Heat energy: statistical mechanics vs atomic orbitals
In summary, statistical mechanics accounts for all of the heat energy in a gas by the kinetic energy of the molecules. However, the thermal excitation of the electrons out of the ground state to higher atomic orbitals is quite minimal at ordinary temperatures for a gas, so there is not a significant contribution to the specific heat from the electrons being thermally excited into higher orbitals.
Zebulin
Normally, I prefer to do my own research, but I'm drawing a blank on this one. Any help would be appreciated.
My understanding is that statistical mechanics accounts for all of the heat energy in a gas by the kinetic energy of the molecules. I also understand that atomic orbitals have different energy levels, and because of the links between heat, radiation, and orbitals, I assume that the atomic orbitals must contribute to the heat energy of a gas. But this seems to be a contradiction with statistical mechanics where all of the heat energy is in kinetic energy.
The thermal excitation of the electrons out of the ground state to higher atomic orbitals is quite minimal at ordinary temperatures for a gas. Thereby, there is not a significant contribution to the specific heat from the electrons being thermally excited into higher orbitals. ## \\ ## To quantify, a typical electronic transition would be on the order of ## \Delta E=2 eV ##. Statistically, we can determine the ratio of the probability of an electron being in the excited state (at ## \Delta E=2 \, eV ##) vs. the ground state at ## T=300 K ## : That ratio is ## p=e^{-\Delta E/(k_b T)}=e^{-2(1.602E-19)/((1.381 E-23) (300))} ## where ## k_b ## is Boltzmann's constant. ## \\ ## Basically, all of the electrons can be assumed to remain in the ground state in regards to computations of the specific heat. ## \\ ## If we had one mole of a gas, the energy contribution to the above would be ## E=(6.02 E+23)(2)(1.602 E-19)(p) \, Joules ##. The factor ## p ## is so small that this number for the energy ## E ## is miniscule compared to the kinetic energy of the atoms, ## E_{kinetic}=(3/2)nRT ##, where ## R=(4.184)1.987 \, Joules/(mole-degree \, K) ## with ## n=1 ## mole. ## \\ ## Editing note: Initially I had the incorrect exponent on Boltzmann's constant.
Likes Zebulin
Whoa, if my calculations are right, that's about 2.6 x 10^-34. That's really small...
Likes Charles Link
It really is a good question by the OP @Zebulin, but the specific heat contribution from the excited electron states in a monatomic gas is so small that most Statistical Physics textbooks don't even consider it. In Reif's Statistical Physics book, on p.251 (chapter 7.6 Simple Applications), he states "For an ideal monatomic gas the entire energy is kinetic, so that the mean energy per mole of gas is simply ## \bar{E}=N_a (\frac{3}{2}k T)=\frac{3}{2}RT ## ". ## \\ ## It really is a heads-up question to ask "what about the excited states"? In diatomic molecules the rotational modes are excited states that do come into play, and at very high temperatures even the vibrational modes of diatomic molecules can make a contribution to the specific heat. (The energy of a typical excited rotational state is much much less than 2 eV, so that atoms with excited rotational states are quite abundant and the number increases considerably with an increase in temperature.)
Likes Zebulin
Wow. You guys are great. Thanks.
Likes Charles Link
Related to Heat energy: statistical mechanics vs atomic orbitals
1. What is the difference between statistical mechanics and atomic orbitals in relation to heat energy?
Statistical mechanics is a mathematical framework used to describe the behavior of a large number of particles, such as atoms or molecules, in a system. It is used to study the relationship between macroscopic properties, like temperature and pressure, and the microscopic behavior of the particles. On the other hand, atomic orbitals refer to the specific energy levels that electrons can occupy in an atom. These energy levels are determined by the quantum mechanics of the atom and are used to explain the properties of elements and their interactions. In terms of heat energy, statistical mechanics looks at the overall behavior of a system, while atomic orbitals focus on the behavior of individual particles.
2. How does statistical mechanics explain the transfer of heat energy?
According to statistical mechanics, heat energy is transferred through the random motion of particles. When two objects with different temperatures are in contact, the particles in the hotter object have a higher average kinetic energy and collide with the particles in the colder object. This results in the transfer of energy from the hotter object to the colder one, until both objects reach thermal equilibrium.
3. Can atomic orbitals affect the heat energy of a substance?
Yes, atomic orbitals can affect the heat energy of a substance. The arrangement of electrons in an atom's orbitals determines its electronic structure, which in turn affects its physical and chemical properties. For example, atoms with half-filled or completely filled orbitals tend to be more stable and have lower heat energy compared to atoms with partially filled orbitals.
4. How do statistical mechanics and atomic orbitals relate to the heat capacity of a substance?
Statistical mechanics provides a theoretical framework for calculating the heat capacity of a substance, which is the amount of heat energy required to raise the temperature of a substance by one degree. It takes into account the number of particles, their interactions, and their energy levels. On the other hand, atomic orbitals play a role in determining the electronic structure of a substance, which can affect its heat capacity. For example, substances with more complex atomic structures tend to have higher heat capacities.
5. Can statistical mechanics and atomic orbitals be used to predict the behavior of heat energy in different states of matter?
Yes, both statistical mechanics and atomic orbitals can be used to predict the behavior of heat energy in different states of matter. Statistical mechanics can help explain the behavior of heat energy in gases, liquids, and solids by considering the movement and interactions of particles. Atomic orbitals, on the other hand, can help predict the heat energy of substances in different phases by considering their electronic structures and how they may change with temperature. Together, these theories provide a comprehensive understanding of the behavior of heat energy in different states of matter.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
