Heat of combustión of a mixture of two substances?
In summary: Well ... if any C particles or CO emitted in exhaust then combustion is not complete , many garages have equipment for measuring emissions, I don't know if this is significant and worth bothering about ... temperature of engine could be measured by thermocouple for comparison .
Saharka
Hello chemists, need some help here.
I'm trying to calculate the power output of a certain otto cycle using different fuels, specifically gasoline, ethanol and different combinations of the two like 85% ethanol and 15% gasoline or 50% ethanol and 50% gasoline. However I have found it difficult to find a reliable source for the heat of combustion values of those mixed substances so I wondered if I just calculated the average heat of combustion given the proportions of the substances used or if there is some weird chemical stuff going on that I'm not aware of, this is out of my area of expertise so I figured I should ask somebody that knows.
The short version is: can I just assume that the heat of combustion value of a mixture of substances to be the average value of the heats of combustion of the substances that make the mixture given the proportions or not?
For example:
If gasoline has a heat of combustion of 47,000 Kj/Kg and ethanol 28,500 Kj/Kg would it be correct to assume that the heat of combustion of a mixture of 50% ethanol and 50% gasoline has a heat of combustion of: (47,000+28,500)/2 = 37,750 KJ/Kg is that correct?
Chemistry news on Phys.org
Saharka said:
For example:
Yes... I'm sure that's OK ... but monitor exhaust products to make sure the degree of complete combustion is not affected by mixing ...
But also this is heat of combustion don't assume that the % of work output from the engine is constant for all fuel mixes ... for example if a particular fuel makes the engine run hotter , it will be more efficient ie a greater % of the heat of combustion is turned into useful power and less wasted in heat.
Depends what the 50% means. Are you mixing equal amounts of ethanol and gasoline by volume (v/v %) or equal amounts by mass (w/w %)?
I'm doing it all theoretical for now so I only have to adjust the air to fuel ratio when changing fuels so I think that's ok.
I'm also using the fuel
Mass
So I have to do a stoichiometric analysis for each mix?
Saharka said:
Mass
Ok, then your approach is correct. 1 kg of fuel would contain 0.5 kg of ethanol and 0.5 kg of gasoline, so the heat of combustion would just be the heat generated by the combustion of 0.5 kg of ethanol plus the heat generated by the combustion of 0.5 kg of gasoline.
Great, thanks :D
This is a practical problem , not something you can do on a piece of paper ...
Related to Heat of combustión of a mixture of two substances?
1. What is the definition of heat of combustion?
The heat of combustion is the amount of energy released when a substance undergoes complete combustion, usually in the form of heat and light.
2. How is the heat of combustion measured?
The heat of combustion is typically measured using a bomb calorimeter, which is a closed container where the substance is burned and the heat released is absorbed by surrounding water. The temperature change of the water can then be used to calculate the heat of combustion.
3. How is the heat of combustion affected by different substances?
The heat of combustion can vary depending on the type of substance being burned. Factors such as the chemical composition, molecular structure, and physical state of the substance can all impact the amount of heat released during combustion.
4. Can the heat of combustion of a mixture be predicted?
Yes, the heat of combustion for a mixture of two substances can be predicted using the individual heat of combustion values for each substance. The total heat of combustion for the mixture is equal to the sum of the individual heat of combustion values.
5. How is the heat of combustion used in practical applications?
The heat of combustion is a crucial factor in understanding energy release and efficiency in various industries, such as power generation, transportation, and chemical production. It is also used in determining the energy content of different fuels and in the design of more efficient combustion processes.
  • Mechanical Engineering
  • Materials and Chemical Engineering
