Heat over time comparison question
In summary: Therefore, it would take 60 minutes for the mass to reach 50ºC in Experiment 2 with a constant ambient temperature of 100ºC.
Fancy Moses
I have a fairly basic (I hope) question - please note that the values given are just to make the problem easier to comprehend:
Given:
I'm heating, via convection, a constant sized spherical mass (Let's say m=1g) with a consistent surface area (Let's say SA = 1cm^2) at a constant temperature, Tc, (Let's say Tc = 60ºC) for a time, t = 60 minutes. Let us assume that the mass has an initial temperature (Ti) of 20ºC and after 60 minutes the temperature (Tf) of the mass will equal 50ºC. In a similar scenario (m=1g, SA=1cm^2, Ti=20ºC) how long will it take the mass to equal 50ºC if the new constant ambient temperature equals 100ºC?
Experiment 1:
m = 1g
SA = 1cm^2
Ti = 20ºC
Tc = 60ºC
Tf = 50ºC
t = 60 min
Experiment 2:
m = 1g
SA = 1cm^2
Ti = 20ºC
Tc = 100ºC
Tf = 50ºC
t = ?? min
How would I figure this out? Assuming any necessary chemical or physical properties can be found for the mass.
Any information would be greatly appreciated!
Science news on Phys.org
The answer to this question can be found by using the equation of heat transfer. This equation states that the rate of heat transfer (Q) is equal to the product of the thermal conductivity (k), the area (A), and the temperature difference (ΔT). In other words, Q = kA∆T. In this case, the thermal conductivity (k) and the area (A) remain constant, so the equation simplifies to Q = kA(Tc-Tf). Since we know the values for Q, k, A, Tc, and Tf, we can solve for t, the time it takes to reach the final temperature, by rearranging the equation to t = Q/(kA(Tc-Tf)). Plugging in the given values, we find that t = 60 min.
Related to Heat over time comparison question
1. What is a heat over time comparison question?
A heat over time comparison question is a type of scientific inquiry that involves analyzing how the amount of heat changes over a period of time. This can be done by measuring the temperature of a substance or system at different time intervals.
2. Why is heat over time comparison important?
Heat over time comparison allows scientists to track changes in temperature and understand how heat is transferred or used in a particular system. This can provide valuable insights into the behavior of materials, chemical reactions, and physical processes.
3. What factors can affect a heat over time comparison?
There are many factors that can influence a heat over time comparison, including the type of material or substance being studied, the environment or surroundings, and the rate of heat transfer. Other variables such as pressure, humidity, and radiation can also impact the results.
4. How is heat over time comparison measured?
The most common way to measure heat over time is by using a thermometer or other temperature sensing device to record the temperature at specific intervals. This data can then be plotted on a graph to visualize the changes in heat over time.
5. What are some practical applications of heat over time comparison?
Heat over time comparison is used in many fields of science and engineering, including chemistry, physics, and environmental science. It can help researchers understand how heat is transferred in industrial processes, how materials behave under different conditions, and how to improve energy efficiency in buildings and devices.
15K
