Heat transfer and heat from lightbulbs
In summary: Each bulb generates 100 Watts of heat. So, just for example, if the required rate of heat transfer turned out to be 300 Watts, how many bulbs would it take to generate that 300 W?In summary, to transfer 300 Watts of heat from one room to another, it would take at least 22 bulbs.
tiffanysnow
Two rooms, each a cube 4.0m on a side, sare a 12cm thick brick wall. Because of a number of 100-W light-bulbs in one room the air is at 30 Celsius, while in the other room it is at 10 Celsius. How many of the 100-W light-bulbs are needed to maintain the temperature difference across the wall?
I'm not so sure if this equation would work. But I have tried using it.
ΔQ/Δt = (kA(T-T))/l
I used the above equation and got 213.3 J/s. But I do not know if I am going the rigt direction. The answer that the book gave is 22 bulbs. Please help me and explain how I can solve this.
To solve the problem, the value of k is needed.
The value of k (for wood) = 0.08 to 0.16
The value of k (for air) = 0.023 J/s*m*C
What I have so far is (but I don't so if it is correct or not). This is the rate of heat flow
[(0.03J/s*m*C)(16m^2)(30C-10C)]/(0.12) = 213.3 J/s
But what do I do next or is this incorrect?
The expression is correct, but the numbers in it are not. What does 0.03 J/s*m*C represent? It should be the thermal conductivity of wood. The assumption here is that the entire "hot" room is at 30 oC, so we do not have to worry about the conductivity of the air. To get the book's answer, you need to use the lowest of the values for wood (0.08). This will give you the minimum number of light bulbs required to do the job.
The walls of the room are made of brick, not of wood. The thermal conductivity of brick is more than wood. Find k for brick.
The k value of brick is 0.84J/s*m*C.
Good. Repeat your calculation from Post #3, using k for brick.
I haven't really get what this post mean. How do we get the relationship between the no of bulb required and the rate of heat transfer? @_@
Welcome to Physics Forums.
Related to Heat transfer and heat from lightbulbs
1. What is heat transfer?
Heat transfer is the movement of thermal energy from one object or system to another. This can occur through three main methods: conduction, convection, and radiation.
2. How does heat transfer occur in lightbulbs?
In lightbulbs, heat transfer occurs through conduction and radiation. The filament inside the lightbulb heats up and transfers heat to the surrounding air through conduction. The heated filament also emits radiation, which transfers heat to the surrounding objects and surfaces.
3. Why do lightbulbs get hot?
Lightbulbs get hot because they produce light through the conversion of electrical energy into heat and light. The heat produced by the lightbulb is a byproduct of this process.
4. Can heat from lightbulbs be harmful?
Yes, heat from lightbulbs can be harmful if the lightbulb is too close to flammable materials or if it is not properly ventilated. It is important to follow safety precautions and keep flammable materials away from lightbulbs to prevent potential hazards.
5. How can heat from lightbulbs be controlled?
Heat from lightbulbs can be controlled through proper ventilation and by using energy-efficient lightbulbs. It is also important to avoid placing lightbulbs in enclosed spaces without proper ventilation to prevent excessive heat buildup.
