zb23
- 26
- 2
What is the difference on microscopic level between electric current and heat current(conduction)?
Please understand my question more deeplyvanhees71 said:Electric current describes a transport of electric charge and the heat current a transport of heat energy.
I am not talking about those trivial stuffCharles Link said:It may be of interest that with electric current, there is a flow of charged particles, (electrons in the direction opposite the current flow), and the result is magnetic fields are produced (Biot-Savart), and capacitor plates can become charged.
With heat current, there is no overall transport of particles. It is simply a flow of the kinetic energy.
It doesn't matter. Sorry for bothering you.vanhees71 said:Then you have to more clearly express your question :-).
It seems like a good question you asked. Without the details of the "trivial stuff", there perhaps isn't much difference between electric current flow and energy flow.zb23 said:I am not talking about those trivial stuff
Please put more effort into your question. The answer you got was the answer to the question you asked. We cannot read your mind, so we don’t know what deep question you are asking unless you put in the effort to formulate it clearly and write it down. All we can do is respond to what you write. We are physicists, not psychics.zb23 said:Please understand my question more deeply
Heat current on a microscopic level refers to the flow of thermal energy between particles at the molecular level. It is the transfer of heat from areas of high temperature to areas of low temperature.
Heat current can be measured by using techniques such as calorimetry, which measures the change in temperature of a substance as heat is transferred. It can also be measured indirectly through the use of equations such as Fourier's Law.
The rate of heat current on a microscopic level is affected by various factors, including the temperature difference between two points, the thermal conductivity of the material, and the distance between the particles.
Heat current can cause particles to vibrate and move faster, which can lead to changes in the physical properties of the material. It can also affect the rate of chemical reactions and phase changes.
On a microscopic level, heat current is responsible for the transfer of heat between particles. This transfer of energy continues until a state of thermal equilibrium is reached, where there is no longer a temperature difference between the particles.
