Heat is conserved differential equation
It takes into account the two mechanisms of heat transport: conduction and convection. Heat radiation is neglected in this model. In summary, the conservation of heat in a fluid with constant density and specific heat leads to a differential equation for the temperature field, taking into account heat transport through conduction and convection.
nrod2712
Assume there is a non-uniform temperature field T(x,y,z,t) in a fluid moving with velocity v(x,y,z,t). Assume there are no sources of heat and take the following parameters of the fluid to be constant: density p: specific heat c; conductivity k.
Assume that generation of heat by dissipation of mechanical energy is negligible. Because the density is constant, thermal energy (heat) and mechanical energy are then seperatly conserved.
Making these assumptions, begin with the statement "heat is conserved" and end with the differential equation for the temperature, using the following physical model:
(1.) The heat per unit volume is pcT:
(2.) Heat radiation is negligible, so transport of heat is carried out by two mechanisms:
(A.) Conduction. heat flow due to conduction is proportioal to the temperature gradient and directed opposite to it, i.e. it is -k(del)T.
(B.) Convection. Heat flow due to the fluid motion is pcTv.
I know because heat is conserved that the same amount of heat going in an area must come out so I am going to have to use a flux integral, but i have no idea how to set it up. Any suggestions??
Answer:Heat is conserved, so the rate of change of thermal energy in a given volume must be equal to the sum of all the heat fluxes entering and leaving the volume. This can be expressed mathematically as a flux integral:d/dt (pcT) = ∫(-k∇T + pcTv).dA Rearranging this equation and using Divergence theorem, we get:∇.(-k∇T + pcTv) = d/dt(pcT) This is the differential equation for the temperature field T(x,y,z,t).
FAQ: Heat is conserved differential equation
What is the Heat is conserved differential equation?
The Heat is conserved differential equation is a mathematical expression that describes the transfer of heat in a system. It states that the rate of change of heat in a system is equal to the difference between the heat entering and leaving the system.
What does the Heat is conserved differential equation represent?
The Heat is conserved differential equation represents the conservation of energy in a system. It shows how energy is transferred from one part of the system to another through the transfer of heat.
What are the variables in the Heat is conserved differential equation?
The variables in the Heat is conserved differential equation are time, temperature, and thermal conductivity. Time represents the rate of change of heat, temperature represents the amount of heat in the system, and thermal conductivity represents the ability of the system to transfer heat.
How is the Heat is conserved differential equation used in science?
The Heat is conserved differential equation is used in science to study the behavior of heat in various systems, such as heat transfer in materials, the cooling or heating of a substance, and the temperature distribution in a system. It is also used in engineering to design and optimize heat transfer processes.
What are some real-world applications of the Heat is conserved differential equation?
The Heat is conserved differential equation has many real-world applications, including studying the temperature distribution in buildings, designing efficient heating and cooling systems, analyzing heat transfer in engines and machinery, and understanding the Earth's climate and weather patterns.
