Physgeek64
- 247
- 11
A stainless-steel wire is 0.1 mm in diameter and 1 m long. If the outside of the
wire is held fixed at 20◦C, estimate the steady-state current passing through the wire
when the stainless steel at the centre of the wire begins to melt.
The solution to the heat equation will be ##T=-\frac{Hr^2}{4\kappa} +c## The ln term disappears because the temperature must be finite at the origin.
H is the source term ##H=\frac{I^2R}{Al}= \frac{I^2\rho}{A^2}## where A is the c.s.a of the wire
Since the outer surface of the wire is held at 20 degrees
##c=293+\frac{Ha^2}{4\kappa} ## where a is the radius of the wire
##T=293+\frac{Ha^2}{4\kappa}-\frac{Hr^2}{4\kappa}##
Therefore the temperature at the centre of the wire is
##T=293+\frac{Ha^2}{4\kappa}##
setting ##T=1400## which we are told is the melting point of the wire we get
##1380 = \frac{I^2\rho a^2}{\pi^2 a^4 4\kappa}##
##I=\sqrt{\frac{4(1380) \pi^2 a^2 \kappa}{\rho}}##
However this isn't right but i can't see where I've gone wrong
Many thanks
