Heat Equation and Energy Balance
In summary, the conversation discusses the difference between the energy balance equation and the energy equation in a steady state, constant property, laminar flow of fluid between two flat surfaces. After simplification, the energy balance equation is found to be incorrect and the correct equation can be obtained by multiplying the energy equation by the average velocity and integrating with respect to y between the two boundaries. The conversation also explores the use of a constant heat flux as a boundary condition and the importance of recognizing the general mathematical form of the solution. Finally, there is a discussion about the interpretation of vx as the average velocity or the local velocity.
member 428835
Hi PF!
For the longest time I thought an energy balance and the heat equation were identical procedures. However, recently I saw an example of a steady state, constant property, laminar flow of fluid between two flat surfaces where the top surface moves in the ##x## direction at ##V_1## and we assume fully developed hydrodynamical and thermally. The distance between plates is ##a## and the top surface is insulated with temperature ##T_o## and bottom surface has constant heat flux ##q''##.
After an energy balance I arrive at $$\frac{\partial T}{\partial x} = \frac{q''}{a V_1 \rho c}$$
But the energy equation gives (after simplification) $$\frac{\partial T}{\partial x} = \frac{\alpha}{V_1}\frac{\partial^2 T}{\partial y^2}$$
And clearly the right hand side of these two equations, while equal, are represented quite differently. Ultimately we find $$ak\frac{\partial^2 T}{\partial y^2}=q''$$ but I thought flux was equal to ##-k \nabla T=-k\partial_yT## for this problem.
Can someone please help me understand?
Thanks so much!
The "energy balance equation" is incorrect. The V1 should be the average velocity in the x direction, T should be the "mixing cup average" temperature, and the derivative should be an ordinary derivative. You can obtain the correct "energy balance equation" by multiplying both sides of the "energy equation" by ##V_1(y) \rho c## and integrating with respect to y between the two boundaries.
You're totally correct, sorry for this. However, if we are thermally fully developed isn't it true ##\partial_xT_{mean} = \partial_x T##?
So is the equality I've concluded with wrong? Namely, ##akT_{yy} \neq q''## since the velocity should be an average in the energy balance but an actual velocity profile in the energy equation?
Ah. I now see what this problem is about that you are trying to solve. You are trying to determine the asymptotic temperature variation in a constant heat flux problem at large values of x. I have lots of experience with this kind of problem, and have solved many like it during my career.
The key to getting a solution is to a problem like this is to recognize the general mathematical form that the solution must take, to wit:
$$T=T_0+Kx+f(y)$$
Note that it is a function of x plus a function of y. By making use of the energy differential equation and the boundary conditions, you need to determine the constant K and the function f(y). The function f(y) must be such that its mixing cup average is zero.
chet
Likes member 428835
Hi, Chet and Josh! The way I'm interpretting the constant heat flux statement is as a boundary condition for y = 0, not that the heat flux for all y is constant. Taking this approach, the energy balance can be written as
[tex]\Delta y W (\rho v_x \hat{H} |_x - \rho v_x \hat{H} |_{x+\Delta x}) + \Delta x W (q'' |_y - q'' |_{y+\Delta y}) = 0[/tex]
Rearranging and taking limits
[tex]\rho v_x \frac{d \hat{H}}{dx} + \frac{d q''}{dy} = 0[/tex]
Inserting the definition of enthalpy and Fourier's Law
[tex]\rho v_x c \frac{\partial T}{\partial x} - k \frac{\partial^2 T}{\partial y^2} = 0[/tex]
[tex]\frac{\partial T}{\partial x} = \frac{k}{\rho c v_x} \frac{\partial^2 T}{\partial y^2} = \frac{\alpha}{v_x} \frac{\partial^2 T}{\partial y^2}[/tex]
Taking this approach, the energy balance now agrees with the energy equation. However, as Chet pointed out, vx is the average velocity, not the velocity of the upper plate.
Actually, in your equations, ##v_x## is the local velocity at y, ##v_x(y)##.
The problem that Josh is solving is analogous to the problem of laminar flow in a pipe with a constant wall heat flux at all axial locations x > 0. For long distances down the pipe, the temperature approaches an asymptotic profile in which the radial temperature variation stops changing with x. This problem is solved in BSL.
Hi MexChemE!
Regarding you energy balance:
I don't think ##q''## is evaluated at both endpoints of the energy balance (since this flux is imposed on the base plate. My balance looks like $$W \Delta x q'' + V_{mean} \rho c a W T(x) = V_{mean} \rho c a W T(x + \Delta x) \implies\\ q'' = \rho c a V_{mean} \frac{d T}{d x}$$
Is this correct?
Likes MexChemE
joshmccraney said:
Hi MexChemE!
Is this correct?
Yes. dT/dx is the value of the constant K in my post #4. So you've already determined that. Now, all you need to do is determine the function f(y).
Awesome, but I have a few questions. First, when computing this infinitesimal mass balance technically ##T(x,y)## is actually ##T(x,y-mean)##, where ##y-mean## implies the average temperature in ##y##, right?
Secondly, if this mass balance is correct, why isn't it recognizably identical to the energy equation (if my understanding is correct, the energy equation is a mass balance once you apply the divergence theorem to the flux); is this correct? Please feel free to elaborate on this point.
And lastly, how would anyone know to come up with the ansatz you proposed for the solution form?
T(x,y) is the temperature at the coordinates location x,y.
The "recognizable" heat balance equation is:$$\rho C_p v(y) \frac{\partial T}{\partial x}=k\frac{\partial^2 T}{\partial y^2}$$
where ##v(y)=V_1\frac{y}{a}##
If we integrate this equation between y = 0 and y = a, we obtain:
$$\rho C_p\frac{d [\int_0^a{v(y)T(x,y)dy}]}{dx}=k\left(\frac{\partial T}{\partial y}\right)_a-k\left(\frac{\partial T}{\partial y}\right)_0\tag{1}$$
The mixing cup temperature at location x is defined as:
$$\bar{T}(x)=\frac{\int_0^a{v(y)T(x,y)dy}}{\int_0^a{v(y)dy}}=\frac{\int_0^a{v(y)T(x,y)dy}}{\bar{v}a}\tag{2}$$
So, combining Eqns. 1 and 2, we obtain:
$$\rho C_p\bar{v}a\frac{d\bar{T}}{dx}=q''\tag{3}$$So this equation follows directly as a result of integrating the "recognizable" heat balance.From Eqn. 3, we see that the mixing cup temperature must be rising at a constant rate with x, irrespective of what the temperature is doing in the y direction. So, $$\bar{T}(x)=T_0+\frac{q''}{\rho C_p\bar{v}a}x\tag{4}$$
Once the temperature profile becomes fully developed, the temperature profile between y = 0 and y = a is no longer changing with x. So, once this region is reached, ##T=\bar{T}(x)+f(y)##
Likes member 428835
Oh, that makes more sense, I was totally misunderstanding the implications of the heat flux. Initially, the reason I suggested the balance I wrote was that it would agree with the energy equation, but it was the energy equation what had to be adapted to the problem, not the balance. I should've known better, I'm always more inclined to set up the balance personally instead of using the equations when solving this kind of problem.
By the way, I enjoyed your last post, specifically, the integration wrt y of the energy equation and how it ended up agreeing with Josh's balance. Awesome skills!
Having tons of practical experience helps a little.
Chet
Likes MexChemE
Sorry, I was unclear in what I meant by ##T(x,y-mean)##. I am asking if on this energy balance, since we are slicing this up pieces of ##\Delta x## and not ##\Delta y##, the ##y## direction quantities must be averaged? So the temperature we use in the balance must be ##1/a \int_0^a T(x,y) \, dy## rather than simply ##T(x,y)##; is this correct?
I do have one more question: when setting up the energy balance, initially I did not include a flux term for the stream-wise direction. Now I'm not sure why. Can you explain why there wouldn't also be flux term ##-aWk\partial_xT(x,y)## entering and ##-aWk\partial_xT(x+\Delta x,y)## leaving?
I agree with MexChemE, excellent explanations!
No. T(x,y) is what I said it was. If you are talking about the integrated average heat balance involving the mixing cup average temperature, this is not a function of y, and it is not the temperature at the average y either.
The effect of heat conduction in the x direction is usually neglected compared to the conduction in the thickness direction (in this case, y), because the temperature gradients in the x direction are much smaller. Dimensional analysis also elucidates this same result. Only in the case of liquid metals have I ever heard of conduction in the axial direction being included.
So if I were to include this flux term in the energy balance we would have
$$-aWk\partial_xT(x)+W \Delta x q'' + V_{mean} \rho c a W T(x) = -aWk\partial_xT(x+\Delta x,y)+V_{mean} \rho c a W T(x + \Delta x) \implies\\ q'' = \rho c a V_{mean} \frac{d T}{d x} - k\frac{d^2T}{dx^2}$$
Since ##q''## is a vertical flux, would we scale it as ##k/y^2## and conclude that it dominates over the ##T_{xx}## term since, by the channel geometry, ##x>y\implies x^2 \gg y^2 \implies 1/y^2 \gg 1/x^2## and thus ##q''## dominates over ##T_{xx}##?
Also, I've been very lazy with partial and ordinary derivatives. Technically all should be partial derivatives in this post, right?
No. Start with the differential equation and integrate with respect to y. The last term here is incorrect.
Basically, yes.
Except in the equation obtained by averaging over y, where its dTbar/dx (for the case where the axial conduction is neglected).
Isn't it true that neither ##q''## nor ##\rho c V_{mean} T_x## are functions of ##y##? If so, integrating gives an ##a## multiplier. If that balance is incorrect, how would I set up that flux term?
The balance is correct, but there should be an "a" in front of the T'' term. And, of course, this only applies to the region where the temperature profile is fully developed. Plus, that T'' term doesn't have any boundary conditions specified on either end.
You said earlier that the last term was incorrect. Was the ##a## what you were referring to?
yes.
Related to Heat Equation and Energy Balance
1) What is the heat equation and how is it used in science?
The heat equation is a mathematical representation of the flow of heat through a material. It is used in science to model and understand heat transfer in various systems, such as the Earth's atmosphere and the human body.
2) How does the heat equation relate to energy balance?
The heat equation is an important component of the energy balance equation. It helps us understand how energy is transferred and distributed within a system, and how changes in temperature can affect the overall energy balance.
3) What are the variables and constants in the heat equation?
The variables in the heat equation include temperature, time, and the thermal conductivity of the material. The constants include the density and specific heat capacity of the material.
4) How is the heat equation solved and what are its limitations?
The heat equation can be solved using various numerical methods, such as finite difference or finite element methods. However, it has limitations in complex systems where other factors, such as fluid flow, must also be considered.
5) How is the heat equation used in real life applications?
The heat equation is used in a wide range of real-life applications, including weather forecasting, climate modeling, and designing heating and cooling systems. It is also used in medical research to understand heat transfer in the human body and develop treatments for conditions such as burns and hypothermia.
  • Mechanical Engineering
  • Differential Equations
