Heat transfer and airflow question
In summary, the speaker has set up an experiment with an enclosed airspace and is using a fan and heater to create different thermal conditions. They have placed thermocouples at various points in the chamber and are noticing discrepancies in temperature changes. The listener suggests that the fan could be contributing to the increase in temperature at the fan aperture, and that the lack of ventilation in the corners could be causing lower temperature changes. The listener also suggests that radiation and convection are the main sources of heat transfer in this system. The speaker confirms that there is an inlet and outlet for air flow and that the heater does not emit light due to a thermostat. The speaker thanks the listener for their answer and mentions that it has provided keywords for further research.
Ioannis86
Hello everybody, I would like your comments on my findings and perhaps prompt me to look at relevant literature.
Consider an enclosed airspace 1m length, 1m height, 0.5m width. At the center of its one 0.5 side a fan is drawing air out of the chamber through an aperture(steady, low air extraction) . At its other end a heater is used to produce different thermal conditions (through another aperture). I have placed 3 thermocouples at the fan's side, 1 at the center of the aperture and 2 at the lower corners. For a full heat input, the temperature elevation at the second hour is 4.5 C for the right corner and 1.7C for the left corner. This must mean that the left corner is better ventilated than the right corner, but, if that is the case, why does the elevation at the fan aperture is 8.1C, since it is definitely a point in space always under ventilation??
Science news on Phys.org
I've included a drawing of what I pictured the set up to look like, let me know if I have something wrong.
You're saying the temperature change is greatest at the thermocouple at the fan aperture, and want to know why when this is the point of the most ventilation. I think there could be a couple reasons for that.
1) Your heater is likely a source of radiation, in which case the thermocouple at the fan will receive the most direct heat radiation. At the temperature changes you're talking about, I don't know how much this would influence things, but at a timescale of an hour, it is a possible contributor.
2) Fans do not lower the temperature of an atmosphere, they actually raise it, by contributing energy to the system. Imagine your box full of air molecules. The average kinetic energy of these molecules in a given area is proportional to the temperature of that area. The fan thermocouple is receiving a constant dose of molecules that have been heated on one side of your box and accelerated directly into the fan aperture, thereby hitting your thermocouple and delivering an exchange of energy. There is less "wind energy" in the bottom corners where your other thermocouples are, and they are also further away from the heater.
As to why the two bottom corner thermocouples show a different temperature change, this I cannot say. It perhaps has to do with the construction of the box--the thermocouples are not perfectly spaced, the box is not perfectly rectangular, the heater aperture is not quite centered, air flow is not perfectly isotropic, etc, etc. Likely, there are a lot of sources of error that would contribute to an otherwise theoretically identical temperature change reading.
Even if I have understood your set up a bit incorrectly, hopefully this has provided some insight.
Hello Soothsayer,
Thank you for your answer, the drawing you made is representative of what is happening.
So this means that low temperature change is due to the lack of ventilation and not from its effect?
It seems counter-intuitive, and I'm still trying to convince myself one way or another, but what you have is much like a convection oven. Convection is really going to be the #1 source of heat transfer in your system. You are putting heat in through one aperture and pulling air out from another (by the way, how does air get back into the chamber? You're not drawing a vacuum, are you?). Your fan is aiding this convection, and providing the best path for heat flow directly onto itself, and subsequently, the adjacent thermocouple. My thinking is that this thermocouple should then heat up the quickest. The two thermocouples in the corner don't have that same convection path aiding heat flow to their respective regions, and so they won't heat up as quickly.
It would also help me to know where you are pulling air in from (the heater aperture?) and what temperature your heater is at.
Fyi: I just spoke to a PhD friend of mine about it, and he confirmed my theory. So in a word: yes. Low temperature change is due to poor ventilation, which is not so counter-intuitive, now that I think about it. He also brought up that your heater is likely hot enough for incandescence and so radiation heating, as I mentioned, is also a significant contributor.
There is an inlet and an outlet, essentially the fan is drawing air from the chamber, air that is brought from the lab. I have included an image. http://postimage.org/image/51lemp431/
When the heater is used with full power it does not emit light because there's a thermostat in series to cut off power at 70C. Nonetheless you have answered my main question and gave me some keywords to look for in available literature, so thank you very much.
Yeah, regardless of radiation, my response should explain the situation. You're welcome!
Related to Heat transfer and airflow question
1. How does heat transfer occur?
Heat transfer occurs through three main mechanisms: conduction, convection, and radiation. Conduction is the transfer of heat through a solid material, such as when you touch a hot pan and feel the heat spread to your hand. Convection is the transfer of heat through a fluid, such as when warm air rises and cool air sinks. Radiation is the transfer of heat through electromagnetic waves, such as the warmth you feel from the sun.
2. What factors affect heat transfer?
The rate of heat transfer is affected by several factors, including the temperature difference between the objects, the thermal conductivity of the material, the surface area, and the distance between the objects.
3. How is heat transfer related to airflow?
Airflow can affect the rate of heat transfer through convection. For example, when air is blown over a hot surface, it can increase the heat transfer rate by carrying away the hot air and bringing in cooler air. Additionally, airflow can also affect the distribution of heat within a space, as air movement can cause temperature variations in different areas.
4. What is the difference between conductive and convective heat transfer?
Conductive heat transfer occurs through direct contact between two objects, such as when a hot pan touches a cold surface. Convective heat transfer, on the other hand, occurs through the movement of fluids, such as air or water, and does not require direct contact between the objects.
5. How can heat transfer and airflow be controlled in a space?
Heat transfer and airflow can be controlled through insulation, ventilation, and air conditioning systems. Insulation helps to reduce heat transfer through conduction, while ventilation and air conditioning systems can regulate airflow and temperature in a space. Additionally, factors such as building design, materials used, and weather conditions can also impact the control of heat transfer and airflow.
11K
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • Thermodynamics
17K
