathematical model or simulation of heat conduction. This includes properties such as the thermal conductivity of the materials, the boundary conditions, and the initial temperature distribution.
How is heat conduction used in scientific research?
Heat conduction is used in various fields of scientific research, including materials science, thermodynamics, and environmental engineering. It is often used to study the transfer of heat in different materials and to analyze the thermal behavior of systems. It is also used in the design and optimization of thermal systems and processes, such as heat exchangers and refrigeration systems.
