Heat flux through a material with variable heat conductance
The discussion focuses on calculating heat flux through a rod with variable heat conductance, specifically where conductivity is defined as K = aT. The initial approach incorrectly assumes a constant temperature gradient, leading to an incorrect expression for thermal resistance. The correct method involves recognizing that the temperature varies non-linearly along the rod, necessitating the use of the steady-state heat equation. The key takeaway is that the relationship between temperature and position must account for the variable conductivity, which complicates the analysis. Understanding this concept is crucial for accurately determining temperature distribution in materials with variable conductance.
shivamchouhan5077
Can anyone explain how temperature at any point on the rod (or any material in general) varies with distance when conductivity is variable. This question came to my mind from my physics test last week, I got the following question in it.
*A rod of length ##l## and cross-sectional area ##A## has a variable conductivity given by ##K = aT##, where ##a## is a positive constant and ##T## is temperature in kelvin. Two ends of the rod are maintained at temperature ##T_1## and ##T_2## ##(T_1 > T_2)##. Heat current flowing through the rod will be*:
The answer given in the answer key was $$\frac{Aa\left(T_1^2-T_2^2\right)}{2l}$$ I could not solve the question during the test. But now the test is over and I want to find what mistakes I made.So as I was analyzing the question, trying to solve this on my own at home, I spent hours but somehow my answer didn't match with the answer key.
$$I_H = \frac{T_1-T_2}{R_{total}}$$
My first thought was that as the heat current ##I_H## is going to be constant at any cross section of the rod, by the equation of continuity, as the area of cross section is constant throughout the rod.
So using: (where ##R_{total}## is the total thermal resistance of the rod) $$I_H = \frac{T_1-T_2}{R_{total}}$$
If I can find net thermal resistance of the rod, I can solve the question.
We know that thermal resistance is given by:$$R = \frac{l}{KA}$$
For a small thermal resistance of an element of rod of length ##\mathrm dx## at a distance x from ##T_1## $$\mathrm dR = \frac{\mathrm dx}{\left(aT\right)A}$$
Now we need to find a relation between ##T## and ##x##.
By using the concept of temperature gradient, We know that,$$T_1-T = \frac{x}{l}(T_1-T_2)$$
Therefore, $$T = T_1- \frac{x}{l}(T_1-T_2)$$
On put the value of ##T##, $$\int_0^R dR = \frac{1}{aA}\int_0^l \frac{1}{T_1-\frac{x}{l}(T_1-T_2)} dx$$
On simplification, $$R = \frac{l}{aA(T_1-T_2)} ln\left(\frac{T_1}{T_2}\right)$$
On put ##R## in the equation ##1##, $$I_H = \frac{aA(T_1-T_2)^2}{l \times ln\left(\frac{T_1}{T_2}\right)}$$
So this was my answer, but as you know my answer is somehow wrong according of the answer key. Although I have now understood that the mistake in my solution was that temperature gradient is not constant throughout the rod. But still, I don't the concept about how can we find temperature at any point on the rod (or any material in general)
shivamchouhan5077 said:
Homework Statement: Can anyone explain how temperature at any point on the rod (or any material in general) varies with distance when conductivity is variable. This question came to my mind from my physics test last week, I got the following question in it.
*A rod of length $l$ and cross-sectional area $A$ has a variable conductivity given by $K = aT$, where $a$ is a positive constant and $T$ is temperature in kelvin. Two ends of the rod are maintained at temperature $T_1$ and $T_2$ $(T_1 > T_2)$. Heat current flowing through the rod will be*:
Relevant Equations: $$I_H = \frac{T_1-T_2}{R_{total}}$$
My first thought was that as the heat current $I_H$ is going to be constant at any cross section of the rod, by the equation of continuity, as the area of cross section is constant throughout the rod.
So using: (where $R_{total}$ is the total thermal resistance of the rod) $$I_H = \frac{T_1-T_2}{R_{total}}$$
For a small thermal resistance of an element of rod of length $\mathrm dx$ at a distance x from $T_1$ $$\mathrm dR = \frac{\mathrm dx}{\left(aT\right)A}$$
Now we need to find a relation between $T$ and $x$.
This assumes that temperature is a linear function of x, which, for this material is incorrect.
Likes shivamchouhan5077
I think you can start with the (reduced) steady state heat equation:
$$ \frac{\partial}{\partial x} \left( k \frac{\partial T}{\partial x} \right) = 0 $$
Work forward from there? With regards to the partial derivatives ##k## is a function of temperature ##T##, which is a function of ##x##. I think you have to keep that in mind.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
