tonyjk
- 227
- 3
Hello,
Let's say the temperature of an object is constant and equal to 20 °C. If we put this object to a surrounding which has a temperature of 25 °C, than there's heat transfer from the surrounding to object by convection. If q is the heat transfer (in Watt) than after a specific time (Δt) we will have Temperature of the object equal to 25 °C ( If we consider the temperature of the surrounding constant) and thus we will have a net heat transfer equal to Q = qxΔt if q is constant. My question is, if we consider a 1D heat transfer, the surface of the object exposed to the surrounding will get the heat and thus will receive each dt the amount of heat q( q is measured like a current, in a cross section of the object) then will gain as internal energy DU = q but we say that all the object gained the heat q not only the surface exposed to the surrounding. Can we say, first the surface of the object exposed will gain an internal energy equal to q (increasing its temperature) and thus "distributing" its energy "uniformly" to the other parts of the object so we can say that all the object gained DU as energy ?
Thank you
Thank you
